Error running standard examples
  • July 31, 2025
  • 46 views
llrds
 Using the Aetina Eval kit that came with the project challenge.
Trying to run some of the standard examples, I get this error message:
(venv) aetina@aetina:~/voyager-sdk$ ../ll-tests/ll-application.py
WARNING : This model is restricted to deploy for single-core (but can be run using multiple cores).
INFO : Deploying model yolov8n-coco-onnx for 1 core. This may take a while...
|████████████████████████████████████████| 10:18.7
INFO : Deploying model yolov8s-coco-onnx for 1 core. This may take a while...
|████████████████████████████████████████| 12:44.9
[libtriton_linux.c:629] DMA_GET_XFER_SYNC_STATUS failed: Connection timed out
[AxeleraDmaBuf.cpp:271] DMABUF_METIS_WAIT failed: Connection timed out
[ERROR][waitForAsyncKernelExecOrMemTransfer]: Wait host to dev failed
[ERROR][axeCommandQueueExecuteCommandListsAsync]: Waiting for command lists failed: 0x7ff00003.
what(): axr_run_model failed with Error at zeCommandQueueExecuteCommandLists(cmdqueue, n_cmdlists, cmdlists, nullptr): cmdqueue_run_cmdlists: 319: Exit with error code: 0x7FF00003 : ZE_RESULT_EXP_ERROR_REMOTE_DEVICE
Aborted
Contents of ll-application.py, am I doing something wrong?
#!/usr/bin/env python
from axelera.app import config, display
network="yolov8spose-yolov8n",
sources=[
str(config.env.framework / "media/dancing.mp4"),
def main(window, stream):
window.options(0, title="Dancing 1")
# VEHICLE = ('car', 'truck', 'motorcycle')
# center = lambda box: ((box[0] + box[2]) // 2, (box[1] + box[3]) // 2)
for frame_result in stream:
window.show(frame_result.image, frame_result.meta, frame_result.stream_id)
# for veh in frame_result.pedestrian_and_vehicle_tracker:
# print(
# f"{veh.label.name} {veh.track_id}: {center(veh.history[0])} → {center(veh.history[-1])} @ stream {frame_result.stream_id}"
with display.App(visible=True) as app:
wnd = app.create_window("Business logic demo", (900, 600))
app.start_thread(main, (wnd, stream), name='InferenceThread')
app.run()
stream.stop()
