Considering the M.2 module – what can it realistically handle?
  • March 27, 2025
  • 262 views
gurumeditation
I’m scoping out the Metis M.2 module for a compact edge AI project and wondering how capable it really is. I’m mainly interested in real-time object detection on 1080p video streams, maybe 2–4 cameras max.
Can it handle multi-stream inputs in real-time, or is that better suited to the PCIe version?
  • March 31, 2025
From my limited benchmarking with the M.2, I’ve found it to be a quite capable little beast! On my Core i5 I could run yolov8l-coco-onnx on 4 parallel RTSP streams of 30 FPS each (at 1080p) and get a smooth output without any dropped frames. So at least 120FPS for that model?
Here is the system I used:
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 46 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 20
On-line CPU(s) list: 0-19
Vendor ID: GenuineIntel
Model name: 13th Gen Intel(R) Core(TM) i5-13600
CPU family: 6
Model: 191
Thread(s) per core: 2
Core(s) per socket: 14
Socket(s): 1
Stepping: 2
CPU max MHz: 5000.0000
CPU min MHz: 800.0000
$ lspci | grep Metis
$ axdevice
Device 0: metis-0:1:0 board_type=pcie fwver='v1.2.5' clock=800MHz(0-3:800MHz) mvm=0-3:100%
gurumeditation
I’m still kinda new to benchmarking devices, but in my understanding that looks solid!
quant.geek
  • April 6, 2025
What I would like to see is a comparison between the Metis M.2 module and Hailo M.2 module (and maybe the Coral TPU for completeness). I placed an order for two of these and it should be coming in a few days, but instead of me doing the legwork, is there something already out there?
  • April 7, 2025
  Ah, this might have some of what you’re looking for, ​@quant.geek 👍
