Metis M.2 on ThinkPad T480 - PCIe Gen3 x2 and power limits
  • Oct 2, 2026 5:11 PM UTC
  • 44 views
I’m planning to install a Metis M.2 accelerator inside a Lenovo ThinkPad T480.
The T480’s main M.2 storage connection is PCIe Gen3 x2, and I’m considering either the Embedded 110m or the 113m 8 GB.
I mainly need to confirm:
  1. Do both the 110m and 113m work correctly on PCIe Gen3 x2?
  2. Can they be power-limited to around 7–8 W if necessary?
  3. If yes, which one would you recommend for a laptop setup focused on ROS2, robotics, computer vision, and some VLM/LLM inference?
  4. Is a custom heatsink + small fan enough for this kind of installation?
The laptop runs Ubuntu on x86-64.
  • Oct 8, 2026 3:23 PM UTC
Ah, interesting! I’d be quite into this idea, as I have a T48 myself! Great machine - indestructible!
So, let’s think a bit about this... both the 110m and the 113m will work on a Gen3 x2 slot, as the cards are Gen3 x4 M.2 2280 M-key but the driver is documented as working down to a single lane, so you just get halved host bandwidth.
The T480 isn't on Axelera's validated-systems list, so BIOS/slot behaviour would be yours to test, and in truth we haven’t done much with trying them inside laptops at all.
On power, only the 113m has a true closed-loop limiter. Its default cap is already 8.5 W and you can run axdevice --set-power-limit 7 (re-apply after every reboot, it doesn't persist). Whereas the 110m (typical 3.5–9 W) can only be reduced via axdevice --set-clock 600 / --set-mvm-limitation 75, with no hard ceiling.
Given you want VLM/LLM inference as well as CV, the 113m has double the memory bandwidth and up to 8 GB, versus 1 GB on the 110m (which is fine for pure vision but not for language models), plus the enforceable power cap wouldn’t be a bad thing for a laptop bay
A custom heatsink plus small fan might be enough at a 7 W cap, but I definitely wouldn’t want to assume. There are some M.2 Thermal Design Guide in the detting started docs, but you’d probably need to watch the thermals very closely. I’m sure you know that, but just to be excplicit. So this would all be quite experimental I think, but what a great experiment if it pays off! Keep us posted!
