Bridging the Gap: Unlocking Maximum AI Performance at the Edge
Related products:AI SoftwareAI AcceleratorsTechnologyAxelera Community
  • Nov 25, 2026 7:44 AM UTC
  • 41 views
Connect your coding agents. Build inference pipelines. Benchmark real performance. Unlock the full potential of your AI hardware.
What if you could point your coding agent at your AI accelerator, ask it to explore inference pipeline configurations, and benchmark performance - all without having to manually orchestrate every step?
What if you could build computer vision pipelines, run inference at high throughput, and achieve low-latency processing while maintaining the energy efficiency of purpose-built AI hardware?
That's the idea behind AxInferenceServer.
Built on the Voyager™ SDK to unlock the potential of Axelera AI’s Embedded, Edge and Server line of products, AxInferenceServer combines high-performance inference interfaces, a flexible client-server architecture, an intuitive graphical interface, and agent-assisted development capabilities in one software stack.
From gRPC-powered computer vision inference to OpenAI-compatible APIs for language and vision-language models, AxInferenceServer gives developers the tools to build, benchmark, run, and optimize AI workloads on energy-efficient hardware.
And with an integrated Model Context Protocol (MCP) server, developers can go a step further - connecting their coding agents directly to inference infrastructure and bringing AI-assisted development into the pipeline configuration and benchmarking workflow.
From Coding Agents to Inference Pipelines
AI-assisted development is changing how developers build software. Coding agents can already help write code, explore APIs, and automate development workflows. But what happens when we bring these capabilities closer to the AI hardware itself?
AxInferenceServer includes an integrated MCP server, allowing compatible coding agents to interact with the inference infrastructure.
This opens the door to agent-assisted workflows such as:
  • Developing and configuring inference pipelines.
  • Exploring pipeline configurations.
  • Running benchmarks and comparing performance.
  • Experimenting with inference workloads.
  • Automating parts of the development and testing workflow.
Instead of manually orchestrating every step, developers can use natural-language instructions to help drive their experimentation and development process.
The MCP server works alongside the graphical interface, making inference infrastructure accessible both through direct interaction and through compatible coding agents.
Together, the Graphical User Interface (GUI) and MCP integration provide a more accessible way to interact with AI inference infrastructure, helping developers move from experimentation to execution with less manual effort.
Built for Different AI Workloads
Different AI workloads require different communication interfaces and serving architectures.
Rather than forcing every workload through the same interface, AxInferenceServer provides dedicated communication paths for computer vision, large language models, and vision-language models.
High-Performance Computer Vision Through gRPC
For computer vision workloads, AxInferenceServer uses gRPC as its inference data plane.
Built on HTTP/2 and Protocol Buffers, gRPC provides an efficient communication mechanism between remote clients and the inference server.
This architecture allows applications to send inference requests to the server while keeping compute-intensive execution on the host equipped with Axelera-AI’s hardware.
The result is a flexible way to integrate accelerated computer vision inference into decentralized distributed applications.
OpenAI-Compatible APIs for LLMs and VLMs
For large language models (LLMs) and vision-language models (VLMs), AxInferenceServer provides HTTP-based, OpenAI API-compatible interfaces through its vLLM-based serving integration.
This allows developers to interact with supported models using familiar API conventions rather than having to build an entirely new integration layer.
By leveraging the vLLM ecosystem and our dedicated serving integration, developers can build applications around language and multimodal models while using the same underlying AI acceleration hardware.
Edge and On-Premise AI. Under One Ecosystem. Multiple Clients.
To make these interfaces easier to consume, AxInferenceServer provides a collection of dedicated client libraries.
The client ecosystem includes:
  • AxVisionClient: For building and executing computer vision pipelines.
  • AxLLMClient: For interacting with large language models.
  • AxVLMClient: For building applications around vision-language models.
  • AxTrack: For integrating tracking capabilities into computer vision pipelines.
These clients provide a convenient abstraction layer between applications and the underlying inference infrastructure.
Developers can focus on building their applications without having to manage the underlying hardware - software integration directly in every application.
The client-server architecture also separates application execution from inference execution. AxInferenceServer supports this approach through a distributed client-server architecture:
  • Inference Server: Deployed on an edge gateway, remote host, or on-premise system equipped with Axelera AI hardware.
