Metis M.2 with a 4.19 kernel
  • May 6, 2026 1:40 PM UTC
  • 44 views
I would like to use the Metis M.2 in an embedded system running Open Embedded with a 4.19 kernel. (It doesn’t have the “modern” /dev/dma_heap/ interface, it uses /dev/ion). I have the driver installed in the host, and when I use the SDK in a Ubuntu 22.04 docker container I get this error:
[libaxldev_linux.c:394] No dmabuf driver found
[ERROR][axeShareMemAllocMap]: Fail to alloc dmabuf
[ERROR][axeMemAllocShared]: Share memory allocate mao failed: 0x70010001.
  what():  axr_load_model_instance failed : Failed to create executor for model: kernel_function_batched
Aborted
Can the driver/library be compiled to use ION instead of dmabuf?
  • May 6, 2026 3:38 PM UTC
Hi ​@STU940652 !
Hmm, I’m not that hot with ION but don’t think so. The error is from libaxldev, which is part of the axelera_runtime package, distributed as pre-built binaries. It's hardcoded against the modern DMA-BUF heaps interface (/dev/dma_heap/), so even with ION present in your kernel, I don’t think it’d find what it's looking for?
The minimum kernel where this interface exists is 5.6, and you'll need CONFIG_DMABUF_HEAPS, CONFIG_DMABUF_HEAPS_SYSTEM, CONFIG_DMABUF_HEAPS_CMA, CONFIG_SYNC_FILE and CONFIG_SW_SYNC enabled. The Jetson Orin bring-up post lists the full set, if that’s useful?
I’d be interested to hear how this goes though!
