DMABUF error
  • Jun 23, 2026 8:05 AM UTC
  • 9 replies
  • 341 views
  • Hi,
    when running inference on Metis M.2 on raspberry CM5 we noticed these errors occuring after couple minutes.
    error log:
    [libtriton_linux.c:531] DMABUF_METIS_XFER failed: Input/output error
    [AxeleraDmaBuf.cpp:222] DMA transfer failed: Input/output error
    [ERROR][axeShareMemoryExecute]: Dmabuf transfer failed.
    [ERROR][axeCommandQueueExecuteCommandListsAsync]: Level-zero memory operation failed: 0x70010001.
    what():  axr_run_model failed with Error at zeCommandQueueExecuteCommandLists(cmdqueue, n_cmdlists, cmdlists, nullptr): cmdqueue_run_cmdlists: 319:
    Exit with error code: 0x70010001 : ZE_RESULT_ERROR_NOT_AVAILABLE
    kernel errror log:
    axl 0001:01:00.0: DMA error WR CH0 (ctrl 0x1)
    setup:
     Runtime: runtime-1.5.3-1
    - Voyager SDK: v1.5.2
    - metis-dkms: 1.4.4
    - Firmware: flash version 1.5.0
    - bcver 7.1
  • Jun 23, 2026 9:36 AM UTC
Hi ​@mato!
Hmm, the kernel line:
might suggest a low-level DMA/PCIe/device-state issue rather than the model itself, I wonder...
As a first thing to try, a full power-off shutdown of the Raspberry CM5 + Metis M.2 is always worthwhile. Remove power entirely, give it a minute, then boot up again. If you’re running inside Docker, restarting the container before running inference again is often helpful.
This is different from using axdevice --reboot or a normal warm reboot, and it’s often kicked things back into action for people.
Let me know if that does anything, and we can go from there!
  • Jun 23, 2026 10:48 AM UTC
Hi ​@Spanner,
yes, power restart does get the device back in a good state, but since we use the Metis device in a real time control system having to restart the device to recover is really bad for us. We would prefer to somehow prevent this error from happening.
Just curious if you have any insight or previous experience with this error?
The error occurs even if we configure pcie gen2 or gen3 in the config.txt in linux.
  • Jun 23, 2026 3:20 PM UTC
Yeah, it’s useful for diagnostic purposes, but you can’t rely on being able to cold restart is as part of its daily operation 😅
Certainly I think setting it to PCIe gen3 is the way to go, but it sounds like you’ve tried that. It’s not a simple power issue, is it? I know the RPi can get temperemental in some weird ways if it’s not getting just enough juice. I suspect you’ve checked that, but just in case.
 Let’s see if ​@Victor Labian has any insights, too - he’s done a lot of awesome work with a Metis and RPi5 combo. 👍
  • Jun 24, 2026 7:51 AM UTC
Thanks for including ​@Victor Labian I hope he gives us some good insight.
Originally I used PCIe gen3 and the default power save mode in  Active State Power Management:
/sys/module/pcie_aspm/parameters/policy. With this combo I was getting a lot of recoverable PCIe errors (11k / min). Switching the ASPM to “performance” mode it cleared the recoverable errors to zero. But the fatal one that crashes the runtime persisted, Switching to PCIe gen2 produced same results. I can double check the power supply to the Metis.
Hi ​@mato  ​@Spanner ,
If it runs and interrupts after some minutes I suspect it can be related to power peaks.
Let us know if the following works:
Power delivery on the Raspberry Pi 5 can be limited, which may affect some models. If inference crashes, limit MVM utilisation on Metis. From our internal testing we recommend a 20% limit on the Raspberry Pi 5 (tested on Voyager SDK 1.3):
AXELERA_CONFIGURE_BOARD=,20 ./inference.py yolov8l-coco-onnx ./media/traffic1_480p.mp4 --no-display
  • Jun 25, 2026 8:38 AM UTC
Thank you for the advice, I will try it out and get back to you as soon as possible.
  • Jun 26, 2026 11:27 AM UTC
​@Spanner  ​@Victor Labian
So I applied the 20% limit on all 4 cores and so far have not recieved the  PCIe error. I even ran one long 1 hour run. One important note is also I did not report any performance degradation.
I will track this issue in the upcoming days to see if the error reoccurs with this configuration. But for now it seems fine.
Thank you both for the support!
  • Jun 26, 2026 11:31 AM UTC
Awesome news! So glad it's up and running!
What's the project you're working on, by the way?
​@mato Thank you for letting us know that it is working now! Glad I could help :)
