Consider hosting the Wingman code on Github
  • Oct 6, 2026 4:16 PM UTC
  • 52 views
I have filed a few issues on Github. The first one is a week old and hasn’t been looked at. I’ve uncovered a few plumbing issues today as well.
Most of what Wingman ships is already readable: the VS Code base and the bundled Codex engine are open source, and the wingman-dashboard extension ships as unminified JavaScript. Publishing the source here would cost little and would help in a few concrete ways:
  • Contributions instead of reports. Several of the open issues are one-line fixes. With the source here, they could arrive as pull requests.
  • Packaging for more distributions. Packagers for Arch, Fedora and others could build Wingman properly instead of repackaging the .deb.
  • Trust. For a tool that runs an agent with shell access on developers' machines, being able to review the code is a strong selling point, especially for a European company competing with much larger vendors.
If publishing the whole codebase isn't an option, opening just the Linux launcher (/usr/bin/wingman) and the packaging scripts would already cover most of the fixes above.
Either way, it would help to know whether issues here are monitored. If not, could the README point to the preferred channel?
https://github.com/axelera-ai-hub/wingman/issues
Abhilash
  • Oct 7, 2026 1:17 PM UTC
Hi jclsn, thank you for these.
Yes, a terminal version of Axelera Wingman is planned. If you need a terminal workflow on a server before then, the hosted Wingman MCP server works with MCP clients that support remote servers and MCP sign-in, such as Claude Code, Codex or Gemini CLI. It brings the Wingman knowledge and project tools into that CLI, without every feature of the app. On the first tool call it asks you to sign in with your Wingman account in a browser. The docs page [Connect any MCP client](https://app.wingman.axelera.ai/docs/mcp-skills/connect-any-client) has the setup for each one. The engine bundled in the app is pinned to the editor and is not supported on its own.
I will post here when a terminal build is ready to try.
The launcher and packaging bugs are fixed in v1.7.52
- `wingman --version` and `--help` answer without a display. With neither `DISPLAY` nor `WAYLAND_DISPLAY`, a launch exits with a message instead of segfaulting. A case loop scans the options and stops at `--`, because the `getopts` builtin does not handle long options.
- The package has one Electron binary at `/usr/share/wingman/wingman`. `Axelera Wingman` beside it is a symlink.
- The launcher no longer uses `pgrep`. It asks the session bus whether a Secret Service such as KWallet or gnome-keyring owns `org.freedesktop.secrets` or can be started for it, and leaves the session alone when one answers. It runs `gnome-keyring-daemon --start --components=secrets` only when there is no provider or no session bus, and that call attaches to a running daemon instead of spawning another.
- X11 is no longer forced. Electron selects the platform automatically, and the launcher pins Wayland when a Wayland socket exists but there is no X display. You can pin either platform with `WINGMAN_OZONE_PLATFORM=x11` or `WINGMAN_OZONE_PLATFORM=wayland`.
I checked these changes in the published amd64 package. I have not yet tested native Wayland on a real compositor or a real KDE session; if you run either, a report from you would be very welcome. The app's "What's new" for 1.7.52 lists the changes.
Your first issue waited eight days for a reply. That was on us. The public distribution repository was not considered for feedback. The feedback channel is built in Wingman. From today we watch Github issues. The README now has a Support section naming GitHub Issues and this community.
You are right that Wingman builds on VS Code and the Codex engine, as all other VS Code-based AI editors build on VS Code and that is the floor. What we add sits on top. Alongside the Axelera AI models, you can use GPT, Claude and Gemini with your own keys.
On the source: Wingman's source stays closed. Publishing just the launcher and packaging scripts would cover most of the fixes you listed. I will raise that narrower request with the team this week.
On trust: each release carries a SHA256SUMS file signed with the Axelera key, the public key to check it, and an SPDX SBOM. The agent's shell uses the `workspace-write` sandbox by default, and full access is an explicit mode.
Keep them coming.
Abhilash
Axelera Wingman team
  • Oct 8, 2026 5:01 PM UTC
​@Abhilash Thanks for looking into it! In the end it is of course up to you if you open the source.
I btw don’t actually own a card yet. I was merely looking at the setup, because I considering buying one. I think the setup is not yet there for me.
I personally think Wingman is a bit large. Even without the duplicate binary, it is still around ~800 MB due to the bundled Codex and VSCode. I would prefer a slimmer version here, but I understand that most users would probably prefer a GUI.
Looking forward to seeing the progress!
