Support to zsh
mcunha
I am using zsh as my shell application. While activating the environment, I encountered this error:
  voyager-sdk git:(release/v1.3) ✗ source venv/bin/activate
_AX_set_env:4: bad substitution
Do you think providing support for shells other than bash would help?
Best answer by emustafa
Hi ​@mcunha
Here is a super unofficial, hacky and totally not tested solution:
Open venv/bin/activate in an editor and adapt the following two functions.
_AX_set_env() {
# Must be called before defining deactivate function
local var="_OLD_ENV_${1}"
local x=
# Check if deactivate function exists (bash/zsh compatible)
local deactivate_exists=0
if [ -n "${BASH:-}" ]; then
type deactivate &>/dev/null && deactivate_exists=1
else
typeset -f deactivate &>/dev/null && deactivate_exists=1
fi
# Indirect variable expansion for bash and zsh
if [ -n "${!1:-}" ] && [ $deactivate_exists -eq 0 ] ; then
eval "${var}=\"${!1}\""
fi
else
# zsh indirect expansion
if [ -n "${(P)1:-}" ] && [ $deactivate_exists -eq 0 ] ; then
eval "${var}=\"${(P)1}\""
fi
fi
# strip escapes from $ expressions and evaluate RHS before assigning to LHS
x=${2//\\\$/\$}
x=`echo $x`
eval "$1=\"$x\""
export "$1"
for _AX_var in "${_AX_envs[@]}"; do
if [[ "$_AX_var" == *=* ]]; then
_AX_set_env "${_AX_var%%=*}" "${_AX_var#*=}"
fi
done
unset _AX_var
_AX_reset_env() {
if [ -n "${!var:-}" ]; then
eval "$1=\"${!var}\""
export "$1"
unset ${var}
else
unset $1
fi
else
if [ -n "${(P)var:-}" ]; then
eval "$1=\"${(P)var}\""
export "$1"
unset ${var}
else
unset $1
fi
fi
  • July 11, 2025
Hey man!
Yeah, that looks like bash-specific syntact that zsh doesn’t support (by default anyway, as far as I know).
I actually think this is the first time I’ve seen it raised, but it’s a really interesting point - support for more terminal options. It’s probably not going to be a huge priority right now, if I’m honest, but I like the idea!
Actually, it might be worth adding it as an idea/feature request in the Launchpad. If it gets plenty of attention, it might gain more traction internally. 👍
emustafa
  • July 11, 2025
Hi ​@mcunha
_AX_set_env() {
local x=
else
fi
fi
else
fi
fi
x=${2//\\\$/\$}
x=`echo $x`
eval "$1=\"$x\""
export "$1"
fi
done
unset _AX_var
_AX_reset_env() {
export "$1"
unset ${var}
else
unset $1
fi
else
export "$1"
unset ${var}
else
unset $1
fi
fi
mcunha
  • July 12, 2025
Hi ​@emustafa ,
This not tested, hacky, super unofficial solution worked perfectly. 😀
Thanks
  • July 14, 2025
Hi ​@mcunha
_AX_set_env() {
local x=
else
fi
fi
else
fi
fi
x=${2//\\\$/\$}
x=`echo $x`
eval "$1=\"$x\""
export "$1"
fi
done
unset _AX_var
_AX_reset_env() {
export "$1"
unset ${var}
else
unset $1
fi
else
export "$1"
unset ${var}
else
unset $1
fi
fi
Wow, nice work dude! 😃 I think that deserves a System Sensei badge 😎
