Voyager-sdk on singularity
lorenzo.lamberti
Dear all,
I am trying to set up the metis PCIe accelerator on a intel workstation. Later we will move to a full risc-v embedded setup.
In out lab workstation we are forced to use singularity instead of docker, so i am trying to translate the docker container into a singularity one.
I think i am very close to make everything work. However, i am now stuck with a problem i can’t figure how to solve. in particular, i get a weird error when i try to run a simple ./inference.py with one of the pre-trained models.
Below the full description on how i create, run the container, and how i run the example from the voyager sdk
my `voyager-sdk-1.2.5.def` file
Bootstrap: docker
%labels
Author You
Version voyager-sdk-1.2.5
%environment
export DISPLAY=$DISPLAY
%post
apt-get update && apt-get install -y \
sudo \
git \
pciutils \
lsb-release \
x11-utils
curl \
wget \
gnupg2 \
lsb-release \
software-properties-common \
xauth \
libgl1-mesa-glx \
libxrender1 \
libxtst6 \
libxi6 \
&& apt-get clean \
&& touch /dev/metis0 \
&& update-pciids
echo "[INFO] Cloning Voyager SDK repo..."
git clone https://github.com/axelera-ai-hub/voyager-sdk.git
echo "[INFO] Running Voyager SDK install script..."
cd voyager-sdk
./install.sh --YES --no-driver --media --user llamberti@iis.ee.ethz.ch --token <whatever>
echo "Voyager SDK base container setup complete."
%runscript
echo "Starting Voyager SDK container shell..."
exec /bin/bash
i built the .sif file like this
sudo singularity build voyager-sdk-1.2.5.sif voyager-sdk-1.2.5.def
and i run the container like this:
singularity shell \
--fakeroot \
--writable-tmpfs \
--no-home \
--home /scratch/llamber/singularity-home:/root \
--bind /dev/dri:/dev/dri \
--bind /lib/modules:/lib/modules \
--bind /scratch/llamber/tmp:/tmp \
--bind /run:/run \
--bind "$HOME/.Xauthority:/root/.Xauthority" \
--env DISPLAY=$DISPLAY \
i source the environment
source /root/.cache/axelera/venvs/93f45ae3/bin/activate
export AXELERA_FRAMEWORK=/scratch/llamber/singularity-workspace-axelera/voyager-sdk
last, i try to run a simple inference
./inference.py yolov5s-v7-barrel-onnx media/traffic1_1080p.mp4 -vv --disable-opencl --disable-opengl --no-display -vv
and i get the following error
ERROR   : RuntimeError: Failed to create element of type axinplace (axinplace-addstreamid0)
below the full log. Do you guys know why this function call is failing? my guess is that it could be trying to write somewhere not writeable within the singularity container, but i could not trace down the error..
Do you have any guess on what i should check?
I tried to see if i can find this axinplace, but the following commands return me nothing.
>find / -name "libaxinplace.so" 2>/dev/null
>gst-inspect-1.0 axinplace
No such element or plugin 'axinplace'
Thanks a lot if you have the patience to read!
full error log:
(venv) Singularity> ./inference.py yolov5s-v7-barrel-onnx media/traffic1_1080p.mp4 -vv --disable-opencl --disable-opengl --no-display -vv
DEBUG :axelera.app.inf_tracers: HostTracer will write to /tmp/tmp1o1998fj
INFO :axelera.app.device_manager: Using device metis-0:6:0
DEBUG :axelera.app.network: Create network from ax_models/reference/image_preprocess/yolov5s-v7-barrel-onnx.yaml
TRACE :axelera.app.utils: Changing weight_path from weights/yolov5s-v7.onnx to /root/.cache/axelera/weights/yolov5s-v7-coco-onnx/yolov5s-v7.onnx
TRACE :axelera.app.utils: Changing template_path from $AXELERA_FRAMEWORK/pipeline-template/yolo-letterbox.yaml to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/pipeline-template/yolo-letterbox.yaml
TRACE :axelera.app.utils: Changing class_path from $AXELERA_FRAMEWORK/ax_models/base_onnx.py to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/ax_models/base_onnx.py
TRACE :axelera.app.utils: Changing weight_path from weights/yolov5s-v7.onnx to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/ax_models/reference/image_preprocess/weights/yolov5s-v7.onnx
TRACE :axelera.app.utils: Changing anchors_path from training_yamls/yolov5s.yaml to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/ax_models/reference/image_preprocess/training_yamls/yolov5s.yaml
TRACE :axelera.app.utils: Changing class_path from $AXELERA_FRAMEWORK/ax_datasets/objdataadapter.py to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/ax_datasets/objdataadapter.py
TRACE :axelera.app.utils: Changing labels_path from $AXELERA_FRAMEWORK/ax_datasets/labels/coco.names to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/ax_datasets/labels/coco.names
TRACE :axelera.app.utils: Changing repr_imgs_dir_path from $AXELERA_FRAMEWORK/data/coco2017_400_b680128 to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/data/coco2017_400_b680128
TRACE :axelera.app.utils: Changing class_path from $AXELERA_FRAMEWORK/ax_models/decoders/yolo.py to /scratch/llamber/singularity-workspace-axelera/voyager-sdk/ax_models/decoders/yolo.py
DEBUG :axelera.app.network: Register custom operator 'decodeyolo' with class DecodeYolo from /scratch/llamber/singularity-workspace-axelera/voyager-sdk/ax_models/decoders/yolo.py
TRACE :axelera.app.network: 1. build/yolov5s-v7-barrel-onnx/yolov5s-v7-coco-onnx/model_info.json: Available
TRACE :axelera.app.network: 1. build/yolov5s-v7-barrel-onnx/yolov5s-v7-coco-onnx/1/manifest.json: Available
DEBUG :axelera.app.device_manager: Reconfiguring devices with ddr_size=2.0GB, device_firmware=1, mvm_utilisation_core_0=100%, clock_profile_core_0=800MHz, mvm_utilisation_core_1=100%, clock_profile_core_1=800MHz, mvm_utilisation_core_2=100%, clock_profile_core_2=800MHz, mvm_utilisation_core_3=100%, clock_profile_core_3=800MHz
DEBUG :axelera.app.inf_tracers: Host FPS multiplier: 4
DEBUG :axelera.app.utils: $ vainfo
INFO :axelera.app.utils: Could not exec vainfo: Command '['vainfo']' returned non-zero exit status 3.
DEBUG :axelera.app.utils: libva info: VA-API version 1.14.0
DEBUG :axelera.app.utils: libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
DEBUG :axelera.app.utils: vaInitialize failed with error code -1 (unknown libva error),exit
INFO :axelera.app.pipe.manager: Network type: NetworkType.SINGLE_MODEL
INFO :axelera.app.pipe.manager: Input
INFO :axelera.app.pipe.manager: └─detections
TRACE :axelera.app.transforms: composite_expansion transformed:
TRACE :axelera.app.transforms: TorchToTensor(input_layout='NHWC', output_layout='NCHW', datatype='float32', scale=True)
TRACE :axelera.app.transforms: to:
TRACE :axelera.app.transforms: ToTensor()
TRACE :axelera.app.transforms: PermuteChannels(input_layout=<TensorLayout.NHWC: 2>, output_layout=<TensorLayout.NCHW: 1>)
TRACE :axelera.app.transforms: TypeCast(datatype='float32')
TRACE :axelera.app.transforms: Normalize(mean='0', std='255.0', tensor_layout=<TensorLayout.NCHW: 1>, format='RGB')
TRACE :axelera.app.transforms: ax_letterbox_to_tensor_and_inplace transformed:
TRACE :axelera.app.transforms: Letterbox(height=640, width=640, scaleup=True, half_pixel_centers=False, pad_val=114, image_width=1000000, image_height=1000000)
TRACE :axelera.app.transforms: LetterboxToTensorAndNormalise(height=640, width=640, mean=[0.0], std=[1.0], datatype='float32', scaleup=True)
DEBUG :yolo: Model Type: YoloFamily.YOLOv5 (YOLOv5 pattern:
DEBUG :yolo: - 3 output tensors (anchor-based)
DEBUG :yolo: - Each output has 255 channels
DEBUG :yolo: = 3 anchors × (4 box + 1 obj + 80 classes)
DEBUG :yolo: = 3 × (4 + 1 + 80) = 255
DEBUG :yolo: - Shapes: [[1, 40, 40, 255], [1, 20, 20, 255], [1, 80, 80, 255]])
TRACE :axelera.app.pipe.manager: Parse input and output options
DEBUG :axelera.app.pipe.io: FPS of /root/.cache/axelera/media/traffic1_1080p.mp4: 60
DEBUG :axelera.app.operators.inference: Enabled 4x1 inference queues for yolov5s-v7-coco-onnx because model_cores=1 and num_cores=4
DEBUG :axelera.app.operators.inference: Using inferencenet name=inference-task0 model=/scratch/llamber/singularity-workspace-axelera/voyager-sdk/build/yolov5s-v7-barrel-onnx/yolov5s-v7-coco-onnx/1/model.json devices=metis-0:6:0 double_buffer=True dmabuf_inputs=True dmabuf_outputs=True num_children=4
DEBUG :axelera.app.pipe.gst: GST representation written to build/yolov5s-v7-barrel-onnx/logs/gst_pipeline.yaml
TRACE :axelera.app.pipe.gst: environment at gst pipeline construction:
TRACE :axelera.app.pipe.gst: {'AXELERA_DEVICE_DIR': '/opt/axelera/device-1.2.5-1/omega',
TRACE :axelera.app.pipe.gst: 'AXELERA_EXAMPLES_DIR': '/opt/axelera/compiler-examples-1.2.5-1',
TRACE :axelera.app.pipe.gst: 'AXELERA_FRAMEWORK': '/scratch/llamber/singularity-workspace-axelera/voyager-sdk',
TRACE :axelera.app.pipe.gst: 'AXELERA_RISCV_TOOLCHAIN_DIR': '/opt/axelera/riscv-gnu-newlib-toolchain-409b951ba662-7',
TRACE :axelera.app.pipe.gst: 'AXELERA_RUNTIME_DIR': '/opt/axelera/runtime-1.2.5-1',
TRACE :axelera.app.pipe.gst: 'AXE_LZ_PERF_LOG_PATH': '/tmp/tmp1o1998fj',
TRACE :axelera.app.pipe.gst: 'AXE_PROFILING_CONFIG': 'HOST_TEMPLATE'}
TRACE :axelera.app.pipe.gst_helper: Setting property filesrc0.location=/root/.cache/axelera/media/traffic1_1080p.mp4
TRACE :axelera.app.pipe.gst_helper: Creating filesrc0 from filesrc
TRACE :axelera.app.pipe.gst_helper: Setting property queue_in0.force-sw-decoders=True
TRACE :axelera.app.pipe.gst_helper: Setting property queue_in0.caps=video/x-raw(ANY)
TRACE :axelera.app.pipe.gst_helper: Setting property queue_in0.expose-all-streams=False
TRACE :axelera.app.pipe.gst_helper: Creating queue_in0 from decodebin
ERROR : Failed to create element of type axinplace (axinplace-addstreamid0)
ERROR : Traceback (most recent call last):
ERROR : File "/scratch/llamber/singularity-workspace-axelera/voyager-sdk/./inference.py", line 93, in <module>
ERROR : stream = init(args, tracers)
ERROR : File "/scratch/llamber/singularity-workspace-axelera/voyager-sdk/./inference.py", line 40, in init
ERROR : return InferenceStream(pipemanager, frames=args.frames, timeout=args.timeout)
ERROR : File "/scratch/llamber/singularity-workspace-axelera/voyager-sdk/axelera/app/stream.py", line 129, in __init__
ERROR : self.pipe_mgr.init_pipe()
ERROR : File "/scratch/llamber/singularity-workspace-axelera/voyager-sdk/axelera/app/pipe/manager.py", line 404, in init_pipe
ERROR : self._pipeline.init()
ERROR : File "/scratch/llamber/singularity-workspace-axelera/voyager-sdk/axelera/app/pipe/base.py", line 64, in init
ERROR : self._loopfn = self.init_loop()
ERROR : File "/scratch/llamber/singularity-workspace-axelera/voyager-sdk/axelera/app/pipe/gst.py", line 661, in init_loop
ERROR : self.pipeline_cache = gst_helper.build_gst_pipelines(
ERROR : File "/scratch/llamber/singularity-workspace-axelera/voyager-sdk/axelera/app/pipe/gst_helper.py", line 403, in build_gst_pipelines
ERROR : raise RuntimeError(f"Failed to create element of type {instance} ({name})")
here’s my env variables:
🔎 Voyager SDK Environment Variables
AXELERA_FRAMEWORK: /scratch/llamber/singularity-workspace-axelera/voyager-sdk
AXELERA_DEVICE_DIR: /opt/axelera/device-1.2.5-1/omega
AXELERA_RUNTIME_DIR: /opt/axelera/runtime-1.2.5-1
AXELERA_RISCV_TOOLCHAIN_DIR: /opt/axelera/riscv-gnu-newlib-toolchain-409b951ba662-7
PYTHONPATH: /scratch/llamber/singularity-workspace-axelera:/opt/axelera/runtime-1.2.5-1/tvm/tvm-src:/scratch/llamber/singularity-workspace-axelera:/opt/axelera/runtime-1.2.5-1/tvm/tvm-src
LD_LIBRARY_PATH: /opt/axelera/runtime-1.2.5-1/lib:/scratch/llamber/singularity-workspace-axelera/operators/lib:/opt/axelera/runtime-1.2.5-1/lib:/scratch/llamber/singularity-workspace-axelera/operators/lib:/.singularity.d/libs
HOME: /root
Hi Lorenzo,
Usually this error means that the Axelera GST operators have not been compiled. Normally, this is part of the installation process. Would you be able to try running
make clobber-libs && make gst-operators
from inside the Voyager SDK container and virtual environment (source venv/bin/activate).
If that doesn’t work- please share the logs of trying to compile the operators with this command
Thanks,
David
  • June 24, 2025
I have the exact same issue and after running I get this error:
/usr/bin/ld: /lib/x86_64-linux-gnu/libstdc++.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
[88/141] Building CXX object customers/tu...iles/inplace_tu9.dir/src/inplace_tu9.cc.o
ninja: build stopped: subcommand failed.
make[1]: *** [Makefile:54: gst_ops_install] Error 1
make[1]: Leaving directory '/home/aris/Workspace/voyager-sdk/operators'
make: *** [Makefile:80: operators] Error 2
Will try chatgpt’s fix and let you know if it works or do you have suggestions?
Steven Hunsche
​@Pepijn any luck here? Otherwise I’m happy to investigate
lorenzo.lamberti
hi everyone,
from my side, i found a workstation that i can isolate from my lab network, and i installed the voyager sdk without a container.
therefore, I am not in a rush to make the singularity container work, but as soon as i give it a try i will give you an update
  • June 30, 2025
​@Steven Hunsche  I have to add linked libraries to the cmaklist file
target_link_libraries(... stdc++)
