Support on security survailance use case using Axelera AI
  • December 17, 2024
  • 134 views
Hi!
I need to set up a real-time security surveillance system to monitor an area using 20 cameras. Using your technology, what is the best solution you would propose, including the components and setup required to make it work efficiently? Additionally, could you let me know how I can purchase the recommended solution?
Kind regards,
G
Axelera CMX
This is an excellent question for ​@jonas_ax!
  • December 19, 2024
Hi GeorgiosS,
Nice to meet you. I am Steven.
To be able to give you a good answers, we would need some more information. E.g.
  • Which network do you want to run?
  • What is the resolution of the camera’s you’re looking to support?
  • Which frame-rate do you want to be able to process (either per-camera or total)
  • What are the latency requirements. Is 1 second between capture and result fine, or do you need real-time solutions?
  • How far will the camera’s be apart?
  • How will you connect the camera’s? A popular way of connecting a camera is using RTSP over ethernet. You may need some sort of network switch to be able to connect them all to a pc or server.
Please have a look at our evaluation kits and browse around. Each one of these should be able to handle 20 full HD camera streams without problems.
You can also have a look at our ai in security surveillance page to draw some inspiration.
