Problem with Voyager SDK 1.5.1
  • December 1, 2025
  • 7 replies
  • 189 views
I’ve already redeployed the model:
./inference.py yolo11m-custom dataset --show-device-fps --no-display --pipe gst
INFO    : Using dataset val
WARNING : Using deprecated heuristic transpose detection. Redeploy the model to include explicit output info
Segmentation fault
Best answer by Giodst
It works, the only difference is the addition of this entry in the pipeline:
inference:
handle_all: false
Many Thanks! ​@Habib ​@Spanner
  • December 1, 2025
Hi ​@Giodst! Just to double check - when you say you’ve redeployed the model, did you also recompile it? There’s a breaking change in Voyager 1.5 that requires models to be recompiled.
I’m guessing you have, as you know what you’re doing, but I thought it best to check first as we dig deeper 👍
  • Community Manager
  • December 1, 2025
Hi ​@Giodst,
Could you also try using the precompiled yolo11m model from axdownloadmodel? If the model-zoo version works with inference.py, it would help confirm that the SDK installation is not the source of the issue.
Many thanks!
  • Lieutenant Commander
  • December 2, 2025
Hi ​@Habib the precompiled model works.
  • December 2, 2025
Thanks for letting us know ​@Giodst ! That’s really helpful, especially on a new release. Glad it’s working again!
  • December 3, 2025
But for custom recompiled model the error remains: WARNING : Using deprecated heuristic transpose detection. Redeploy the model to include explicit output info
Segmentation fault
  • Community Manager
  • December 3, 2025
Hi ​@Giodst
Can you please try to use this [1] yaml for your custom model? and redeploy, i.e. please make sure old artifacts are completely removed from the build/ dir. Thanks!
[1] https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.5/ax_models/zoo/yolo/object_detection/yolo11m-coco-onnx.yaml
  • December 3, 2025
inference:
handle_all: false
