Can not install ©Card through voyager SDK
  • March 31, 2026
  • 11 replies
  • 202 views
I'm trying to install a Metis AI Accelerator M.2 Card using the Voyager SDK install.sh script. I successfully installed the card on my setup.
Current environment:
  • Debian 12 with a custom kernel
  • Motherboard: Advantech SOM-DB5920
  • x4 PCIe to M.2 PCIe Adapter (StarTech.com)
The Metis card is correctly detected through the PCIe adapter:
lspci | grep Metis
02:00.0 Processing accelerators: Axelera AI Metis AIPU (rev 02)
When i verify the installation using axdevice command i have this issue:
axdevice -v
INFO: Found PCI device: 02:00.0 Processing accelerators: Axelera AI Metis AIPU (rev 02)
INFO: Found AIPU driver: metis                 110592  0
[libtriton_linux.c:1313] Device communication timed out: device did not respond within 1 seconds. (4294967295)
WARNING: Failed to get valid board type for device metis-0:2:0 got 8
INFO: Ignoring device 0(metis-0:2:0) as it has not returned a valid board type: 8
INFO: Using device metis-0:2:0
Device 0: metis-0:2:0 board_type=unknown (not responding)
I found a ticket with the same symptoms: Can not Enable Update. I followed the steps described there but the issue persists and I still fail to load the firmware.
Please find the full diagnostic
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 84
Region 0: Memory at 82010000 (64-bit, non-prefetchable) [size=4K]
Region 2: Memory at 80000000 (32-bit, non-prefetchable) [size=32M]
Expansion ROM at 82000000 [disabled] [size=64K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2- AuxCurrent=375mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable+ Count=32/32 Maskable+ 64bit+
Address: 00000000fee00c18 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset- SlotPowerLimit 25W
DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <4us, L1 <16us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x4
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp- 10BitTagReq- OBFF Via message, ExtFmt- EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 260ms to 900ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP+ SDES- TLP+ FCP+ CmpltTO+ CmpltAbrt+ UnxCmplt+ RxOF+ MalfTLP+ ECRC+ UnsupReq+ ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
MultHdrRecCap+ MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [148 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn- PerformEqu-
LaneErrStat: 0
Capabilities: [168 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [170 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
T_CommonMode=0us LTR1.2_Threshold=0ns
L1SubCtl2: T_PwrOn=10us
Capabilities: [180 v1] Vendor Specific Information: ID=0006 Rev=0 Len=018 <?>
Kernel driver in use: axl
Kernel modules: metis
00000000: 8806 0000 0000 0000 0400 0400 0100 0000 ................
00000010: 0000 0000 0000 0000 2184 0000 2184 0000 ........!...!...
00000020: 0000 0000 0000 0000 0000 0000 0100 0000 ................
00000030: 0000 0000 0000 0000 2184 0000 2184 0000 ........!...!...
ERROR: Failed to load runtime stage0: /opt/axelera/device-1.5.3-1/omega/bin/start_axelera_runtime_stage0.bin
ERROR: AXR_ERROR_CONNECTION_ERROR: Failed to load runtime stage0: /opt/axelera/device-1.5.3-1/omega/bin/start_axelera_runtime_stage0.bin
0000:02:00.0 : Axelera AI Metis AIPU (rev 02)
[ 0.144885] [mem 0x80000000-0xdfffffff] available for PCI devices
[ 1.794188] ACPI: bus type PCI registered
