[Axelera Metis] APT repositories for Voyager OS
  • October 7, 2025
  • 65 views
Hello everyone,
I’m trying to install some packages using APT with my Axelera Metis Compute Board with Voyager Linux 1. However the /etc/apt/sources.list is empty. What kind of repositories should I use?
Are there any tutorials?
Thanks.
Best regards
Hello ​@HeroGian,
On the Metis Compute Board, it is recommended to install and run the Voyager-SDK within a Docker container. Please refer to the Metis Compute Board User Guide published on our Support Portal for detailed instructions on getting started.
Please note that the Metis Compute Board has a Yocto-based OS, which does not support direct package installation via “apt”. If additional packages are required, please try installing them inside the SDK Docker container environment.
If you are encountering errors with package installations inside the Docker container environment, please share the detailed error log with us.
