Problem Summary
Platform: ARM64 (RK3588-based boards like Radxa ROCK 5B Plus)
OS: Ubuntu 22.04
Issue: GStreamer plugins (axinplace
, axtransform
, etc.) fail to build despite:
- All GStreamer development packages installed
- CMake detecting GStreamer successfully (
GST_FOUND=1
) - No explicit build errors or warnings
- Source code present in
operators/gstaxstreamer/
Symptom: ERROR
failed to create element of type axinplace (decodebin-link0)
when trying to do inference
bash
gst-inspect-1.0 axinplace
# Returns: "No such element or plugin 'axinplace'"
After build, libgstaxstreamer.so
is missing from operators/lib/
even though the build claims success.
Root Cause Analysis
The Silent Dependency Failure
The issue is a silent CMake conditional failure caused by a missing platform-specific dependency that's not documented anywhere in the Voyager SDK.
What the developers missed:
- Incomplete dependency documentation - The SDK docs list standard GStreamer packages but omit hardware-specific requirements
- Silent build failure - The CMake logic silently skips building GStreamer plugins when dependencies aren't met, with no warning
- Platform-specific dependency - Rockchip's customized GStreamer build requires
librga
, which isn't mentioned in SDK documentation
Technical Details
In operators/CMakeLists.txt
, there's this conditional:
cmake
pkg_check_modules(GST_VIDEO gstreamer-video-1.0)
if (GMODULE_FOUND AND GLIB_FOUND AND GST_FOUND AND GST_VIDEO_FOUND)
add_subdirectory(gstaxstreamer)
install(TARGETS gstaxstreamer LIBRARY DESTINATION lib)
endif()
When GST_VIDEO_FOUND
is not set (empty/false), the entire GStreamer plugin build is silently skipped.
Why GST_VIDEO_FOUND
fails on Rockchip systems:
Rockchip ships a customized GStreamer build (version format: 1.20.x-1+rkYYMMDD+x
) that includes hardware acceleration support. The gstreamer-video-1.0.pc
file on these systems has a dependency on librga
bash
$ pkg-config --cflags gstreamer-video-1.0
# Output:
# Package librga was not found in the pkg-config search path.
# Perhaps you should add the directory containing `librga.pc'
# to the PKG_CONFIG_PATH environment variable
# Package 'librga', required by 'gstreamer-video-1.0', not found
When pkg-config fails to resolve librga
, CMake's pkg_check_modules(GST_VIDEO ...)
silently fails, leaving GST_VIDEO_FOUND
unset, and the entire GStreamer plugin build is skipped.
Verification:
Check your CMakeCache.txt:
bash
grep "GST_VIDEO_FOUND" operators/CMakeCache.txt
If you see GST_VIDEO_FOUND:INTERNAL=
(empty) instead of GST_VIDEO_FOUND:INTERNAL=1
, you have this problem.
Solution
Step 1: Install the Missing Dependency
On RK3588/Rockchip systems (Radxa, Orange Pi, etc.):
bash
sudo apt-get update
sudo apt-get install librga-dev
On other ARM64 systems, you may need different hardware acceleration libraries. Check your gstreamer-video-1.0.pc
dependencies:
bash
pkg-config --print-requires gstreamer-video-1.0
pkg-config --print-requires-private gstreamer-video-1.0
Install any missing packages listed.
Step 2: Verify pkg-config Now Works
bash
pkg-config --modversion gstreamer-video-1.0
Both should complete without errors about missing packages.
Step 3: Clean and Rebuild
bash
cd ~/voyager-sdk/operators
rm -rf CMakeCache.txt CMakeFiles/
cmake .
make -j$(nproc)
Watch for this in the build output:
[ 99%] Built target gstaxstreamer
Step 4: Verify GST_VIDEO_FOUND
bash
grep "GST_VIDEO_FOUND" CMakeCache.txt
Should show: GST_VIDEO_FOUND:INTERNAL=1
Step 5: Locate and Install the Plugin
The built library is in the build subdirectory:
bash
# Find the library
ls -lh ~/voyager-sdk/operators/gstaxstreamer/libgstaxstreamer.so
# Install to GStreamer plugin directory
GST_PLUGIN_PATH=$(pkg-config --variable=pluginsdir gstreamer-1.0)
sudo cp ~/voyager-sdk/operators/gstaxstreamer/libgstaxstreamer.so $GST_PLUGIN_PATH/
# Clear plugin cache
rm -rf ~/.cache/gstreamer-1.0/
Step 6: Test
bash
Should now display the plugin information!
What Axelera Should Fix
For the developers:
- Update documentation - Add platform-specific dependency requirements:
- For RK3588: Explicitly document
librga-dev
requirement - For other ARM platforms: Document how to check for hardware-specific GStreamer dependencies
- Improve CMake feedback - Add warning messages when optional components are skipped:
cmake
else()
message(WARNING "GStreamer plugins will not be built. Missing dependencies:")
if(NOT GST_FOUND)
message(WARNING " - gstreamer-1.0 not found")
endif()
if(NOT GST_VIDEO_FOUND)
message(WARNING " - gstreamer-video-1.0 not found")
message(WARNING " Try: pkg-config --modversion gstreamer-video-1.0")
endif()
endif()
- Add dependency validation script - Include a pre-build script that checks for all required dependencies and provides actionable error messages
- Update installation guide - Separate x86 and ARM installation instructions with platform-specific dependencies clearly listed
Generic Troubleshooting for Other Platforms
If you're on a different ARM64 board and encounter this issue:
- Check what GStreamer needs:
bash
- Find missing packages:
bash
# Look for "not found" errors
- Search for the missing package:
bash
apt-cache search <package-name>
apt-cache search <package-name>-dev
- Common ARM hardware acceleration libraries:
- Rockchip (RK3588, RK3566, etc.):
librga-dev
,librockchip-mpp-dev
- Allwinner:
libcedrus-dev
,libvdpau-sunxi-dev
