Segmentation Fault when Running Inference on Voyager SDK 1.5.1 (Metis PCIe Card)
  • December 1, 2025
  • 184 views
I installed Voyager SDK 1.5.1 on Ubuntu 22.04 and the Metis PCIe card is detected correctly, but running inference results in a segmentation fault.
System Setup
  • OS: Ubuntu 22.04 (AMD64)
  • Hardware: Axelera Metis PCIe card
  • SDK Version: Voyager SDK 1.5.1
  • GPU/CPU: AMD Ryzen + integrated GPU
  • Installation completed successfully:
No pending installation tasks. To activate the environment, type: source venv/bin/activate
PCIe Card Detection
lspci -tv correctly shows the Metis device:
+-01.1-[10]----00.0 Axelera AI Metis AIPU (rev 02)
Issue
When I run a sample inference:
./inference.py yolov5s-v7-coco media/traffic1_1080p.mp4 --verbose
I get:
WARNING: Failed to get OpenCL platforms : clGetPlatformIDs failed: PLATFORM_NOT_FOUND_KHR Segmentation fault (core dumped)
The last debug messages:
DEBUG: Setting state of pipeline0 to GST_STATE_READY DEBUG: pipeline0: state-changed (null to ready) Segmentation fault (core dumped)
What I’ve checked
  • SDK installation is complete
  • PCIe card detected
  • Firmware + drivers installed (metis-dkms == 1.4.4, axelera-multi-device == 1.0.0)
  • Activated virtual environment
  • Media file loads (GStreamer detects FPS correctly)
Questions
  1. Why does the GStreamer pipeline trigger a segmentation fault?
  2. Do the OpenCL warnings indicate a missing GPU runtime that the SDK requires?
Any help or suggestions would be greatly appreciated!
Best answer by Spanner
Hi guys, sorry to hear you’ve hit a couple of problems with 1.5.1.
Before we dig too deep, did you recompile any models that were compiled with a previous version of Voyager? There’s a breaking change in 1.5 that requires models to be recompiled, or redownloaded if it’s a pre-compiled model from the zoo.
Bit of a pain admittedly, but in the long run this change will really yield fruit! 😀
  • December 1, 2025
  • December 1, 2025
Ok spanner,  will try it out
