New
windows drivers script
Related products:Evaluation SystemsAI SoftwareAI AcceleratorsAxelera Community
#Get-MetisDrivers.ps1
## normally bcd edit allow unsigned drivers ... on github  Voyager SDK  every reboot ... kills bitlocker secboot.. etc...
### required wdk winget install Microsoft.WindowsSDK.10.0.22621
#Requires -RunAsAdministrator
.SYNOPSIS
    Downloads, unpacks, and test-signs Axelera Metis M.2 AIPU drivers locally.
.DESCRIPTION
    Step 1 of Axelera Metis driver installation:
      - Downloads MetisDriver and optionally Switchtec-kmdf archives
      - Extracts to a staging directory
      - Generates a self-signed test certificate (if not already present)
      - Signs all .sys/.cat/.inf driver files with the local cert
      - Enables TESTSIGNING boot mode if not already active
.PARAMETER DestDir
    Directory where archives and unpacked drivers will be staged.
    Default: $env:USERPROFILE\MetisDrivers
.PARAMETER IncludeSwitchtec
    Switch to also download the Switchtec-kmdf driver (required only for
    the 4-Metis PCIe board, not needed for single M.2 Metis).
.PARAMETER CertSubject
    Subject name for the generated test-signing certificate.
    Default: "MetisTestSign"
.EXAMPLE
    # Single M.2 Metis (most common homelab case)
    .\Get-MetisDrivers.ps1
.EXAMPLE
    # 4-port PCIe board
    .\Get-MetisDrivers.ps1 -IncludeSwitchtec
.EXAMPLE
    # Custom staging directory
    .\Get-MetisDrivers.ps1 -DestDir D:\Drivers\Metis -IncludeSwitchtec
[CmdletBinding()]
param(
    [string]$DestDir        = "$env:USERPROFILE\MetisDrivers",
    [switch]$IncludeSwitchtec,
    [string]$CertSubject    = "MetisTestSign"
Set-StrictMode -Version Latest
$ErrorActionPreference = "Stop"
# Helpers
function Write-Step([string]$Msg) {
    Write-Host "`n==> $Msg" -ForegroundColor Cyan
function Write-OK([string]$Msg) {
    Write-Host "    [OK] $Msg" -ForegroundColor Green
function Write-Warn([string]$Msg) {
    Write-Host "    [!!] $Msg" -ForegroundColor Yellow
# URLs
$BaseUrl   = "https://software.axelera.ai/artifactory/axelera-win/driver/1.3.x"
$Downloads = [ordered]@{
    "MetisDriver-1.3.1.zip"         = "$BaseUrl/MetisDriver-1.3.1.zip"
    "switchtec-kmdf-0.7_2019.zip"   = "$BaseUrl/switchtec-kmdf-0.7_2019.zip"
# 0. Preflight
Write-Step "Preflight checks"
# Ensure WDK signtool is available (ships with Windows SDK / WDK)
$SignTool = (Get-Command signtool.exe -ErrorAction SilentlyContinue)?.Source
if (-not $SignTool) {
    # Fallback: search common SDK paths
    $CandidatePaths = @(
        "${env:ProgramFiles(x86)}\Windows Kits\10\bin\*\x64\signtool.exe"
        "${env:ProgramFiles}\Windows Kits\10\bin\*\x64\signtool.exe"
    $SignTool = Resolve-Path $CandidatePaths -ErrorAction SilentlyContinue |
                Sort-Object -Descending |
                Select-Object -First 1 -ExpandProperty Path
    Write-Warn "signtool.exe not found. Install the Windows SDK / WDK."
    Write-Warn "  winget install Microsoft.WindowsSDK.10.0.22621"
    Write-Warn "Continuing — signing step will be skipped."
else {
    Write-OK "signtool: $SignTool"
# Makecert / New-SelfSignedCertificate availability
$HasPKI = [bool](Get-Command New-SelfSignedCertificate -ErrorAction SilentlyContinue)
Write-OK "New-SelfSignedCertificate available: $HasPKI"
# 1. Create staging directory
Write-Step "Creating staging directory: $DestDir"
$null = New-Item -ItemType Directory -Force -Path $DestDir
$ArchiveDir  = Join-Path $DestDir "archives"
$ExtractDir  = Join-Path $DestDir "extracted"
$null = New-Item -ItemType Directory -Force -Path $ArchiveDir, $ExtractDir
Write-OK "Directories ready."
