Axelera metis m.2 board issue
  • April 22, 2026
  • 62 views
So far we had 7 boards, 5 are fine and working with no issues. But on 1 we get errors when running "axdevice --refresh" which points to some sort of hardware or firmware issue since the others work properly. Another one behaves the same way but sporadically, sometimes it works and sometimes it shows the same errors.
We are connecting the cards into a cm5 i/o board, and are running RPI OS and voyager sdk 1.5.2 inside the ubuntu docker. Below is the ouput:
axdevice --refresh
0001:01:00.0 : Axelera AI Metis AIPU (rev 02)
[libtriton_linux.c:1313] Device communication timed out: device did not respond within 1 seconds. (300)
WARNING: Failed to get valid board type for device metis-1:1:0 got 8
[libtriton_linux.c:1313] Device communication timed out: device did not respond within 1 seconds. (110)
ERROR: Failed to load runtime stage0: /opt/axelera/device-1.5.2-1/omega/bin/start_axelera_runtime_stage0.bin
ERROR: AXR_ERROR_CONNECTION_ERROR: Failed to load runtime stage0: /opt/axelera/device-1.5.2-1/omega/bin/start_axelera_runtime_stage0.bin
Bcver is 7.1
Thank you for your time, If you need any more info please ask.
