Axelera Embedded 111c: Metis AIPU not responding, PCIe link down/up loop every ~10 s (BSP 1.3.3, driver 1.6.2, SDK 1.8.0)
  • Oct 5, 2026 4:26 PM UTC
  • 38 views
My Axelera Embedded 111c (Metis Compute Board) cannot communicate with the Metis AIPU. I need help solving the issue .
Board details
- BSP: 1.3.3, flashed over USB with upgrade_tool (kernel 6.1.148-rockchip-standard)
- Driver: patched to 1.6.2 by installing kernel-module-metis-6.1.148-rockchip-standard_v1.8.0-r0_arm64.deb and axelera-container_1.0-r0_arm64.deb (as described in the SDK 1.8.0 release notes). /sys/class/metis/version shows 1.6.2.
- Voyager SDK: 1.8.0 (axversion reports 1.8.0, axversion --driver reports 1.6.2)
- Did axdevice ever work on this board before? no
Symptoms
- axdevice reports: "Device communication timed out", "Failed to get valid board type for device metis-0:1:0 got 12", and board_type=unknown (not responding).
- axdevice --refresh -v reports: "USR_DMA_XFER failed: Connection timed out", "Failed to write ELF to device memory", and "Failed to load runtime stage0".
- lspci shows the device: 01:00.0 Processing accelerators [1200]: Axelera AI Metis AIPU (rev 02) [1f9d:1100]. The PCIe link on fe150000.pcie comes up at Gen3 x4.
- dmesg shows "IRQ MSI timeout (12 1)" and "DMA WR CH0 status -110" whenever axdevice runs.
- /proc/interrupts: all 32 msi-metis-0-1-0-* counters stay at 0.
- Even after a power cycle with the SDK container not started, dmesg shows the PCIe link going down and up about every 10 seconds, starting about 10 s after boot. About 5 s after each bounce, it logs "fwtrace: detached for firmware reload".
What I tried
- Full power cycles
- axdevice --refresh and axdevice --reboot
- [modprobe metis single_msi=1 dma_poll=1, if you tried it]
I am attaching the full dmesg output, /proc/interrupts, and the axdevice -v output.
root@antelao-3588:/home/antelao# dmesg | grep axl | tail -30
[   81.613983] axl 0000:01:00.0: Link up
[   86.748455] axl 0000:01:00.0: vmsi not available
[   86.748556] axl 0000:01:00.0: fwtrace: detached for firmware reload
[   91.674615] axl 0000:01:00.0: Link down
[   91.762589] axl 0000:01:00.0: Link up
[   96.985923] axl 0000:01:00.0: vmsi not available
[   96.985985] axl 0000:01:00.0: fwtrace: detached for firmware reload
[  101.832886] axl 0000:01:00.0: Link down
[  101.920880] axl 0000:01:00.0: Link up
[  106.968997] axl 0000:01:00.0: vmsi not available
[  106.969137] axl 0000:01:00.0: fwtrace: detached for firmware reload
[  385.372998] axl 0000:01:00.0: Unregister directory 0000:01:00.0
[  385.373050] axl 0000:01:00.0: Cleaning up firmware trace consumer
[  385.373740] axl 0000:01:00.0: Unregistered metis-0-1-0 (0 0)
[  385.373762] axl 0000:01:00.0: Release dma mem metis-0-1-0
[  385.411782] axl_aipu: debugfs root directory axl_aipu removed
[  389.285369] axl_aipu: root directory for axl_aipu
[  389.285791] axl 0000:01:00.0: All AER errors masked
[  389.285807] axl 0000:01:00.0: Memory windows prefetch 0x0000000000000000 0x0000000000000000
[  389.285819] axl 0000:01:00.0: Memory windows no-prefetch 0x0000000900000000 0x0000000004010000
[  389.288545] axl 0000:01:00.0: vmsi not available
[  389.288651] axl 0000:01:00.0: DMA trace buffer: 4096 entries (288 KB)
[  389.288997] axl 0000:01:00.0: Data Link Layer Link Active Reporting capability
[  389.289442] axl 0000:01:00.0: MSI registered 1 (1)
[  389.289481] axl 0000:01:00.0: irq vec number 132
[  389.289492] axl 0000:01:00.0: Initializing Metis MSI (nmsi=1, max_msi=32)
[  389.290261] axl 0000:01:00.0: fwtrace: datastream area not available yet
[  389.290274] axl 0000:01:00.0: Firmware trace consumer initialized (kfifo=1024 KB, dma=256 KB, poll=1000 ms)
[  389.290314] axl 0000:01:00.0: Register directory metis-0000:01:00.0
[  573.819106] axl 0000:01:00.0: IRQ MSI timeout (12 1)
ubuntu@antelao-3588:~/voyager-sdk$ cat /proc/interrupts
           CPU0       CPU1       CPU2       CPU3       CPU4       CPU5       CPU6       CPU7
 13:      33011      11733       8671       5408       5957       6324      20651       5587     GICv3  26 Level     arch_timer
 14:      34365      11000       8587       6761      17056      14987      15799       6623     GICv3 321 Level     rk_timer
 20:          0          0          0          0          0          0          0          0     GICv3 455 Edge      debug-signal
 21:          0          0          0          0          0          0          0          0     GICv3 365 Level     debug
 22:          0          0          0          0          0          0          0          0     GICv3 429 Level     rockchip_thermal
 23:          0          0          0          0          0          0          0          0     GICv3  23 Level     arm-pmu
 24:          0          0          0          0          0          0          0          0     GICv3 425 Level     rockchip_usb2phy
 25:          2          0          0          0          0          0          0          0     GICv3 423 Level     rockchip_usb2phy
 26:          2          0          0          0          0          0          0          0     GICv3 424 Level     rockchip_usb2phy
