How to configure custom LLM models in YAML?
  • December 18, 2025
  • 6 replies
  • 159 views
​@Spanner  what i get on this code?
by launching “axllm.py my.yaml”
try:
network_yaml_info = yaml_parser.get_network_yaml_info(
include_collections=['llm_local', 'llm_cards', 'llm_zoo']
parser = config.create_llm_argparser(
network_yaml_info, description='Perform LLM inference on an Axelera platform'
How to configure the yaml file
what’s inside?
can i specify like
llm_local = ip:port
llm_cards = /dev/metis0
llm_zoo = https://huggingface.com/my/llm.zip
Or
llm_zoo:
- url: ${HUG_RELEASE_URL}/llm/myhillarius.zip
- url: ${HUG_RELEASE_URL}/llm/codellama:8B.zip
- url: ${HUG_RELEASE_URL}/llm/r1-1776:70B.zip
By duck tapeing models to my yaml
  • December 19, 2025
Hi ​@florit ! (I moved this message out into its own topic, as I thought it’d make it easier to focus the conversation 😀 Hope that’s cool!)
The collections you're seeing (llm_local, llm_cards, llm_zoo) in the yaml_parser.get_network_yaml_info() code are internal SDK parameters that control where the parser looks for LLM YAML files, but they're not user-configurable as far as I know.
So you can't point to arbitrary HuggingFace URLs directly. LLM models must be pre-compiled for Metis hardware and use a specific YAML format with precompiled_url pointing to Axelera-hosted model packages.
To use an LLM, you can copy an existing YAML from ax_models/zoo/llm/ to ax_models/llm/ and run with ./inference_llm.py <model-name> or axllm <model-name>. LLM support is still marked as experimental at the moment, but there is the LLM tutorial that has some really good insights into getting started. 👍
Technically it’s all very possible, but currently needs a more hands on, experimental approach 😅 But keep us posted! I really want to see what you’re able to do with all this! What’s the project you’re working on?
  • December 19, 2025
that helps a lot 😁
want the following models:
r1-1776:70B
codellama
codegemma
is there a chance to get this precompiled this year?
  • December 19, 2025
that helps a lot 😁
r1-1776:70B
codellama
codegemma
Awesome, glad that helped!
Honestly, probably not this year, given we’re already well into December… but do add it to the Launchpad as that’s a great way to draw attention to new features, models, etc that could go on the roadmap 👍
  • December 20, 2025
​@Spanner how to pre-compile?
is there a special tool what’s used with graphic cards or aipu’s?
i want access to it ...
  • December 21, 2025
Unfortunately I don’t think there is yet for LLMs (or SLMs) as it’s still quite experimental. But there’s a LOT of working going on internally around this, so I will ask the team if there’s anything that’s in condition to be shared yet 👍
  • December 21, 2025
I read the model parameter like:  llama-3-1-8b-1024-4core-static
is it possible to make  llama-3-1-8b-2048-8core-static, llama-3-1-8b-3072-12core-static, llama-3-1-8b-4096-16core-static
true within the metis 4x4core 64GB card?
and higher models like:  llama-3-3-70b-4096-16core-static
??? big question