  • Inference Client(s): Deployed on a centralized host, connecting applications and data sources to the inference server.
The result is a flexible architecture for deploying AI across edge and on-premise environments.
The inference server can run inside a container on an edge gateway, remote host, or on-premise system equipped with Axelera-AI hardware, while clients run on their respective application hosts. This separation allows compute-intensive inference to run where the accelerator is installed. Meanwhile applications and data sources remain on their own hosts, providing flexibility in how AI applications are developed and deployed.
High Throughput. Low Latency. Efficient Compute.
AxInferenceServer is designed to deliver both high throughput and low-latency inference, allowing developers to run demanding workloads without having to compromise unnecessarily between responsiveness and processing capacity.
By bringing inference execution together with Axelera-AI’s energy efficient hardware and a dedicated serving stack, we aim to make high-performance inference accessible without adding complexity to the application layer.
To see what this means in practice, let's look at a computer vision workload running YOLO26L on Axelera-AI’s Metis product line.
Scaling AI Inference Across Multiple Devices
High-performance inference isn't just about achieving high throughput. It's about maintaining low latency and energy efficiency while scaling performance.
To demonstrate this, we ran a YOLO26L inference pipeline with Axelera-AI’s Embedded 113m, first using a single device and then scaling the same workload across four devices with Axelera AI’s Server 150p.
The result? With a single device, we achieved approximately 170 FPS at just 9 W of power consumption. Scaling the same pipeline across four devices increased throughput to approximately 710 FPS, with a total power consumption of around 39 W.
That's more than a 4x increase in throughput across four devices, demonstrating near-linear scaling.
But throughput is only part of the story.
Importantly, this increase in performance doesn't come at the expense of energy efficiency. In both configurations, we achieve approximately 18 FPS per watt, showing that the performance-per-watt advantage remains consistent as we scale across devices.
The accompanying measurements also demonstrate that low-latency inference is maintained across both configurations. By monitoring FPS, power consumption, and inference latency throughout the experiments, we can observe how the system behaves as additional compute capacity is introduced.
These results highlight an important advantage of combining Axelera-AI’s energy-efficient inference hardware with a dedicated inference serving stack: we can significantly increase throughput by adding more devices without compromising the energy efficiency and low-latency characteristics of the system.
Metric
1 Device
4 Devices
Model
YOLO26L
YOLO26L
Throughput
~170 FPS
~710 FPS
Power consumption
~9 W
~39 W
FPS per watt
~18.9
~18.2
Relative throughput
1×
~4.18×
Relative power consumption
1×
~4.33×
In other words, scaling performance doesn't have to mean compromising on efficiency.
And here's AxVisionClient in action: 12 concurrent streams - running YOLO26L (using Axelera AI’s Server 150p), each targeting 60 FPS, over the high-performance gRPC interface of AxInferenceServer.
Beyond the benchmarks, AxInferenceServer is already powering real-world AI applications. VSaaS.ai, a Chilean tech startup, specializing in AI-powered video surveillance as a service and edge computing, is using it for more than 20,000 cameras across multiple sites, putting high-performance edge AI into action.
From No-Code Pipelines to Agent-Assisted Development
Getting started should be easy.
That's why AxInferenceServer includes a GUI-based, no-code pipeline editor that allows users to configure and experiment with inference workflows through a few simple interactions.
And we're taking developer productivity a step further.
With our integrated MCP server, users can connect coding agents and automate workflows such as pipeline development, benchmarking, and configuration testing.
This means we can move from experimentation to benchmarking and deployment workflows much faster, without having to manually orchestrate every step.
The Bigger Picture: Maximizing Your Hardware Investment
Energy efficiency, inference performance, and hardware economics are becoming increasingly important as AI moves from centralized data centers to edge and on-premise deployments.
The combination of energy-efficient AI silicon and software designed to maximize its utilization creates an opportunity to achieve more with less.
That's what we're building with AxInferenceServer.
Not just another way to serve AI models, but a software stack designed to help developers extract maximum value from their Metis and Europa product lines from Axelera AI.
More performance. Better utilization. Greater efficiency. Maximum return on investment.
AxInferenceServer - Unlock Every Bit of Your Axelera AI Hardware.
