Attaching Equipment using RS-232: M.2 Eval System RS-232 Pin-out
  • July 19, 2025
  • 140 views
shabaz
What is it?
If there’s a requirement to attach equipment to machines, one possible method would be to consider using an RS-232 interface.
RS-232 is a serial interface that can have a minimum of two or three wires (depending on if you need single direction or bidirectional communication!) with voltage levels of up to around +15V and -15V.
Once the connections have been made, it is possible to easily send and receive data using Linux, by using the /lib/ttyUSB0 device on the M.2 Eval System.
Connections on the M.2 Eval System
The Axelera M.2 Eval System has a connector that exposes this interface.  The photo here shows the pin connections.
Note that the connector also has a 5V supply output, but it’s best to avoid using that. The board could easily be damaged if too much current is attempted to be drawn from the 5V output. I don't know the limit, so personally I would not use it at all, or, restrict usage to just 10-20 mA.
The connector has a 2mm pitch pin spacing. I didn’t have a mating connector, so I soldered wires.
Interfacing to a Microcontroller
The RS-232 voltage levels cannot directly connect to a microcontroller.
An RS-232 transceiver board such as Adafruit RS232 Pal is used to convert to the levels, and automatically invert the signal, to become suitable for a microcontroller.
Source Code
Here is an example SerialComms.py file, which can be used to send text data.
To use, type:
python SerialComms.py "Hello there"
Alternatively, use it from within Python code:
from SerialComms import SerialComms
comms = SerialComms()
comms.send("Hello there")
Thanks for reading!
  • July 22, 2025
Great idea ​@shabaz ! It’s so cool that after all these years, RS-232 is still useful! Wasn’t it developed in the ‘60s, or something?!
shabaz
  • July 23, 2025
Hi! It's amazing how long it's lasted as a standard.
Machines might be plugging in their RS-232 ports in a totally AI world even in the 2060's : )
saadtiwana
  • July 23, 2025
I think the reason RS232 (or it’s TTL/CMOS equivalent “UART”) have lasted such a long time is because they are very simple and yet so versatile.
  • Connections are VERY simple (just TX, RX to take care of)
  • Data throughput is enough for most use cases
  • Data on the bus can be very easily made human-readable (not the case for some others like I2C, SPI, CAN etc which will always need some decoding. This is very good for logging/debugging
  • The protocol is asynchronous and does not limit message sizes - this keeps things simple, flexible and easy.
  • Cheap (hardware wise) to implement.
Can’t think of any other protocol that comes close :)
  • July 23, 2025
That’s true! Goes to show that the simplest solutions can last the longest!
Feels like there’s an analogy for everyday life in there somewhere...
