ARM support list
  • December 16, 2024
  • 168 views
hey,
I am an ARM enthusiast and I wanted to check if you have any compatibility list.
Are you supporting NXP and MediaTek?
What about the Broadcom CPU on latest Raspberry Pi?
Best answer by Hermione
Here’s the latest list of M.2 tested Host PCs and the PCIe tested Host PCs and both lists have some Arm hosts. Hope that helps, ​@mark_81.
Thank you!
Axelera CMX
  • December 16, 2024
There is a list of (current) compatible hosts in the Help Center, but I’ll also look at adding that info to the community, probably in Documentation somewhere, as this is likely to be a fairly common question 👍
Thanks ​@mark_81!
  • March 28, 2025
Thank you!
manubot
  • April 16, 2025
In addition to the ones pointed by Radhika, we have also a project using Arduino Portenta X8 which has an NXP iMX8-mini on it. So that ARM-based CPU would also work.
Mediatek we have not tried yet. If you do, let us know!
