Evangelos Eleftheriou | CTO at AXELERA AI
Technology is progressing at an incredible pace and no technology is moving faster than Artificial Intelligence (AI). Indeed, we are on the cusp of an AI revolution which is already reshaping our lives. One can use AI technologies to automate or augment humans, with applications including autonomous driving, advances in sensory perception and the acceleration of scientific discovery using machine learning. In the past five years, AI has become synonymous with Deep Learning (DL), another area seeing fast and dramatic progress. We are at a point where Deep Neural Networks (DNNs) for image and speech recognition can provide accuracy on par or even better than that achieved by the human brain.
Most of the fundamental algorithmic developments around DL go back decades. However, the recent success has stemmed from the availability of large amounts of data and immense computing power for training neural networks. From around 2010, the exponential increase of single-precision floating point operations offered by Graphic Processing Units (GPUs) ran in parallel to the explosion of neural network sizes and computational requirements. Specifically, the amount of compute used in the largest AI training has doubled every 3.5 months during the last decade. At the same time, the size of state-of-the-art models increased from 26M weights for ResNet-50 to 1.5B for GPT-2. This phenomenal increase in model size is reflected directly in the cost of training such complex models. For example, the cost of training the bidirectional transformer network BERT, for Natural Language Processing applications, is estimated at $61,000, whereas training XLNet, which outperformed BERT, costs about nine times as much. However, a major concern is not only the cost associated with the substantial energy consumption needed to train complex networks but also the significant environmental impact incurred in the form of CO2 emissions.
As the world looks to reduce carbon emissions, there is an even greater need for higher performance with lower power consumption. This is true not only for AI applications in the data center, but also at the Edge, which is where we expect the next revolution to take place. AI at the Edge refers to processing of data where it is collected, as opposed to requiring data to be moved to separate processing centers. There is a wealth of applications at the edge: AI for mobile devices, including authentication, speech recognition, and mixed/augmented reality, AI for embedded processing for IoT devices, including smart cities and homes or embedded processing for prosthetics, wearables, and personalized healthcare, as well as AI for real-time video analytics for autonomous navigation and control. However, these embedded applications are all energy and memory constrained, meaning energy efficiency matters even more so at the Edge. The end of Moore’s and Dennard’s laws are compounding these challenges. Thus, there are compelling motivations to explore novel computing architectures with inspiration from the most efficient computer on the planet, the human brain.
Traditional Computing Systems: Current State of Play
Traditional digital computing systems, based on the von Neumann architecture, consist of separate processing and memory units. Therefore, performing computations typically results in a significant amount of data being moved back and forth between the physically separated memory and processing units. This data movement costs latency and energy and creates an inherent performance bottleneck. The latency associated with the growing disparity between the speed of memory and processing units, commonly known as the memory wall, is one example of a crucial performance bottleneck for a variety of AI workloads. Similarly, the energy cost associated with shuttling data represents another key challenge for computing systems that are severely power limited due to cooling constraints as well as for the plethora of battery-operated mobile devices. In general, the energy cost of multiplying two numbers is orders of magnitude lower than that of accessing numbers from memory. Therefore, it is clear to AI developers that there is a need to explore novel computing architectures that provide better collocation of processing and memory subsystems. One suggested concept in this area is near-memory computing, which aims to reduce the physical distance and time needed to access memory. This approach heavily leverages recent advances made in die stacking and new technologies such as the high memory cube (HMC) and high bandwidth memory (HBM).
In-Memory Computing: A Radical New Approach
In-memory computing is a radically different approach to data processing, in which certain computational tasks are performed in place in the memory itself (Sebastian 2020). This is achieved by organizing the memory as a crossbar array and by exploiting the physical attributes of the memory devices. The peripheral circuitry and the control logic play a key role in creating what we call an in-memory computing (IMC) unit or computational memory unit (CMU). In addition to overcoming the latency and energy issues associated with data movement, in-memory computing has the potential to significantly improve the computational time complexity associated with certain computational tasks. This is primarily a result of the massive parallelism created by a dense array of millions of memory devices simultaneously performing computations.
For instance, crossbar arrays of such memory devices can be used to store a matrix and perform matrix-vector multiplications (MVMs) at constant O(1) time complexity without intermediate movement of data. The efficient matrix-vector multiplication via in-memory computing is very attractive for training and inference of deep neural networks, particularly for inference applications at the Edge where high energy efficiency is critical. In fact, matrix-vector multiplications constitute 70-90% of all deep learning operations. Thus, applications requiring numerous AI components such as computer vision, natural language processing, reasoning and autonomous driving can explore this new technology in new and innovative ways. Novel dedicated hardware with massive on-chip memory, where part of it is enhanced with in-memory computation capabilities could lead to very efficient training and inference engines of ultra-large neural networks comprising of potentially billions of synaptic weights.
The core technology of IMC is memory. In general, there are two classes of memory devices. The conventional one, in which information is stored in the presence or absence of charge, includes dynamic random-access memory (DRAM), static random-access memory (SRAM) and Flash memory. There is also an emerging class of memory devices, in which information is stored in terms of the atomic arrangements within nanoscale volumes of materials, as opposed to charge on a capacitor. Generally speaking, one atomic configuration corresponds to one logic state, and the other corresponds to another logic state. These differences in atomic configuration manifest as a change in resistance, and thus these devices are collectively called resistive memory devices or memristors. Traditional and emerging memory technologies can perform a range of in-memory logic and arithmetic operations. In addition, SRAM, Flash and all memristive memories can also be used for MVM operations.
The most important characteristics of a memory device are its read and write times, that is how fast a device can store and retrieve information. Equally important characteristics are the cycling endurance, which refers to the number of times a memory device can be switched from one state to the other, the energy required to store information in a memory cell as well as the size of the memory cell. Table 1 -compares the traditional DRAM, SRAM and NOR Flash with the most popular emerging resistive-memory technologies, such as spin-transfer torque RAM (STT-RAM), phase-change memory (PCM) and resistive RAM (ReRAM).
Table 1 – Comparing different memory technologies. Sources:(B. Li 2019), (Marinella 2013)
Be the first to reply
