Request Artifactory Access Token for Voyager SDK v1.5 – Partial Install on Dell PowerEdge R420 (Ubuntu 24.04, Metis PCIe detected & driver loaded)
  • February 21, 2026
  • 67 views
Hello Axelera team,
I successfully got my Metis PCIe card (16 GB single-AIPU, Device 1f9d:1100) detected and running on a Dell PowerEdge R420 (Ubuntu 24.04 LTS, kernel 6.17.0-14-generic) using Voyager SDK release/v1.5.
Quick summary how I got the hardware/driver working:
  • Installed in a PCIe x4 slot (bus 0a:00.0)
  • Disabled third-party PCIe fan response via IPMI raw command to stop jet-engine fans:
    ipmitool -I lanplus -H -U root -P calvin raw 0x30 0xce 0 0x16 5 0 0 0 5 0 1 0 0
  • Updated BIOS/iDRAC to latest available for R420
  • Cloned repo: `git clone https://github.com/axelera-ai-hub/voyager-sdk.git && cd voyager-sdk && git checkout release/v1.5`
  • Ran `./install.sh --all --media` as non-root user
  • Driver loaded successfully: `metis` module active, lspci shows "Axelera AI Metis AIPU (rev 02)", `/dev/metis-0:a:0` exists
  •  `axdevice` confirms: "Device 0: metis-0:a:0 16GiB pcie flver=1.4.0 bcver=1.4 clock=800MHz(0-3:800MHz) mvm=0-3:100%"
The install finishes with "Installation complete", but the venv only contains `axdevice`
  • missing `aip-build`, `inference.py`, `deploy.py` etc. (ls venv/bin shows only axdevice).
    I suspect this is because I don't have an Artifactory / API token yet for downloading the runtime wheels, operators, and model zoo access.
Request:
I believe I need an Artifactory token for the runtime/operators/model zoo downloads.
Could you provide the token or instructions to generate one?
Thank you in advance
Best regards,
Richard
SAE Engineering
  • February 23, 2026
Hi ​@SAE Engineering !
I don’t think you need an Artifactory token with v1.5 -- the packages are now publicly accessible, so the installer should handle everything without credentials. I wonder if actually your install didn't complete properly?
It might be worth running the installer again to see if it catches what's missing. The --verbose flag will give you more detail on what's happening at each step, and should make it clearer if/where things are dropping out.
Also, Kernel 6.17 is a recent pre-release kernel, is it? We've only tested a range up to around 6.8 if I recall. If the re-install still has issues, it might be worth testing on a stable LTS kernel to rule out a driver/DKMS compatibility problem?
Let us know how it goes!