 27:          0          0          0          0          0          0          0          0     GICv3 426 Level     rockchip_usb2phy
 28:         10          0          0          0          0          0          0          0     GICv3 295 Level     pcie-sys
 30:          0          0          0          0          0          0          0          0     GICv3 118 Level     fea10000.dma-controller
 31:          0          0          0          0          0          0          0          0     GICv3 119 Level     fea10000.dma-controller
 32:          0          0          0          0          0          0          0          0     GICv3 120 Level     fea30000.dma-controller
 33:          0          0          0          0          0          0          0          0     GICv3 121 Level     fea30000.dma-controller
 34:          0          0          0          0          0          0          0          0     GICv3 122 Level     fed10000.dma-controller
 35:          0          0          0          0          0          0          0          0     GICv3 123 Level     fed10000.dma-controller
 37:          0          0          0          0          0          0          0          0     GICv3 142 Level     fdab9000.iommu, fdab0000.npu
 38:          0          0          0          0          0          0          0          0     GICv3 143 Level     fdab9000.iommu, fdab0000.npu
 39:          0          0          0          0          0          0          0          0     GICv3 144 Level     fdab9000.iommu, fdab0000.npu
 40:          0          0          0          0          0          0          0          0     GICv3 150 Level     fdb50800.iommu
 41:          0          0          0          0          0          0          0          0     GICv3 146 Level     fdb60f00.iommu, rga3
 42:          0          0          0          0          0          0          0          0     GICv3 147 Level     fdb70f00.iommu, rga3
 43:          0          0          0          0          0          0          0          0     GICv3 162 Level     fdb90480.iommu
 44:          0          0          0          0          0          0          0          0     GICv3 153 Level     fdba0800.iommu
 45:          0          0          0          0          0          0          0          0     GICv3 155 Level     fdba4800.iommu
 46:          0          0          0          0          0          0          0          0     GICv3 157 Level     fdba8800.iommu
 47:          0          0          0          0          0          0          0          0     GICv3 159 Level     fdbac800.iommu
 48:          0          0          0          0          0          0          0          0     GICv3 149 Level     fdbb0800.iommu, fdbb0000.iep
 49:          0          0          0          0          0          0          0          0     GICv3 131 Level     fdbdf000.iommu
 50:          0          0          0          0          0          0          0          0     GICv3 132 Level     fdbdf000.iommu
 51:          0          0          0          0          0          0          0          0     GICv3 134 Level     fdbef000.iommu
 52:          0          0          0          0          0          0          0          0     GICv3 135 Level     fdbef000.iommu
 53:          0          0          0          0          0          0          0          0     GICv3 128 Level     fdc38700.iommu
 54:          0          0          0          0          0          0          0          0     GICv3 130 Level     fdc48700.iommu
 55:          0          0          0          0          0          0          0          0     GICv3 141 Level     fdca0000.iommu
 56:      12309          0          0          0          0          0          0          0     GICv3 188 Level     fdd97e00.iommu, fdd90000.vop
 57:          0          0          0          0          0          0          0          0     GICv3 193 Level     fde50000.dp
 58:          0          0          0          0          0          0          0          0     GICv3 305 Level     ahci-dwc[fe210000.sata]
 59:          0          0          0          0          0          0          0          0     GICv3 306 Level     ahci-dwc[fe220000.sata]
 60:       4799          0          0          0          0          0          0          0     GICv3 360 Level     feb20000.spi
 61:          0          0          0          0          0          0          0          0  rockchip_gpio_irq   7 Level     rk806
 62:          0          0          0          0          0          0          0          0     rk806   0 Edge      rk805_pwrkey_fall
 63:          0          0          0          0          0          0          0          0     rk806   1 Edge      rk805_pwrkey_rise
 64:          0          0          0          0          0          0          0          0     rk806   7 Level     rk806_vb_low
 65:          0          0          0          0          0          0          0          0     GICv3 266 Level     eth0
