PCIE Metis card voyage sdk Failing and Basic Inference code is not working
  • Jul 17, 2025 1:03 PM UTC
  • 29 replies
  • 811 views
Show first post
  • Jul 31, 2025 9:04 AM UTC
 Hi ​@Spanner i am facing a issue like whenever i power on the PC it is showing
the device as
 +-01.0-[01]----00.0  Synopsys, Inc. DWC_usb3 / PCIe bridge
and it sometimes works after changing the slot:
now it is persitant i want help with this…
wgtech@wgtech-server:~$ lspci -tv
-[0000:00]-+-00.0 Intel Corporation 12th Gen Core Processor Host Bridge/DRAM Registers
+-02.0 Intel Corporation AlderLake-S GT1
+-06.0-[02]----00.0 Sandisk Corp WD SN560/SN740/SN770/SN5000 NVMe SSD
+-0a.0 Intel Corporation Platform Monitoring Technology
+-0e.0 Intel Corporation Volume Management Device NVMe RAID Controller
+-14.0 Intel Corporation Raptor Lake USB 3.2 Gen 2x2 (20 Gb/s) XHCI Host Controller
+-14.2 Intel Corporation Raptor Lake-S PCH Shared SRAM
+-14.3 Intel Corporation Raptor Lake-S PCH CNVi WiFi
+-15.0 Intel Corporation Raptor Lake Serial IO I2C Host Controller #0
+-15.1 Intel Corporation Raptor Lake Serial IO I2C Host Controller #1
+-15.2 Intel Corporation Raptor Lake Serial IO I2C Host Controller #2
+-16.0 Intel Corporation Raptor Lake CSME HECI #1
+-17.0 Intel Corporation Raptor Lake SATA AHCI Controller
+-1a.0-[03]--
+-1b.0-[04]--
+-1c.0-[05]--
+-1c.2-[06]----00.0 Intel Corporation Ethernet Controller I226-V
+-1d.0-[07]--
+-1f.0 Intel Corporation Raptor Lake LPC/eSPI Controller
+-1f.3 Intel Corporation Raptor Lake High Definition Audio Controller
+-1f.4 Intel Corporation Raptor Lake-S PCH SMBus Controller
\-1f.5 Intel Corporation Raptor Lake SPI (flash) Controller
 I tried your trouble shooting guide:
wgtech@wgtech-server:~$ echo 1 | sudo tee /sys/bus/pci/devices/0000:01:00.0/remove > /dev/null
+-01.0-[01]--
+-1a.0-[03]--
+-1b.0-[04]--
+-1c.0-[05]--
+-1d.0-[07]--
wgtech@wgtech-server:~$ echo 1 | sudo tee /sys/bus/pci/rescan > /dev/null
+-1a.0-[03]--
+-1b.0-[04]--
+-1c.0-[05]--
+-1d.0-[07]--
sometimes when i shutdown and plug out and try it back again it works other times it is not working
i want to know why
still it is like this ​​​​​​​
  • Jul 31, 2025 2:01 PM UTC
Hmm, I’m starting to feel like there may be a fault here, ​@WGPravin. Something a little intermittent, if moving the board around sometimes works, and then it goes offline again.
Let’s look at getting a replacement sent out to you. I think that’s that the best option for fault finding at this stage. Could I ask you to submit an RMA ticket in the Help Desk? (Use the “Submit a Request” link at the top, and select RMA).
Apologies for the difficulties!
  • Aug 1, 2025 9:55 AM UTC
​@Spanner  I will fill it out
  • Feb 22, 2026 11:00 AM UTC
Ouch!
I just realized that the voyager-sdk is not a repository of the whole source code of the SDK, but it relies on artifacts downladed from https://software.axelera.ai/ui/packages .
This is going to collide with my original idea for integration, but it explains why in meta-alexera it’s written that
The complete VoyagerSDK (inference runtime, model compiler, and development tools) is not currently available natively for Yocto environments and must run inside a Docker container.
