Aetina board with M2 Metis: error timeout for querying an inference
  • August 29, 2025
  • 10 replies
  • 250 views
lucagessi
Hello everyone!
I am Luca Gessi, from Italy.
I am a (lucky) owner of Aetina board with M2 Axelera Metis.
Unfortunatly the board arrived without the SDK installed. I installed it using the github guide. The procedure faced several issues and broken packages. I had to run it several time but at the end the installation completed.
From this I tried to run simple command for testing the board (as suggested on the getting started guide):
./inference.py --no-display yolov5s-v7-coco dataset
However the inference failed:
(venv) aetina@aetina:~/voyager-sdk$ ./inference.py --no-display yolov5s-v7-coco dataset
ERROR   : timeout for querying an inferencearm_release_ver: g13p0-01eac0, rk_so_ver: 9
INFO    : Using dataset val
INFO    : Dataset 'COCO2017' split 'val' downloaded successfully to /home/aetina/.cache/axelera/data/coco
INFO    : Dataset 'COCO2017' split 'labels' downloaded successfully to /home/aetina/.cache/axelera/data/coco
INFO    : Dataset 'COCO2017' split 'annotations' downloaded successfully to /home/aetina/.cache/axelera/data/coco
Creating new label cache: /home/aetina/.cache/axelera/data/coco/labels/val2017/val_coco_objdet.cache
Labels found: 4952, corrupt images: 0
Background images: 48, missing label files: 48, empty label files: 0
Detecting...                               :   0%|▎        | 13/5000 [00:15<1:41:32,  1.22s/frames][libtriton_linux.c:505] DMABUF_METIS_XFER failed: Connection timed out
[AxeleraDmaBuf.cpp:240] DMA transfer failed: Connection timed out
[ERROR][axeShareMemoryExecute]: Dmabuf transfer failed.
[ERROR][axeCommandQueueExecuteCommandListsAsync]: Level-zero memory operation failed: 0x70010001.
  what():  axr_run_model failed with Error at zeCommandQueueExecuteCommandLists(cmdqueue, n_cmdlists, cmdlists, nullptr): cmdqueue_run_cmdlists: 319: Exit with error code: 0x70010001 : ZE_RESULT_ERROR_NOT_AVAILABLE
The board seems to be recognized by the system, axdevice outputs :
Device 0: metis-0:1:0 1GiB m2 flver=1.2.0-rc2 bcver=1.0 clock=800MHz(0-3:800MHz) mvm=0-3:100%
Metis also has the heat dissipator.
Thank you for your assistance.
lucagessi
  • September 8, 2025
Hi.
I tryed to run a pretrained model from zoo but it also fails.
aetina@aetina:~/voyager-sdk$ . venv/bin/activate
(venv) aetina@aetina:~/voyager-sdk$ axdevice
(venv) aetina@aetina:~/voyager-sdk$ ./inference.py yolov8n-coco-onnx dataset --pipe=torch-aipu --no-display
INFO : Restricting yolov8n-coco-onnx to 1 core(s) because running pipe torch-aipu.
INFO : Using CPU based torch
Detecting... : 0%|▏ | 9/5000 [01:54<16:51:46, 12.16s/frames] [libtriton_linux.c:505] DMABUF_METIS_XFER failed: Connection timed out
[ERROR][axeCommandQueueExecuteCommandListsSync]: Level-zero memory operation failed: 0x70010001.