 66:          0          0          0          0          0          0          0          0     GICv3 265 Level     eth0
 67:        296          0          0          0          0          0          0          0     GICv3 259 Level     eth1
 68:          0          0          0          0          0          0          0          0     GICv3 258 Level     eth1
 69:          0          0          0          0          0          0          0          0     GICv3 252 Level     dwc3
 70:       2706          0          0          0          0          0          0          0     GICv3 253 Level     xhci-hcd:usb1
 71:         29          0          0          0          0          0          0          0     GICv3 247 Level     ehci_hcd:usb3
 72:         32          0          0          0          0          0          0          0     GICv3 250 Level     ehci_hcd:usb5
 73:          0          0          0          0          0          0          0          0     GICv3 248 Level     ohci_hcd:usb4
 74:          0          0          0          0          0          0          0          0     GICv3 251 Level     ohci_hcd:usb6
 75:      13114          0          0          0          0          0          0          0     GICv3 349 Level     fd880000.i2c
 76:         62          0          0          0          0          0          0          0     GICv3 350 Level     fea90000.i2c
 77:          0          0          0          0          0          0          0          0     GICv3 354 Level     fead0000.i2c
 78:         73          0          0          0          0          0          0          0     GICv3 355 Level     fec80000.i2c
 79:          0          0          0          0          0          0          0          0  rockchip_gpio_irq  27 Level     fsc_interrupt_int_n
 80:         12          0          0          0          0          0          0          0     GICv3 356 Level     fec90000.i2c
 81:          0          0          0          0          0          0          0          0     GICv3 175 Level     rockchip-mipi-csi2-hw
 82:          0          0          0          0          0          0          0          0     GICv3 176 Level     rockchip-mipi-csi2-hw
 83:          0          0          0          0          0          0          0          0     GICv3 177 Level     rockchip-mipi-csi2-hw
 84:          0          0          0          0          0          0          0          0     GICv3 178 Level     rockchip-mipi-csi2-hw
 85:          0          0          0          0          0          0          0          0     GICv3 179 Level     rockchip-mipi-csi2-hw
 86:          0          0          0          0          0          0          0          0     GICv3 180 Level     rockchip-mipi-csi2-hw
 87:          0          0          0          0          0          0          0          0     GICv3 181 Level     rockchip-mipi-csi2-hw
 88:          0          0          0          0          0          0          0          0     GICv3 182 Level     rockchip-mipi-csi2-hw
 89:          0          0          0          0          0          0          0          0     GICv3 183 Level     rockchip-mipi-csi2-hw
 90:          0          0          0          0          0          0          0          0     GICv3 184 Level     rockchip-mipi-csi2-hw
 91:          0          0          0          0          0          0          0          0     GICv3 185 Level     rockchip-mipi-csi2-hw
 92:          0          0          0          0          0          0          0          0     GICv3 186 Level     rockchip-mipi-csi2-hw
 93:       8004          0          0          0          0          0          0          0     GICv3 237 Level     mmc0
 94:       8358          0          0          0          0          0          0          0     GICv3 430 Level     fec10000.saradc
 95:          0          0          0          0          0          0          0          0     GICv3 217 Level     i2s
 96:          0          0          0          0          0          0          0          0     GICv3 212 Level     i2s
 97:          0          0          0          0          0          0          0          0     GICv3 148 Level     rga2
 98:          0          0          0          0          0          0          0          0     GICv3 151 Level     fdb51000.avsd-plus, fdb50400.vdpu
101:          0          0          0          0          0          0          0          0     GICv3 152 Level     fdb50000.vepu
102:          0          0          0          0          0          0          0          0     GICv3 154 Level     fdba0000.jpege-core
103:          0          0          0          0          0          0          0          0     GICv3 156 Level     fdba4000.jpege-core
104:          0          0          0          0          0          0          0          0     GICv3 158 Level     fdba8000.jpege-core
105:          0          0          0          0          0          0          0          0     GICv3 160 Level     fdbac000.jpege-core
