Metis M.2 temperature
  • Apr 29, 2026 10:45 AM UTC
  • 5 replies
  • 77 views
I’m running the metis m.2 chip in a micro pc and the temps are quite high when running the inference.
Core Temp is showing 110.0°C.
What can we do to lower these temps, or is it fine?
Thanks
  • Apr 29, 2026 10:59 AM UTC
Does this seem correct with no utilisation?
axmonitor> print
# Device 0:
System Timestamp: 1777460282206 ms
Device Timestamp: 2561649 ms
Sys-core:
Core Utilization: 2.00%
Temperature: 107°C
Clock Frequency: 100 MHz
AI-core 0:
Core Utilization: 0.00%
Temperature: 106°C
Clock Frequency: 700 MHz
Num Kernels: 0
Total Runtime: 0 us
AI-core 1:
Temperature: 106°C
Clock Frequency: 300 MHz
Num Kernels: 0
Total Runtime: 0 us
AI-core 2:
Temperature: 107°C
Clock Frequency: 200 MHz
Num Kernels: 0
Total Runtime: 0 us
AI-core 3:
Temperature: 106°C
Num Kernels: 0
Total Runtime: 0 us
Board Sensor temp_sensor0@48:
Temperature: 98°C
Context 0:
DDR Utilization: 992 MB
Is Active: No
Context 1:
DDR Utilization: 0 MB
Is Active: No
Context 2:
Is Active: No
Context 3:
Is Active: No
Memory:
Total DDR Size: 1024 MB
Used DDR Size: 0 MB
DDR Read Bandwidth: 0.00 GB/s
DDR Write Bandwidth: 0.00 GB/s
DDR Total Bandwidth: 0.00 GB/s
PCIe DMA Info:
rd:0: 0.00 MB/s
rd:1: 0.00 MB/s
rd:2: 0.00 MB/s
rd:3: 0.00 MB/s
wr:0: 0.00 MB/s
wr:1: 0.00 MB/s
wr:2: 0.00 MB/s
wr:3: 0.00 MB/s
Processes:
axsystemserver (PID: 28373)
emustafa
  • Apr 29, 2026 11:39 AM UTC
Hi ​@naeemza
Your temperature numbers are pretty high, what cooling solution are you using for the M.2?
  • Apr 29, 2026 9:01 PM UTC
Hi ​@naeemza
For now nothing, I will install a passive heatsink tomorrow. I can’t use an active heatsink as I don’t have a power port for the fan on my motherboard.
emustafa
  • Apr 29, 2026 9:58 PM UTC
You definitely need to cool it. More in-depth information here: 25548432682770
The recommended way is to use active cooling. It's recommended to buy the system with active cooling if you are not going to design a custom cooling solution. Our solution doesn't require any ports on your motherboard. It uses the power plug on the M.2 PCB. So using the card without proper cooling will result on a damaged device on the long run.
  • Apr 30, 2026 2:17 PM UTC
The passive heat sink makes a difference, its around 47C now.
Will the M.2 Active Cooling Solution fit in a dell mff.
Can you buy the active cooling heating sink on its own, we already have a few m.2 chips?