[ 1.795075] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.796189] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 1.797076] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 1.799765] PCI: Using configuration type 1 for base access
[ 1.964075] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC used to handle transactions
[ 1.970077] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 1.991481] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 1.994605] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[ 1.996128] PCI host bridge to bus 0000:00
[ 1.997073] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 1.998072] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 1.999072] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 2.000072] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[ 2.001072] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ 2.002072] pci_bus 0000:00: root bus resource [mem 0x880000000-0x7fffffffff window]
[ 2.003072] pci_bus 0000:00: root bus resource [mem 0xfe010000-0xfe010fff window]
[ 2.004072] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfa0fffff window]
[ 2.005072] pci_bus 0000:00: root bus resource [mem 0xfb000000-0xfb7fffff window]
[ 2.006072] pci_bus 0000:00: root bus resource [mem 0xfa100000-0xfa1007ff window]
[ 2.007072] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.008214] pci 0000:00:00.0: [8086:1980] type 00 class 0x060000
[ 2.009578] pci 0000:00:04.0: [8086:19a1] type 00 class 0x060000
[ 2.010543] pci 0000:00:05.0: [8086:19a2] type 00 class 0x080700
[ 2.011182] pci 0000:00:05.0: PME# supported from D0 D3hot D3cold
[ 2.012493] pci 0000:00:06.0: [8086:19a3] type 01 class 0x060400
[ 2.013143] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 2.014488] pci 0000:00:09.0: [8086:19a4] type 01 class 0x060400
[ 2.015086] pci 0000:00:09.0: reg 0x10: [mem 0x777ff60000-0x777ff7ffff 64bit]
[ 2.016140] pci 0000:00:09.0: PME# supported from D0 D3hot D3cold
[ 2.017534] pci 0000:00:0b.0: [8086:19a6] type 01 class 0x060400
[ 2.018085] pci 0000:00:0b.0: reg 0x10: [mem 0x777ff40000-0x777ff5ffff 64bit]
[ 2.019141] pci 0000:00:0b.0: PME# supported from D0 D3hot D3cold
[ 2.020526] pci 0000:00:0c.0: [8086:19a7] type 01 class 0x060400
[ 2.021085] pci 0000:00:0c.0: reg 0x10: [mem 0x777ff20000-0x777ff3ffff 64bit]
[ 2.022140] pci 0000:00:0c.0: PME# supported from D0 D3hot D3cold
[ 2.023527] pci 0000:00:0e.0: [8086:19a8] type 01 class 0x060400
[ 2.024085] pci 0000:00:0e.0: reg 0x10: [mem 0x777ff00000-0x777ff1ffff 64bit]
[ 2.025140] pci 0000:00:0e.0: PME# supported from D0 D3hot D3cold
[ 2.026522] pci 0000:00:12.0: [8086:19ac] type 00 class 0x088000
[ 2.027090] pci 0000:00:12.0: reg 0x10: [mem 0x777ff94000-0x777ff943ff 64bit]
[ 2.028547] pci 0000:00:13.0: [8086:19b2] type 00 class 0x010601
[ 2.029085] pci 0000:00:13.0: reg 0x10: [mem 0xdee04000-0xdee05fff]
[ 2.030078] pci 0000:00:13.0: reg 0x14: [mem 0xdee07000-0xdee070ff]
[ 2.031078] pci 0000:00:13.0: reg 0x18: [io 0xe050-0xe057]
[ 2.032078] pci 0000:00:13.0: reg 0x1c: [io 0xe040-0xe043]
[ 2.033078] pci 0000:00:13.0: reg 0x20: [io 0xe020-0xe03f]
[ 2.034078] pci 0000:00:13.0: reg 0x24: [mem 0xdee06000-0xdee067ff]
[ 2.035120] pci 0000:00:13.0: PME# supported from D3hot
[ 2.036459] pci 0000:00:15.0: [8086:19d0] type 00 class 0x0c0330
[ 2.037088] pci 0000:00:15.0: reg 0x10: [mem 0x777ff80000-0x777ff8ffff 64bit]
[ 2.038134] pci 0000:00:15.0: PME# supported from D3hot D3cold
[ 2.039549] pci 0000:00:16.0: [8086:19d1] type 01 class 0x060400
