New
Andred7
Related products:Evaluation SystemsAI SoftwareAI AcceleratorsCompany
  • May 12, 2026 5:14 AM UTC
  • 34 views
Design me the following with the name ANDRED7 on all.1. An hybrid drone that is equipped with a sonar, a very good day and night video camera for streaming live video feeds to head office, a solar that can run for 7 days, get go's coordination and send info via satellite to head office and other hybrid equipment and the drone should be able to communicate and give orders to other hybrids.
2. The vessel that is equipped with the follow: 5 skimmer boats attached to both sides of the vessel. The skimmer boats are released by the vessel and on its return with the help of sensors positions itself perfectly so that the vessel can attach it. The skimmer boats are controlled by a pyp that can extract and pull back, the pyp is switched on by the vessel that sucks up the oil. The boom. It can extract and be pulled back in. The lengIs is given by the drone. The boom has sensors that helps to navigate the skimmers and to firm a dam around the oil.. The crain, it is used to attach its arms to a submarine and a big pyp. On top of the crain is a good day and night video camera for streaming live video to head office. The submarine is equipped with a sensor, Good day and night video camera for streaming live video. The submarine is used to find any damage to the vessel that made the spill and weld the damages plus the arms of the submarine can also attach a long pyp to sunken ships that contain oil in order to suck op the oil. All equipment on the vessel all have solar, can communicate to each other and head office plus be able to attach itself to a charging port and detach itself.
Once the vessel is full off oil the vessel returns to the port where it positions itself under a crain with the help of sensors. The crains arms attach a pyp to the vessel and pumps out the oil into containers. The crain also has a solar, can work with sensors that's on the vessel and the containers.
  • May 12, 2026 5:15 AM UTC
