Yolo11l custom weigts deploy
  • July 7, 2025
  • 53 views
Hi, I’m getting very pool performance on Yolo11l custom weigts after the conversion in onnx.
I’ve used opset 17 and 16, do you have any suggestions?
Thanks.
Best answer by Giodst
I found out that the cause is the dynamic=true parameter of the ultralytics export function, but without it I get this error during compilation:
ERROR   : Traceback (most recent call last):
ERROR   :   File "<frozen compiler.top_level>", line 494, in quantize
ERROR   :   File "<frozen onnx_graph_cleaner.onnx_graph_cleaner>", line 864, in clean
ERROR   :   File "<frozen onnx_graph_cleaner.onnx_graph_cleaner>", line 49, in closure
ERROR   :   File "<frozen onnx_graph_cleaner.onnx_graph_cleaner>", line 80, in closure
ERROR   :   File "<frozen onnx_graph_cleaner.onnx_graph_cleaner>", line 796, in _split_pre_post_processing
ERROR   :   File "<frozen onnx_graph_cleaner.onnx_extractor>", line 212, in extract
ERROR   :   File "/home/aetina/.cache/axelera/venvs/ac95b872/lib/python3.10/site-packages/onnx/checker.py", line 179, in check_model
ERROR   :     C.check_model(
ERROR   : onnx.onnx_cpp2py_export.checker.ValidationError: Field 'shape' of 'type' is required but missing.
ERROR   :
ERROR   : The above exception was the direct cause of the following exception:
ERROR   :
ERROR   :   File "voyager-sdk/axelera/app/compile.py", line 456, in compile
ERROR   :     the_manifest = top_level.compile(model, compilation_cfg, output_path)
ERROR   :   File "<frozen compiler.utils.error_report>", line 65, in wrapper
ERROR   :   File "<frozen compiler.top_level>", line 831, in compile
ERROR   :   File "<frozen compiler.top_level>", line 496, in quantize
ERROR   : axelera.compiler.exceptions.ONNXGraphCleanerError: Cleaning graph with ONNXGraphCleaner failed:
ERROR   : Field 'shape' of 'type' is required but missing.
ERROR   : Cleaning graph with ONNXGraphCleaner failed:
  • Lieutenant Commander
  • July 7, 2025
ERROR   :
ERROR   :
