How to use Batch Size > 1 for input during model compilation
  • Apr 28, 2026 1:20 PM UTC
  • 5 replies
  • 78 views
I am trying to run some filtering models for my workflow on Axelera Metis. However, the `axcompile` command doesn’t allow for inputs with batch size (dim = 0) to be greater than 1. During model inference, that means that I have to pass inputs in a sequential order which introduces latency. The model is a custom model (not in model zoo) and not a vision model.
I have tried creating 4 instances of the same model running on each of the cores of Metis AIPU, but that isn’t possible due to SRAM memory limitations.
Is there a way to use Batch Size > 1 for Metis?
  • Apr 29, 2026 4:04 PM UTC
Hi there ​@reck!
Ah, possibly Voyager is at cross purposes with you here in its terminology, if I understand right 😄
In Voyager, "batch size" at the input shape level isn't how the SDK feeds multiple samples in parallel, which is why axcompile rejects dim[0] > 1. The SDK's documented mechanism for parallelism is to compile at batch=1 and then replicate the model across the four AIPU cores at runtime via num_children (or aipu_cores in the YAML), so each core processes a different frame.
I may not have explained that brilliantly, but there’s more (and better) info on it here: axinferencenet.md.
Let me know if that helps!
  • Apr 29, 2026 4:34 PM UTC
Hi ​@Spanner,
Thanks for your reply. I get what you’re trying to say and I believe the reason for that is due to constrained ONNX operations as listed in onnx-opset-17-support.md. However, for my use case it seems that a single model instance is being distributed evenly across the 4 cores. For Metis M.2, there is not enough memory available to create more than one instance of my model.
I am planning to use this towards cloud detection models on Sentinel 2 Multi-Spectral Data.
  • Apr 30, 2026 10:04 AM UTC
Hi @Spanner,
This might be unrelated to the original question, but is it possible to order a M.2 MAX Axelera Metis chip (16GB RAM) chip? I wasn’t able to find it anywhere although its been released for quite some time.
  • Apr 30, 2026 11:03 AM UTC
Hi ​@Spanner,
Hi ​@reck!
Looks to me like you've already got the right setup for a model this size: one nicely compiled instance with all four cores working on it together, sharing the weights. The reason axcompile won't take a batch dimension on top of that is the SDK splits work across cores, rather than across batches, so I think you're effectively at the ceiling for this model on a single Metis.
That being said, let’s see if ​@Habib has any suggestions here - he’s a ninja with this stuff!
  • Apr 30, 2026 11:04 AM UTC
Hi @Spanner,
Ah, it’s not actually released yet. It was announced a little while ago, but it’s yet to actually hit the store. It’s imminent though! I can almost taste it, it’s so close...
