SDK 1.4.2 installed successfully on Metis, but ax_runner module missing
  • November 5, 2025
  • 154 views
Hi it’s still me haha,
I’ve successfully installed the Voyager SDK v1.4.2 directly on my Metis Compute Board (Voyager Linux 1.0, Ubuntu 22.04 arm64 base).
The full installation (install.sh --runtime --development) completed without any critical errors, and all Axelera packages (runtime, compiler, qtools, etc.) appear correctly in the Python environment.
However, when I activate the SDK virtual environment and try to run:
python3 -m ax_runner --help
i get :
No module named ax_runner
Here’s a summary of my setup and verification steps:
✅ Environment
cat /etc/os-release
lsb_release -a
✅ Installation
cd ~/voyager-sdk
bash install.sh --runtime --development
source venv/bin/activate
The install completed with:
Installation complete. To activate the environment, type:
✅ Packages installed
pip list | grep axelera
→ returns:
axelera-aipu-aingine-api     0.3.0rc1.post3.dev0+def3e9a
axelera-aipu-api             3.1.0rc3.post1.dev0+6327ad4
axelera-codegen              1.4.2
axelera-compiler             1.4.2
axelera-miraculix            0.3.0
axelera-onnx-graph-cleaner   1.4.2
axelera-onnx2torch           1.4.2
axelera-qtools-tvm-interface 1.4.2
axelera-qtoolsv2             1.4.2
axelera-runtime              1.4.2
axelera_tvm                  1.4.2
axelera-types                1.4.2
❌ Issue
ax_runner is not installed in the venv:
find ~/.cache/axelera/venvs/ -type f -name "ax_runner*.py"
→ returns nothing.
Attempting to install it manually fails:
pip install ax_runner --extra-index-url https://software.axelera.ai/artifactory/api/pypi/axelera-pypi/simple
ERROR: No matching distribution found for ax_runner
🔍 Runtime path checks
ls -R /opt/axelera/runtime-1.4.2-1 | grep ax_runner
find /opt/axelera/runtime-1.4.2-1 -name "*.whl"
Both return no ax_runner package inside the runtime folder.
🧩 Summary
So far:
  • SDK 1.4.2 installs completely (runtime + development OK)
  • All core Python libs (axelera-compiler, qtools, runtime, etc.) are available
  • But ax_runner (needed to run python3 -m ax_runner) is missing from both the venv and /opt/axelera
  • My Artifactory token is valid and allows access to the private repo
Could you please confirm:
  1. If ax_runner should still be part of SDK 1.4.2 for Metis (Ubuntu arm64) installations?
  2. If it’s expected to be installed automatically, in which package or path can I find it?
  3. If needed, how can I manually link it or re-run only that component?
Thanks a lot for your help,
Thibaut
manubot
  • November 5, 2025
Hi Thibault, thanks for posting!
There is nothing called ax_runner in our SDK - can you provide more context about what you are trying to achieve?
Have you tried following this guide here?
https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.4/docs/tutorials/quick_start_guide.md#run-a-metis-accelerated-pipeline
Thanks,
Manuel
  • November 5, 2025
Hey !
Thanks for your quick answer,
I tried but it keepens telling me this error about a missing file :
  File "/home/ubuntu/voyager-sdk/./inference.py", line 11, in <module>
    from tqdm import tqdm
ModuleNotFoundError: No module named 'tqdm'
manubot
  • November 5, 2025
