Missing libaxruntime.so
I'm using NanoPC-T6. I followed the Https://support.axelera.ai/hc/en-us/articles/31859388491794-Bring-up-Voyager-SDK-in-NanoPC-T6 you sent me. However, when I proceed with the test, the test will not proceed with the following error.
https://community.axelera.ai/voyager-sdk-2/axelera-runtime-tar-gz-256?postid=2749#post2749 Someone has had the same issue in this community and I need help if there was a fix.
(venv) pi@pi-desktop:~/voyager-sdk$ AXELERA_CONFIGURE_BOARD=,20 ./inference.py yolov8l-coco-onnx ./media/traffic1_480p.mp4 --no-display
2026-01-02 14:31:47.360506524 [W:onnxruntime:Default, device_discovery.cc:164 DiscoverDevicesForPlatform] GPU device discovery failed: device_discovery.cc:89 ReadFileContents Failed to open file: "/sys/class/drm/card1/device/vendor"
Failed to create device manager: libaxruntime.so: axr_create_context: libaxruntime.so: cannot open shared object file: No such file or directory
Unsupported tracer: core_temp: valid tracers are: cpu_usage, end_to_end_fps, end_to_end_infs, latency
arm_release_ver: g13p0-01eac0, rk_so_ver: 3
ERROR : Failed to create device manager: libaxruntime.so: axr_create_context: libaxruntime.so: cannot open shared object file: No such file or directory
ERROR : Failed to create element of type axinplace (decodebin-link0)
Best answer by dhd6682
Hi Spanner!
I used balena Etcher when I flash os on sd card, and that seems to be the problem. When I flash and install using Raspberry pi imager, the axelera folder was created in the /opt/path that was not created and the required libraries were installed! However, during the test, an error called "inference time out" occurs and stops. First of all, it's solved because it's a short video, but I need help with what to do when I want to test it with a long video. I tried adding --timeout 0 to the command, but it didn't work out.
  • January 5, 2026
Hey there ​@dhd6682 !
Could be that the virtual environment isn’t activated? Before running inference, try this:
cd ~/voyager-sdk
source venv/bin/activate
You should see (venv) at the start of your terminal prompt. Then try your inference command again. Let me know if that does it!
  • January 6, 2026
Hi Spanner!
  • January 6, 2026
I just noticed this time that you had already activeted venv! My mistake there.
I wonder if it’s worth testing with YOLOv8s? The current model, YOLOv8l, is pretty big for a power-limited device like the T6. Maybe it’s hitting a thermal or power limit? Could be worth a shot switching models, for diagnostic purposes?
