Voyager Wingman login
Hi Axelera Community
After some prompts in the Axelera Wingman browser version, I wanted to test on the Metis M.2 hardware installed in an IPC on my desk.
After downloading and installing the Linux amd64 client (version 1.4.0), logging in is required. Where the browser version supports logging in with an Axelera Community account or with Axelera SSO, the desktop client only seems to show the Axelera SSO option, which is not possible for me of course.
Am I missing anything here? How should a non Axelera employee login to the desktop app?
Kind regards
Robbe
Best answer by Robbe Goethals
Solved with v1.4.1, thanks ​@Abhilash 👍
Abhilash
  • July 17, 2026
Hi Robbe
It means your Axelera account, which maybe your Axelera community account or Axelera webshop etc.
If you are logged in into Axelera community on your browser, clicking SSO login button would log you into the app in one click.
Please feel free to DM if you still see an issue
Quickly replying here for others with the same issue. ​@Abhilash is looking into it with some info I sent him in DM, we’ll reply here when there’s a workaround or fix.
  • July 17, 2026
Adding my case here too, same problem on the desktop app (v1.4.0, Linux). SSO fails even with an active Community session in browser beforehand, tried it with a couple of different accounts.
Is there any obvious solution, I am also having issues in logging into the desktop app
It is saying -
The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account.
Abhilash
  • July 17, 2026
Thanks Robbe! that was a swift check. Kudos!
