Device Did Not Respond Within 1 Seconds Error on Metis M.2
  • Jan 28, 2026 7:33 AM UTC
  • 93 views
Hi again, long time to see ^^
After 6 months I saw a post about ORIN support and I wanted to try my Metis M.2 again.
First I wanted to try it on my Desktop computer, ORIN will come after. But unfortunately, I got some errors.
Note: I was able to run Metis M.2 on my desktop before.
Now I am using same operating system (Ubuntu 22.04) but with different kernel version I suppose.
I can install the repo succesfully but when I try to run “axdevice” command it gives me an error like this:
[libdmabuf.c:1712] Device communication timed out: device did not respond within 1 seconds. (0)
WARNING:axelera.runtime:Failed to get valid board type for device metis-0:2:0 got 5
Device 0: metis-0:2:0 board_type=unknown (not responding)
What I try to solve problem but didnt help:
  • Disabled secure boot from BIOS
  • Disabled Intel_iommu from grub entry
  • Disabled pcie_aspm from grub entry
  • Installed latest version of voyager (1.5.2)
  • Installed previous version of voyager which I was able to run on April 2025 (1.2.5)
Can you help me again :)
Thank you so much
  • Feb 2, 2026 11:35 AM UTC
Hi ​@MehmetYigit!
First of all, I would try to run `axdevice --refresh`.
If you’re still out of luck, you could try with the PCIe troubleshooting guide
Let us know if it fixed your issue,
  • Feb 3, 2026 7:39 AM UTC
Hi, unfortunately i already tried this and did no solution for me.
I updated my BIOS and do the settings, after that updated to Ubuntu 24.04 still no change on the error now.