ERROR : Error at zeCommandQueueExecuteCommandLists(cmdqueue, n_cmdlists, cmdlists, nullptr): cmdqueue_run_cmdlists: 319: Exit with error code: 0x70010001 : ZE_RESULT_ERROR_NOT_AVAILABLE
ERROR : TorchPipe terminated due to ExecutionError at /home/aetina/.cache/axelera/venvs/0ce26488/lib/python3.10/site-packages/axelera/runtime/objects.py:83: AXR_ERROR_RUNTIME_ERROR: Error at ze CommandQueueExecuteCommandLists(cmdqueue, n_cmdlists, cmdlists, nullptr): cmdqueue_run_cmdlists: 319: Exit with error code: 0x70010001 : ZE_RESULT_ERROR_NOT_AVAILABLE
ERROR : Full traceback:
ERROR : File "/home/aetina/voyager-sdk/axelera/app/pipe/torch.py", line 53, in _loop
ERROR : image, result, meta = model_pipe.inference.exec_torch(
ERROR : File "/home/aetina/voyager-sdk/axelera/app/operators/inference.py", line 1084, in exec_torch
ERROR : self._axr_modeli.run(inputs, outputs)
ERROR : File "/home/aetina/.cache/axelera/venvs/0ce26488/lib/python3.10/site-packages/axelera/runtime/objects.py", line 529, in run
ERROR : _raise_error(self.context, res.value)
ERROR : File "/home/aetina/.cache/axelera/venvs/0ce26488/lib/python3.10/site-packages/axelera/runtime/objects.py", line 83, in _raise_error
ERROR : raise exc(f"{err}: {msg}")
INFO : Model: yolov8n-coco-onnx
INFO : Dataset: CocoDataset-COCO2017
INFO : Date: 2025-09-08 08:52:12.930523
INFO : Inference Time: 89270.30ms
INFO : Evaluation Time: 127.65ms
INFO : Evaluation Metrics:
INFO : ==========================
INFO : | mAP_box | 52.65% |
INFO : | mAP50_box | 74.90% |
INFO : | precision_box | 59.25% |
INFO : | recall_box | 63.97% |
INFO : Key Metric (mAP_box): 52.65%
Core Temp : 40.0°C
CPU % : 1.5%
End-to-end : 0.1fps
Latency : 0.0ms (min:inf max:-inf σ:0.0 x̄:0.0)ms
Do you have any idea?
lucagessi
  • September 8, 2025
I tried to enable firmware update and the procedure detected an RC firmware version. The tool forced the firmware update and now it seems to work properly.
INFO : Date: 2025-09-08 09:17:07.443879
INFO : Inference Time: 475084.50ms
INFO : Evaluation Time: 11687.16ms
INFO : | mAP_box | 36.07% |
INFO : | mAP50_box | 51.04% |
INFO : | precision_box | 55.75% |
INFO : | recall_box | 50.57% |
INFO : Key Metric (mAP_box): 36.07%
Core Temp : 41.0°C
CPU % : 59.8%
End-to-end : 10.4fps
Latency : 89.6ms (min:46.9 max:155.6 σ:13.7 x̄:91.7)ms
(venv) aetina@aetina:~/voyager-sdk$ ./inference.py yolov8n-coco-onnx dataset --no-display
INFO : Date: 2025-09-08 09:19:39.082672
INFO : Inference Time: 115371.71ms
INFO : Evaluation Time: 86951.65ms
INFO : | mAP_box | 35.79% |
INFO : | mAP50_box | 50.94% |
INFO : | precision_box | 54.74% |
INFO : | recall_box | 51.05% |
INFO : Key Metric (mAP_box): 35.79%
Core Temp : 42.0°C
CPU % : 28.3%
End-to-end : 43.0fps
Latency : 495.4ms (min:380.8 max:629.5 σ:32.8 x̄:496.8)ms
Thank you
  • September 8, 2025
Hi Luca, you may try with additional argument ‘--timeout 0’ this helped me. Hope it would help you too.
lucagessi
  • September 8, 2025
Hi. I think I have fixed my problem. I enabled firmware update (here the tutorial). From there, the procedure detected an RC fimrware version and forced the update.
After that and a reboot it seems to work.
Core Temp  : 42.0°C
CPU %      : 28.3%
  • September 8, 2025
Glad you fix it.
You’re facing same problem I have. Low fps performance and high latency.
lucagessi
  • September 8, 2025
Glad you fix it.
Do you think that the performance I achieve are bad?
What should we aspect with yolov8n ?
  • September 8, 2025
They are in the docs/reference/model_zoo.md
lucagessi
  • September 8, 2025
Ok, it should achieve at least around 500 fps. Did you found any reason for this mismatch?
  • September 8, 2025
Nop
I have opened a ticket:
  • September 8, 2025
Hi ​@lucagessi!  Thanks for sharing the detailed updates. Great to see you got the board running after updating the firmware. Solid troubleshooting. 👍
And thanks ​@npi  for stepping in on this and helping!
The timeout errors look resolved now, is that right? And what you’re both seeing is a performance mismatch compared to the reference numbers in the Voyager model zoo docs?
In the meantime, really appreciate you both taking the time to test and report back like this 👍
