How can I flash the correct BC firmware? bcver=0.0
  • Mar 11, 2026 2:29 AM UTC
  • 72 views
I’m evaluating Metis PCIe card. It is working. I can run inference and run demo programs. But the fan is running at full speed all the time.
I checked several articles in this community site and realized that BC FW must be upgraded to enable smart fan control.
I confirmed the BC FW version of my card with axdevice command and it reports bcver==0.0.
How can I update or flash the correct BC FW?
Thanks.
  • Mar 11, 2026 2:30 AM UTC
I forgot to paste the axdevice command output. Here is the output.
$ axdevice -v
INFO: Found PCI device: 03:00.0 Processing accelerators: Axelera AI Metis AIPU (rev 02)
INFO: Found AIPU driver: metis                 212992  0
INFO: Firmware version matches: v1.5.3
[libtriton_linux.c:1321] Device command returned an error code.
[libtriton_linux.c:1322] Consider inspecting the device log via `triton_trace --slog`.
WARNING: Failed to parse response after board controller firmware version query: ''
INFO: Using device metis-0:3:0
Device 0: metis-0:3:0 4GiB pcie flver=1.4.0 bcver=0.0 clock=800MHz(0-3:800MHz) mvm=0-3:100%
  device_runtime_firmware=v1.5.3
  sw_throttling: 200°C, hysteresis 5°C, throttle rate:12%
  hw_throttling: 105°C, hysteresis 10°C
  pvt_warning_threshold: 95°C
Thanks.
  • Mar 11, 2026 9:42 AM UTC
Hi there ​@yasu0710 ! Yep, looks like you’ve done your research well there! 😃 As you say, the BC is what drives smart fan control, so running at full speed constantly isn’t unexpected behaviour in this state.
There’s a guide on how to update the firmware here: https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.5/docs/tutorials/firmware_flash_update.md
Let me know how that goes, and if it solves the problem!
