HPE ProLiant DL380 Gen11 + Connecting PCIe Axelera Accelerator
Hi team,
We are currently deploying the Axelera Metis PCIe 4-AIPU AI Accelerator Card (AXE-BME20P4) in an HPE ProLiant DL380 Gen11 server as part of a k3s-based AI inference cluster.
The card is physically seated in a PCIe Gen 3.0 x16 slot and Ubuntu Server 24.04 LTS is installed. However, we are facing a challenge with the auxiliary power connection.
The Metis card requires a 2x4 (8-pin) PCIe auxiliary connector, but the HPE DL380 Gen11 uses a proprietary internal power header on the riser side. We have identified HPE part P77896-B21 (DL380 Gen11 2U 8-pin GPU Power Cable Kit) as the likely adapter cable needed.
Before we proceed with the order, we wanted to check with you directly:
1. Have you or any of your customers successfully deployed the Metis PCIe 4-AIPU in an HPE ProLiant DL380 Gen11?
2. Can you confirm that HPE P77896-B21 is the correct cable to connect the Metis card's 2x4 auxiliary power connector to the DL380 Gen11's internal power distribution?
3. Are there any other HPE DL380 Gen11-specific installation notes we should be aware of?
  • August 21, 2026
Hi there ​@rozero !
Hmm, I’ve not personally seen anyone working with a DL380, in all honesty, but I’ve asked around internally at Axelera to see if anyone’s aware of it 👍I’m always a bit nervous when it comes to power adapers, as they’ll sometimes fit but have an unexpected pin out! 😅
  • August 21, 2026
Hey @rozero, no DL380 here either (my Metis is the M.2, running in a desktop), so take this as generic server tinkering rather than hands-on with that exact box.
On the pinout worry @Spanner raised: the trap with 8-pin aux cables is that PCIe and EPS12V use the same Molex Mini-Fit Jr. housing and will physically mate even when wired mirrored. HPE's GPU cable kit should be proper PCIe pinout by design, but since the riser side is proprietary you can't really tell by eye. When the cable arrives, spend five minutes with a multimeter on the card-side connector: a PCIe 8-pin should show the three +12V pins on one row and grounds (plus sense) on the other. If it reads like EPS, stop there.
Also worth checking before you order: on recent ProLiants the GPU aux output on the riser is not always live by default, it can depend on riser population and setup options. Might be worth a quick question to HPE whether that output is actually enabled in your config, otherwise you risk debugging "card not detected" when the real problem is no 12V on the aux.
One thing for later: if the card powers up fine but you get DMA timeouts or flaky PCIe link errors at boot, try disabling ASPM on that root port. Same family of problem as the S3/resume DMA timeout thread here, that one bit me for weeks on AM5:
https://community.axelera.ai/axelera-embedded-3/s3-suspend-resume-permanent-dma-timeout-on-metis-m-2-amd64-desktop-driver-has-no-resume-path-please-fix-or-document-1388
Good luck with the cluster, 4 AIPUs on one node sounds like a fun rig.
