Multi-Card Model Sharding / Unified Workloads — Roadmap or Workaround?
  • Jun 29, 2026 12:25 AM UTC
  • 45 views
Hey everyone,
I am evaluating the Metis lineup for an edge AI project and have a specific question about multi-card architecture that I haven't found a definitive answer to in the docs or SDK references.
What I understand is supported today:
  • The Voyager SDK detects multiple Metis cards in a single host.
  • Each card runs its own independent inference pipeline.
  • A real-world surveillance example shows three 4-chip PCIe cards running five primary models + one secondary model in parallel across 48 AIPU cores.
My question: Is there any current or planned SDK support for splitting a single neural network across multiple Metis cards (e.g., layer sharding or tensor parallelism across two M.2 cards)? Or is the architecture strictly "one model must fit entirely within a single card's memory and AIPU"?
Context for my use case: I am looking at a host with dual M.2 slots (e.g., Radxa Orion O6N) and weighing whether two standard Metis M.2 cards could act as a unified 2-GB / 428-TOPS accelerator for a single large model, or if I should instead plan for a single M.2 Max (16 GB) and treat the dual-M.2 path as strictly for agent-swarming / multi-model parallelism.
If unified multi-card execution is not on the roadmap, a clear confirmation would help me (and likely others) size the right SKU upfront rather than over-provisioning hardware.
Thanks for any insight you can share.
  • Jul 1, 2026 1:26 PM UTC
Hi ​@Meraclus! Ah, great question, and your framing is spot on.
Short answer: Voyager's multi-device support today is “scale-out” rather than “scale-up.” So each Metis card runs its own complete pipeline, and a model needs to fit into the card's memory and AIPU cores. There's nothing that fuses two cards into one logical accelerator (for want of a better phrase!) so two standard M.2 cards won't act as a unified 2 GB device for one model.
What multi card does give you is a single Context enumerates all cards and distributes independent workloads. The same model round-robined for throughput, or different models per card. Scaling is near-linear for compute-bound work, so that's exactly your agent-swarming/multi-model parallelism case, and a great fit for the dual-M.2 Orion O6N.
The general wisdom is to size around your largest single model's footprint first, then add cards for parallelism. 👍
Is there something specific you’re building that needs this kind of functionality?