# 2. Download archives
Write-Step "Downloading driver archives"
$ToDownload = @("MetisDriver-1.3.1.zip")
if ($IncludeSwitchtec) { $ToDownload += "switchtec-kmdf-0.7_2019.zip" }
foreach ($FileName in $ToDownload) {
    $Url        = $Downloads[$FileName]
    $OutFile    = Join-Path $ArchiveDir $FileName
    if (Test-Path $OutFile) {
        Write-Warn "$FileName already present — skipping download."
        continue
    Write-Host "    Downloading $FileName ..." -NoNewline
    try {
        $ProgressPreference = 'SilentlyContinue'   # dramatically faster Invoke-WebRequest
        Invoke-WebRequest -Uri $Url -OutFile $OutFile -UseBasicParsing
        $ProgressPreference = 'Continue'
        Write-Host " done." -ForegroundColor Green
    catch {
        Write-Host " FAILED." -ForegroundColor Red
        Write-Warn "Could not download $FileName : $_"
        Write-Warn "Download manually from: $Url"
# 3. Extract archives
Write-Step "Extracting archives"
Get-ChildItem -Path $ArchiveDir -Filter "*.zip" | ForEach-Object {
    $Zip     = $_.FullName
    $Target  = Join-Path $ExtractDir $_.BaseName
    if (Test-Path $Target) {
        Write-Warn "$($_.Name) already extracted — skipping."
        return
    Write-Host "    Expanding $($_.Name) ..."
    Expand-Archive -Path $Zip -DestinationPath $Target -Force
    Write-OK "Extracted to: $Target"
# 4. Create / retrieve test-signing certificate
Write-Step "Test-signing certificate"
$CertStore  = "Cert:\LocalMachine\My"
$ExistingCert = Get-ChildItem $CertStore |
                Where-Object { $_.Subject -like "*$CertSubject*" } |
if ($ExistingCert) {
    Write-OK "Re-using existing cert: $($ExistingCert.Thumbprint)"
    $Cert = $ExistingCert
elseif ($HasPKI) {
    Write-Host "    Creating self-signed certificate '$CertSubject' ..."
    $Cert = New-SelfSignedCertificate `
        -Subject        "CN=$CertSubject" `
        -Type           CodeSigningCert `
        -CertStoreLocation $CertStore `
        -KeySpec        Signature `
        -HashAlgorithm  SHA256 `
        -NotAfter       (Get-Date).AddYears(10)
    # Also install into Trusted Publishers + Root so Windows trusts test-signed drivers
    $CertPEM = Export-Certificate -Cert $Cert -FilePath (Join-Path $DestDir "$CertSubject.cer") -Type CERT
    Import-Certificate -FilePath $CertPEM.FullName -CertStoreLocation "Cert:\LocalMachine\Root"          | Out-Null
    Import-Certificate -FilePath $CertPEM.FullName -CertStoreLocation "Cert:\LocalMachine\TrustedPublisher" | Out-Null
    Write-OK "Certificate created and installed. Thumbprint: $($Cert.Thumbprint)"
else {
    Write-Warn "Cannot create certificate (New-SelfSignedCertificate unavailable)."
    Write-Warn "Signing step will be skipped."
    $Cert = $null
# 5. Sign drivers
Write-Step "Signing driver files"
if ($SignTool -and $Cert) {
    $DriverFiles = Get-ChildItem -Path $ExtractDir -Recurse -Include "*.sys","*.cat","*.dll" |
                   Where-Object { -not $_.PSIsContainer }
    if ($DriverFiles.Count -eq 0) {
        Write-Warn "No signable driver files found in $ExtractDir"
    else {
        foreach ($File in $DriverFiles) {
            Write-Host "    Signing: $($File.Name) ..."
            & $SignTool sign `
                /sha1  $Cert.Thumbprint `
                /fd    sha256 `
                /tr    "http://timestamp.digicert.com" `
                /td    sha256 `
                /v     $File.FullName 2>&1 | ForEach-Object { "      $_" }
            if ($LASTEXITCODE -ne 0) {
                Write-Warn "signtool returned $LASTEXITCODE for $($File.Name) — check output above."
            else {
                Write-OK $File.Name
elseif (-not $SignTool) {
    Write-Warn "Skipping signing: signtool.exe not found."
elseif (-not $Cert) {
    Write-Warn "Skipping signing: no certificate available."
