EdgeFlowNet Optical Flow. Successfully Deployed On Board
1️⃣ EdgeFlowNet Is Now Running on the Board
We’ve successfully compiled and deployed EdgeFlowNet,
a modern encoder–decoder optical flow model,
directly on the Orange Pi 5 Plus + Metis M.2 platform.
2️⃣ Calibration for Optical Flow Is Not “Plug-and-Play”
Unlike single-image models, optical flow operates on consecutive frame pairs.
To make this work inside the Voyager SDK calibration flow,
we implemented a custom DataAdapter dedicated to optical flow:
- Takes two consecutive RGB frames
- Concatenates them into a 6-channel tensor
- Ensures layout, normalization, and ordering match model expectations
This adapter is used only for calibration,
but it is critical for correct quantization and deployment.
3️⃣ A Mysterious Shape Mismatch — and How We Found It
During deployment, we encountered a confusing Relay type error:
Error: The Relaytype checker is unable to show the following types match:
Tensor[(192,260,4,64),int8]
Tensor[(192,256,1,64),int8]
This dimensional mismatch could not be traced back to the model itself despite multiple confirmations
In the end, we found the right way to debug this in compiler_configs_full.md.
To locate the issue, we enabled two debug options in the model’s YAML file.
compilation_config:
save_error_artifact:true
trace_tvm_passes:true
This exposed the real culprit:
👉 ICR was enabled by default.
The fix was explicit and clean:
compilation_config:
enable_icr:false
enable_swicr:false
Once disabled, the mismatch disappeared.
4️⃣ Non-Symmetric Padding in Transposed Convolutions
EdgeFlowNet’s decoder contains several stride-2 transposed convolutions with odd kernels.
This leads to non-symmetric padding, for example:
- Padding:
[0, 0, 1, 1]
However, AIPU requires symmetric padding.
Retraining the model was not an option —
we wanted to preserve the original weights.
So we applied a targeted transformation strategy:
- Detect non-symmetric padding
- Convert it into:
- Symmetric padding
- Explicit output padding compensation
Example:
Before the change:
Padding was set to [0, 0, 1, 1]. Output padding was [0, 0]. AutoPad was set to SAME_UPPER.
After the change:
Padding was adjusted to [1, 1, 1, 1]. Output padding became [1, 1]. AutoPad was changed to NOTSET.
This satisfies hardware constraints
without changing the final output behavior or performance.
A pure deployment-side fix.
5️⃣ Where We Are Now
At this point, we have confirmed:
- EdgeFlowNet compiles successfully
- Runs fully on-board
- Uses a custom calibration pipeline
- Passes hardware constraints without retraining
This is a solid foundation.
🔜 Next Stage: Making It Useful
Coming up next:
- Optical flow visualization
- Runtime cost analysis
- Integration into the FlowSentry-Wake multi-stage perception framework
- Coordinated operation of:
- Object detection
- Motion estimation
- Power-aware stage switching
This is where the system-level design really starts to shine.
Stay tuned.
