Tested at Yolov8x and Yolo11
  • April 9, 2025
  • 10 replies
  • 429 views
I wanted to test the Yolo11n model. But I couldn't do this because I got an error in the calibrating part. Is this because of the use of attention mechanism in Yolo11 and Yolo12?
Error: ValueError: Some modules couldn’t be simplified: <… activation.Softmax> <…. matmul.MatMul>
In addition, when I looked at the ready yaml files on voyager sdk github, I saw that the yolov8x model was not available. Is there a special reason for this? Because when I prepared and tried a new yolov8x yaml file, I got the similar error again. But as far as I know, the attention mechanism is not used in Yolov8x.
Thanks
Best answer by Jonas
hi @oguz
If you look on our model-zoo documentation, you can indeed see that yolov11 and yolov12 are not yet supported.
https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.2.5/docs/reference/model_zoo.md#object-detection
As the error indicates, the operators you mention are not yet supported.
For yolov8x, I’m surprised you are hitting this error since that model doesn’t not have a matmul.
Are you using the original yolov8x or a modified version?
  • April 9, 2025
hi @oguz
  • April 10, 2025
Hello again,
Thank you very much for your answer. Today I tried yolov8x again and this time I managed to run it. I think I made a mistake yesterday. Is yolov8x the biggest model that can run? Yolov8's FLOP value is 344. Have you tried a larger model than this?
Thank you, I will follow the developments.
  • April 10, 2025
That’s awesome news ​@oguz, great work!  What did you need to do differently to get it running this time?
  • April 11, 2025
Actually I didn't change anything. 😅 To explain the error more accurately, I deployed again and this time it worked. I guess I did something wrong the first time without realizing it, or a reboot fixed the problem.
  • April 11, 2025
@oguz ,
You can see the full list of models we actively support here https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.2.5/docs/reference/model_zoo.md#object-detection
As you figured out by testing yolov8x, we support many more but do not include all of them in our list of reference models. Model size (no. params) and needed operations (OPS) are two different things. We do not have these numbers in our model-zoo docs but for most models you can find this as public information. I would say yolov8x is indeed already a very demanding model (in terms of OPS).
Finally, note that we often refer to ‘OPS’ instead of ‘FLOPS’ since metis is mostly performing INT8 operations.
  • April 11, 2025
By the way, I forgot to mention this. The models I tried are Yolo's segmentation models.
Berrisius
  • April 17, 2025
Could you please provide more information how you managed to run yolov8x?
  • April 18, 2025
I copied the Yolov8l yaml file and changed everything related to 'L' to 'X'. I added yolov8x to the test_yaml_mc_card_name.py file. I created the folder with the weights as in yolovl and put them in it. Then I ran it the same way.
By the way, don't forget to look at the “make” command.
  • April 20, 2025
Nice! Thanks for helping out with this request ​@oguz!
Did that work for you ​@Berrisius? What's your project?
Berrisius
  • April 20, 2025