106:          0          0          0          0          0          0          0          0     GICv3 161 Level     fdb90000.jpegd
107:          0          0          0          0          0          0          0          0     GICv3 127 Level     fdc38100.rkvdec-core
108:          0          0          0          0          0          0          0          0     GICv3 129 Level     fdc48100.rkvdec-core
109:          0          0          0          0          0          0          0          0     GICv3 133 Level     fdbd0000.rkvenc-core
110:          0          0          0          0          0          0          0          0     GICv3 136 Level     fdbe0000.rkvenc-core
111:          0          0          0          0          0          0          0          0     GICv3 140 Level     fdc70000.av1d
113:          3          0          0          0          0          0          0          0     GICv3 392 Level     dw-hdmi-qp-hpd
114:          0          0          0          0          0          0          0          0     GICv3 201 Level     fde80000.hdmi
115:          0          0          0          0          0          0          0          0     GICv3 203 Level     fde80000.hdmi
116:         34          0          0          0          0          0          0          0     GICv3 204 Level     fde80000.hdmi
117:       2633          0          0          0          0          0          0          0     GICv3 124 Level     fb000000.gpu
118:          1          0          0          0          0          0          0          0     GICv3 125 Level     fb000000.gpu
119:       2343          0          0          0          0          0          0          0     GICv3 126 Level     fb000000.gpu
120:          0          0          0          0          0          0          0          0     GICv3 235 Level     dw-mci
121:         11          0          0          0          0          0          0          0     GICv3 105 Level     dmc
131:          0          0          0          0          0          0          0          0   ITS-MSI   8 Edge      PCIe PME
132:          0          0          0          0          0          0          0          0   ITS-MSI 524288 Edge      msi-metis-0-1-0-0
IPI0:       523        399       1033        340       2192        281       1801        240       Rescheduling interrupts
IPI1:     16938      19788      15981      16084      17243      10886      21807      12593       Function call interrupts
IPI2:         0          0          0          0          0          0          0          0       CPU stop interrupts
IPI3:         0          0          0          0          0          0          0          0       CPU stop (for crash dump) interrupts
IPI4:      4848       1197       3616       1900       5515       1098       1725       2397       Timer broadcast interrupts
IPI5:       423        292        230        212        343        286        297        297       IRQ work interrupts
IPI6:         0          0          0          0          0          0          0          0       CPU wake-up interrupts
Err:          0
ubuntu@antelao-3588:~/voyager-sdk$ axdevice -v
INFO: Found AIPU driver: metis                 147456  0
[libaxldev_linux.c:1678] Device communication timed out: device did not respond within 1 seconds. (0)
WARNING: Failed to get valid board type for device metis-0:1:0 got 12
INFO: Ignoring device 0(metis-0:1:0) as it has not returned a valid board type: 12
INFO: Using device metis-0:1:0
Device 0: metis-0:1:0 board_type=unknown (not responding)
  • Oct 8, 2026 3:40 PM UTC
Thanks for the very complete report ​@808throne, hopefully it actually narrows this down a lot.
The one thing to focus on is this line, repeating every ~10 s even with the SDK container stopped:
That looks like the Metis AIPU resetting itself on a fixed cycle before the host has asked it to do anything. Everything else we can see, like IRQ MSI timeout, DMA WR CH0 status -110, all MSI counters at 0, Failed to load runtime stage0, board_type=unknown, is the host driver timing out against a device that’s never finishing its own boot. It’s not a driver or SDK version problem, which is why --refresh, --reboot, single_msi=1/dma_poll=1 and power cycles make no difference; your host side (driver 1.6.2, SDK 1.8.0) is already consistent with the 1.8.0 compatibility matrix.
I’m wondering if the card never gets far enough for axdevice to talk to it, and since you can't reflash it from the host, it might actually be a board-level issue. Shortest route is to open a support ticket at support.axelera.ai (provide the same dmesg, /proc/interrupts and axdevice -v output) so they can check the AIPU firmware / board-controller state and advise on a reflash or replacement.
Before you do, one quick sanity check: boot the board without loading the metis module at all (modprobe -r metis, or blacklist it) and watch dmesg -w for a minute. If the PCIe link still bounces every ~10 s with no driver attached, that suggests the reset loop originates on the card 👍
