Final Submission Notes - “Elderly Guardian” (edge fall-detection prototype)
I had a blast building this. Between my daughter’s sports games this weekend, I squeezed in some late-night tinkering to land a working demo I’m proud of. The YouTube link in my submission shows the prototype end-to-end: live pose detection, on-screen overlays, and a smart-plug alert when a real fall is confirmed.
What I built
A privacy-first, on-device fall detector that runs YOLOv8 Pose on an RK3588 with a Metis (Voyager SDK) accelerator, watches a Logitech C920 feed, and triggers a TP-Link Kasa plug to kick off downstream alerts/automations to an Amazon Echo Dot
Hardware + stack
Compute: RK3588 SBC
Accelerator: Axelera Metis M.2 (via Voyager SDK)
Camera: Logitech C920 (tested at 1280×720 @ 30 FPS)
Network: Edimax EW-7822UAC USB Wi-Fi
Alert path: TP-Link Kasa smart plug (local control with
python-kasa
Model: YOLOv8 Pose (Ultralytics weights) running through Voyager’s pipeline
How it works (quick tour)
Capture: Voyager pulls frames from the USB camera (GStreamer) and letterboxes to 640×640 for the model.
Pose: The Metis accelerator runs YOLOv8 Pose; Voyager returns a tidy
meta
package with boxes, 17 keypoints, and scores per person. -
Heuristics: My Python app filters low-quality detections, then decides “fall vs ok” using:
Posture: horizontal body (wide bbox + skeleton spread), near the floor (box bottom + ankles/hips in the bottom ~20–22% of frame).
Motion: true downward movement within a short window (core y and box bottom y both move down on screen).
Slow falls: if someone ends up persistently floor-prone for N frames, we flag it even without a big drop.
Guards: proximity (too close to camera), retreat (walking away → shrinking box), couch/bed sitting/lying logic to avoid false alarms.
Output: Draws skeleton + status overlays, optional MP4 recording, and pulses the Kasa plug when a fall is confirmed (easy to hook into Alexa/IFTTT/MQTT).
What’s in the repo
A README with setup steps (exports, deps, GStreamer bits) and example run commands.
The main
fall_detection.py
app with:-
OpenCV overlay, optional MP4 writer
Per-person tracking, latch-until-recovery (prevents blink-flipping)
Tunable knobs for floor band, descent pixels, min keypoints, bbox area, etc.
Optional Kasa trigger (
--kasa-ip
, cooldown, pulse length)
Demo highlights (what you’ll see in the video)
Normal walk-through - no alert
Quick sit on couch - suppressed by “off-ground + floor band” rules
Fall to floor - FALL in red, Kasa plug pulses on
Stand back up - clears after “upright + off-floor + ascended” recovery
Results & current thresholds (sane defaults)
Filters: min box area ≈ 90k px², max ≈ 220k px²; min pose conf 0.65; ≥ 8 visible keypoints (kp conf ≥ 0.35).
Fall heuristic: horizontal near floor + downward motion; or persistent floor-prone for ~6 frames.
Temporal smoothing: latch ~7 s; recovery requires upright, off floor, and rise ≥ ~50 px for ~10 frames.
Separate “future” branch
I’ve started a separate branch focused on:
“Lying on couch/bed/chair” labeling (non-alerting) using off-ground + horizontal posture with a simple per-room floor ROI.
Per-site calibration (camera height/tilt, floor band refinement).
Continued false-positive reduction for close-to-camera and quick sit scenarios.
There’s already interest on LinkedIn from healthcare, and smart-home communities around the approach and the heuristic choices, so I’m excited to share the code and iterate.
Why this matters
On-device inference keeps video private; only a local smart-plug pulse/automation needs to leave the box.
Edge-friendly: RK3588 + Metis handles 720p smoothly while staying power-efficient.
Practical: uses off-the-shelf camera and a $20 smart plug; easy path to real-world pilots.
Setup & run (basics, more details in README below)
Set
AXELERA_FRAMEWORK
,PYTHONPATH
,LD_LIBRARY_PATH
,GST_PLUGIN_PATH
pip install numpy opencv-python pyyaml python-kasa
inside a venv. -
python3 fall_detection.py app-config.yaml --out /path/to/fall_demo.mp4 --log INFO
Add
--kasa-ip <plug_ip>
to pulse the alert.
Thanks
Thanks for hosting the challenge! This was a fun, meaningful build. The README has step-by-step instructions; the video shows it working live. I’m happy to answer questions, or help tweak thresholds for specific rooms.
Demo:
