Fan Speed Control? 🌬️
  • Apr 16, 2025 5:59 PM UTC
  • 6 replies
  • 183 views
Hey!
PCIe card did run out of the box with a first running demo in minutes with no issues!
Question: Is there a way to control the fan speed to reduce the noise of the card?
Best answer by manubot
hey, we are very soon going to release an SDK update that will enable automatic fan speed control on the PCIe card. We agree it is unnecessarily noisy :)
Thanks for your patience!
  • Apr 17, 2025 8:12 AM UTC
Hi ​@alex, welcome on board! It’s not currently possible, but I think the idea may have been floated around.
It’d be good if you could add that as a feature request in the Launchpad, to help the team gauge how popular that option would be 👍 If it gets some upvotes that’d be a good indication.
(To add an feature request, create a new post, and select “Idea” as the post type).
Great question, and thanks for sharing it! Are you working on a project with the Metis PCIe at the moment?
manubot
  • Apr 17, 2025 9:24 AM UTC
mcunha
  • Jul 21, 2025 5:10 PM UTC
Hi, I did not notice a lot of difference in noise generated by Metis Fan after the 1.3 release.
How to know if it is working or not ?
  • Jul 22, 2025 8:05 AM UTC
Is that on the M.2, or a PCIe card, ​@mcunha ?
mcunha
  • Jul 23, 2025 12:55 PM UTC
HI ​@Spanner,
In fact, I have a M.2 card.
I see now that the fan control is just for PCIe card. :)
If it is not already supported for M2 Cards, do you have a roadmap to support it?
  • Jul 23, 2025 2:05 PM UTC
Actually, I’m not sure, I’ll check into that.
There’s a lot of work being put into a passive cooling option, which will do away with the fan entirely (at least, as far as most applications are concened) though that won’t help people who already have the active cooling.
But I’ll let you know when I do!
