Blog
A New Edge AI Hardware Option for BalenaOS
Related products:AI SoftwareAI AcceleratorsTechnology
  • August 20, 2025
  • 374 views
Factory technician monitors AI video inferencing detecting defects
Developers and engineers looking for new options for their fleets of devices using edge AI are getting them.
BalenaOS has become popular precisely because it solves real deployment problems. The container-focused operating system enables over-the-air updates, remote management, and scalable fleets across embedded and edge devices.
This approach works perfectly for large-scale solutions in smart retail, healthcare, autonomous systems, robotics, and manufacturing. The challenge has been finding AI hardware that matches balenaOS's deployment philosophy.
Current solutions often create vendor lock-in and setup complexity that defeats the purpose of choosing balenaOS in the first place. New AI accelerators solve this problem by delivering right-sized performance that integrates naturally with container-native workflows. Businesses can optimize both system performance and power consumption without sacrificing the deployment flexibility that makes balenaOS valuable.
Axelera® AI's Metis® AIPU is purpose-built for computer vision and LLM inferencing at the edge with the best performance-to-cost ratio in the market. Metis' ease of use is the perfect match for balenaOS, so we set out to test whether we could bring this powerful combination to innovators at the edge.
What We Tested
Our validation was performed on an x86-based Lenovo P360 Ultra workstation, equipped with a Metis PCIe card. We used Voyager SDK version 1.3.3 and built a custom balenaOS image tailored for this setup. The goal was to enable full inference capabilities within a Docker container running on balenaOS, using the Metis accelerator.
Out-of-the-box balenaOS images do not include certain kernel features required by the Metis driver; specifically, support for system DMA-BUF heaps. Without these, the driver cannot access the necessary memory interfaces, preventing inference workloads from executing.
To address this, we built a custom balenaOS image from source, enabling the required kernel options. This involved identifying the correct device configuration for our x86 platform, modifying kernel build parameters, and compiling the OS using balena’s Yocto-based build system.
Driver and SDK Integration
Once the custom OS was in place, we compiled the Metis driver against the specific kernel version used in our balenaOS build. This step is critical, as balenaOS does not support DKMS, so drivers must be built manually for each kernel variant.
With the driver installed and loaded, we deployed the Voyager SDK inside a Docker container. Using a prebuilt image that includes all necessary runtime components, we configured the container to access the Metis device and other system resources required for inference.
Running Inference on balenaOS
After setting up the environment, we successfully ran inference workloads using the Voyager SDK inside the container. The system was able to process video input and deliver high-throughput inference performance, confirming that the Metis accelerator is fully functional under balenaOS.
To streamline future deployments, we also created a startup script that prepares the device environment on boot, loading the driver, setting permissions, and configuring device links so that inference can begin immediately after power-on.
Why This Matters
The combination of Metis processing power and balenaOS flexibility creates new possibilities for production-scale edge AI in practical deployment scenarios.
  • Retail AI at the Edge Multi-camera video analytics becomes feasible at scale. Think queue tracking across multiple checkout lanes, shelf monitoring for inventory management, or customer behavior analysis across store sections. Metis handles the stream concurrency that these applications demand, while balenaOS manages secure fleet updates across hundreds of retail locations without requiring on-site technical staff.
  • Intelligent Transport Monitoring Vehicle-mounted systems can now run sophisticated AI workloads locally. License plate recognition, passenger analytics, and incident detection operate on low-power hardware, like Metis’ 8-15 watts, with real-time processing capabilities. When new models or detection algorithms become available, balenaOS delivers over-the-air updates to entire transit fleets without service interruption.
  • Factory Floor and Infrastructure Inspection High-resolution defect detection systems can deploy across manufacturing environments with enterprise-grade management. Metis hardware even supports LLM-based analysis for complex inspection scenarios. Container-based deployment provides the audit trails and version control that regulatory environments require, while Metis delivers the processing power needed for real-time quality control.
The low cost and ease of deployment mean development teams can test and iterate new systems and solutions with speed and flexibility.
Looking Ahead
This validation advances our core mission: ensuring that breakthrough AI capabilities are within reach for every innovator building edge applications. If you’re working on an edge AI project and see potential in this approach, feel free to ask any questions on implementation below, share ideas for adapting it to your use case, or just tell us about the project you're building so we can help you get there.
  • August 24, 2025
We are working on autonomous driving and we belive this way of updating edge devices is the way to go without hardware lock-in. Axelera inc does good job of this.
  • August 26, 2025
Hi ​@deepgrid ,
Your feedback is really appreciated :)
Would you like to share with us some more details and the company you are working for? Are you already in contact with Axelera and using Axelera? We can provide further documentation on how to enable  balenaOS if required.
Let us know! We’ll be happy to help and collaborate :)
FYI ​@Spanner
  • August 26, 2025
We are trying to use axelera inc metis aipu for autonomous driving.
Struggling i should say to make the autonomous driving models to run on it. BalenaOs is on our radar. But before that we are trying to use voyager sdk to port sparsedrive an opensource autonomous driving model into aipu.
We haven't tasted success yet. We are trying to port  sparsedrive model which is already running on nvidia here  https://build.nvidia.com/nvidia/sparsedrive
To metis aipu.
It's supposed to work.
Also we are looking forward to vision transformers to run on metis aipu. It's good to see llm already working on metis aipu (phi3 and llama-7b). But what would be truly remarkable is making these liquid ai
lLiquid AI Releases LFM2-VL: Super-Fast, Open-Weight Vision-Language Models Designed for Low-Latency and Device-Aware Deployment should work out box on metis.
Regards
Deepgrid
  • August 29, 2025
Thank you for all the information ​@deepgrid !
I will connect with my colleagues on this and we will keep in contact! We are looking forward to following up your progress.
