Howto install driver into RK3588 board?
  • Feb 11, 2026 4:08 PM UTC
  • 183 views
HI ,
I have an RK3588 board running Debian, and I would like to use it with an Axelera M.2 AI card. However, I cannot find any related installation or porting documentation.
Does anyone have experience with this?
Thank you.
Best answer by Victor Labian
Hi ​@Phill ,
We are currently working on enabling more OS flexibility, so stay tuned!
This said, you can work with Debian by using Docker, which will not affect your performance or memory usage.
Please find the documentation on how to use Voyager SDK with Docker here: https://support.axelera.ai/hc/en-us/articles/25953148201362-Install-Voyager-SDK-in-a-Docker-Container
In that guide it explains how to get the driver and install it. It will work on Debian ;)
May I ask which RK3588 host you are using? I have indeed worked on supporting RK3588 hosts like the OrangePi5 or the NanoPC-T6. I created a guide for those two hosts (it can help you as reference). The main think to notice is that you will probably need to modify the device tree. But don’t worry, as that is explained in both guides:
I hope you find this info helpful.
Let us know if you have any more questions.
  • Feb 11, 2026 5:15 PM UTC
Hi there ​@Phill !
Ah, sounds cool - there’s been some experimentation going on around Debian, from what I’ve seen.
These are both RK3588 boards - maybe these can shed some light on things, and if metis would play nice with your host?
  • Feb 12, 2026 12:33 AM UTC
HI ​@Spanner
Thank you. I also noticed that Axelera has developed on the RK3588 (ARM) platform and is even selling boards with the same CPU. For example, the Metis M.2 Eval System with Aetina RK3588 Industrial Motherboard | Axelera AI Store. So I assume the driver should already be available. However, I am not sure whether it is designed for Yocto or Debian.
I just cannot find the official download location. That is why I am asking on the forum to see if anyone has relevant experience to share.
However, I also found that the RK official support seems to be Debian only, while the documents you provided are all based on Ubuntu. I would like to ask whether Axelera can provide the driver source code so that we can port it to the Debian file system.
  • Feb 16, 2026 1:48 PM UTC
Indeed, yeah, we don’t have official support for Debian (yet!) although maybe something like this could be of assistance in building it?
I know a couple of people have managed it, but I couldn’t say exactly what they needed to do.
And I think the driver source code is included when you install the Voyager SDK. It gets installed via DKMS, so after installation it’d be in /usr/src/metis-{version}/driver/, which you can potentially use to rebuild for your kernel.
Let me know if this helps, and how it goes!
  • Feb 18, 2026 11:11 AM UTC
Hi ​@Phill ,