# 6. Enable TESTSIGNING boot mode
Write-Step "Boot configuration — TESTSIGNING"
$BcdOutput  = & bcdedit /enum '{current}' 2>&1
$IsTestSign = $BcdOutput -match "testsigning\s+Yes"
if ($IsTestSign) {
    Write-OK "TESTSIGNING already enabled."
else {
    Write-Host "    Enabling TESTSIGNING ..."
    & bcdedit /set testsigning on | Out-Null
    if ($LASTEXITCODE -eq 0) {
        Write-OK "TESTSIGNING enabled. A reboot is required before installing the driver."
    else {
        Write-Warn "bcdedit failed (LASTEXITCODE=$LASTEXITCODE). Run as Administrator?"
# Also disable Secure Boot enforcement for test-signed drivers (Disable Integrity Checks)
# Only uncomment if you are on a non-Secure-Boot system / dev machine:
# & bcdedit /set nointegritychecks on
# 7. Summary
Write-Step "Summary"
Write-Host ""
Write-Host "  Staging root   : $DestDir"                           -ForegroundColor White
Write-Host "  Archives       : $ArchiveDir"                        -ForegroundColor White
Write-Host "  Extracted      : $ExtractDir"                        -ForegroundColor White
if ($Cert) {
Write-Host "  Cert thumbprint: $($Cert.Thumbprint)"               -ForegroundColor White
Write-Host ""
Write-Host "  Next steps:"                                         -ForegroundColor Yellow
Write-Host "    1. Reboot if TESTSIGNING was just enabled."        -ForegroundColor Yellow
Write-Host "    2. In Device Manager, right-click the Metis"       -ForegroundColor Yellow
Write-Host "       device -> Update driver -> Browse my computer"  -ForegroundColor Yellow
Write-Host "       -> point at: $ExtractDir\MetisDriver-1.3.1"    -ForegroundColor Yellow
Write-Host "    3. Repeat for the Switchtec controller using:"     -ForegroundColor Yellow
Write-Host "       $ExtractDir\switchtec-kmdf-0.7_2019"           -ForegroundColor Yellow
Write-Host ""
  • March 9, 2026
Nice work ​@Necrose99 ! So you've automated the entire test-signing workflow into a single PowerShell script? The approach is spot on: instead of just disabling integrity checks entirely (which breaks BitLocker), you're creating a self-signed cert, signing the drivers locally, and enabling TESTSIGNING mode.?
What I particularly like:
  • It pulls from the official Artifactory URLs (MetisDriver-1.3.1 and switchtec-kmdf for 4-chip boards)
  • The cert looks like it gets installed into both Trusted Publishers and Root stores, so Windows actually trusts the signed drivers
  • The script handles all the finicky bits — cert generation, signing each file, bcdedit configuration — that trip people up when following fragmented docs
  • Clear output and next-step guidance throughout
This addresses a great pain point. We've heard from folks that the current Windows setup can involve bouncing between multiple pages for firmware, drivers, WSL, test mode settings, etc. Having this as a single automated flow could be a huge time saver.
Have you tested this script yourself? If so, I'd be curious to hear:
  • What platform/host you ran it on (Win 10/11, Intel/AMD, BitLocker enabled?)?
  • Whether the signed drivers loaded successfully after reboot?
  • Any gotchas or edge cases you ran into?
  • March 9, 2026
https://github.com/maharmstone/btrfs   keys expired ?
https://github.com/bobranten/Ext4Fsd/releases/tag/v0.71  previous matt lu were  unsinged
and if you needed files paragon utility etc…  or by locally signing it it would let you read write to your Linux ssd/nvme a file from your home.. vs having to reboot usb key it etc…
windows domain admin certificates can also be used.  or your own ssl keys
its at best a temporary work around
i’ve had this as a template script for years. or similar scripts
…  for drivers that one might need that go off signing
ie old cheap  but still need for legacy items…
cacert.org Everquest everquest2 half of steam uses free certs from cacert.org
I just added fetching for the axerla drivers useful if you have windows beefy servers ….
https://github.com/Lonewolf-Information-systems/CM5-Exaviz
its bit of a mess but if arch linux or gentoo is your thing i’ve some templates here. too…
