The New Metis PCIe with 4 Quad-Core AIPUs is Here
  • Nov 21, 2025 12:17 PM UTC
  • 259 views
Big update from the Metis world: the epic new 4-core PCIe card is now available to order over on the store.
Huge performance shift that opens up seriously scalable edge AI.
📊 Key specs:
  • 856 TOPS (INT8)
  • Choice of 16GB and 64GB DRAM
  • ~12,800 FPS on ResNet-50
  • Runs dozens of streams or parallel models per board
  • 30–58W typical power draw
It’s not just the raw speed, it’s the ability to compress multi-camera inference, object detection, tracking, segmentation, and more into a single card that I find especially exciting. You can prototype in days, using the Voyager SDK’s YAML-based pipeline builder and model zoo (everything from YOLOv5 to small LLMs).
The benchmarks are where it gets interesting. YOLOv5m hits 1539 FPS at 640x640! YOLOv7 manages 859 FPS, YOLOv8l gets 720 FPS. For context, that's enough to process dozens of camera streams simultaneously without breaking a sweat.
If you’re testing edge-heavy ideas (multi-stream CV, robotics, smart cities), this is one to keep on your radar. Any thoughts on what you might build with a beast like this?
https://store.axelera.ai/products/pcie-ai-accelerator-card-powered-by-4-metis-aipu
(Datasheet attached)
  • Nov 21, 2025 1:08 PM UTC
📊 Key specs:
  • 856 TOPS (INT8)
Thanks for sharing, ​@Spanner  ! The benchmarks are seriously impressive—especially hitting those FPS numbers on YOLOv5m.
While the 16GB option is great, I actually find the 64GB version to be the most interesting part of this release. Having that amount of memory available at the edge is a huge advantage for larger models and complex pipelines.
I have a couple of questions regarding the roadmap:
  • Is there any forecast yet on the release of the M.2 MAX?
  • When can we expect to hear news regarding the new "Europa" AIPU?
Excited to see what people build with this hardware!
  • Nov 21, 2025 2:08 PM UTC
Agreed ​@Tinux, you could do a lot with 64GB!
Nothing concrete with the a release date on the Max or Europa yet, but the moment I hear something, I’ll make sure to share it on the community 👍