[ 2.040137] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 2.041472] pci 0000:00:17.0: [8086:19d2] type 01 class 0x060400
[ 2.042137] pci 0000:00:17.0: PME# supported from D0 D3hot D3cold
[ 2.043488] pci 0000:00:18.0: [8086:19d3] type 00 class 0x078000
[ 2.044096] pci 0000:00:18.0: reg 0x10: [mem 0x777ff93000-0x777ff93fff 64bit]
[ 2.045164] pci 0000:00:18.0: PME# supported from D3hot
[ 2.046492] pci 0000:00:1c.0: [8086:19db] type 00 class 0x080501
[ 2.047090] pci 0000:00:1c.0: reg 0x10: [mem 0x777ff92000-0x777ff92fff 64bit]
[ 2.048083] pci 0000:00:1c.0: reg 0x18: [mem 0x777ff91000-0x777ff91fff 64bit]
[ 2.049511] pci 0000:00:1f.0: [8086:19dc] type 00 class 0x060100
[ 2.050532] pci 0000:00:1f.2: [8086:19de] type 00 class 0x058000
[ 2.051083] pci 0000:00:1f.2: reg 0x10: [mem 0xdee00000-0xdee03fff]
[ 2.052470] pci 0000:00:1f.4: [8086:19df] type 00 class 0x0c0500
[ 2.053089] pci 0000:00:1f.4: reg 0x10: [mem 0x777ff90000-0x777ff900ff 64bit]
[ 2.054091] pci 0000:00:1f.4: reg 0x20: [io 0xe000-0xe01f]
[ 2.055463] pci 0000:00:1f.5: [8086:19e0] type 00 class 0x0c8000
[ 2.056085] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 2.057346] pci 0000:01:00.0: [8086:19e2] type 00 class 0x0b4000
[ 2.058095] pci 0000:01:00.0: reg 0x18: [mem 0xded40000-0xded7ffff 64bit]
[ 2.059081] pci 0000:01:00.0: reg 0x20: [mem 0xded00000-0xded3ffff 64bit]
[ 2.060159] pci 0000:01:00.0: reg 0x164: [mem 0xded90000-0xded90fff 64bit]
[ 2.061073] pci 0000:01:00.0: VF(n) BAR0 space: [mem 0xded90000-0xded9ffff 64bit] (contains BAR0 for 16 VFs)
[ 2.062078] pci 0000:01:00.0: reg 0x16c: [mem 0xded80000-0xded80fff 64bit]
[ 2.063072] pci 0000:01:00.0: VF(n) BAR2 space: [mem 0xded80000-0xded8ffff 64bit] (contains BAR2 for 16 VFs)
[ 2.064134] pci 0000:01:00.0: 2.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x1 link at 0000:00:06.0 (capable of 64.000 Gb/s with 5.0 GT/s PCIe x16 link)
[ 2.065189] pci 0000:00:06.0: PCI bridge to [bus 01]
[ 2.066076] pci 0000:00:06.0: bridge window [mem 0xded00000-0xdedfffff]
[ 2.067179] pci 0000:02:00.0: [1f9d:1100] type 00 class 0x120000
[ 2.068087] pci 0000:02:00.0: reg 0x10: [mem 0xdc010000-0xdc010fff 64bit]
[ 2.069077] pci 0000:02:00.0: reg 0x18: [mem 0xda000000-0xdbffffff]
[ 2.070089] pci 0000:02:00.0: reg 0x30: [mem 0xdc000000-0xdc00ffff pref]
[ 2.071133] pci 0000:02:00.0: supports D1
[ 2.072072] pci 0000:02:00.0: PME# supported from D0 D1 D3hot
[ 2.073211] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 2.074076] pci 0000:00:09.0: bridge window [mem 0xda000000-0xdc0fffff]
[ 2.075164] pci 0000:03:00.0: [1b4b:9230] type 00 class 0x010601
[ 2.076086] pci 0000:03:00.0: reg 0x10: [io 0xd050-0xd057]
[ 2.077079] pci 0000:03:00.0: reg 0x14: [io 0xd040-0xd043]
[ 2.078079] pci 0000:03:00.0: reg 0x18: [io 0xd030-0xd037]
[ 2.079079] pci 0000:03:00.0: reg 0x1c: [io 0xd020-0xd023]
[ 2.080079] pci 0000:03:00.0: reg 0x20: [io 0xd000-0xd01f]
[ 2.081079] pci 0000:03:00.0: reg 0x24: [mem 0xdec10000-0xdec107ff]
[ 2.082079] pci 0000:03:00.0: reg 0x30: [mem 0xdec00000-0xdec0ffff pref]
[ 2.083092] pci 0000:03:00.0: Enabling fixed DMA alias to 00.1
[ 2.084109] pci 0000:03:00.0: PME# supported from D3hot
[ 2.085101] pci 0000:03:00.0: 4.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x1 link at 0000:00:0b.0 (capable of 8.000 Gb/s with 5.0 GT/s PCIe x2 link)
[ 2.086172] pci 0000:00:0b.0: PCI bridge to [bus 03]
[ 2.087074] pci 0000:00:0b.0: bridge window [io 0xd000-0xdfff]
[ 2.088073] pci 0000:00:0b.0: bridge window [mem 0xdec00000-0xdecfffff]
[ 2.089191] pci 0000:04:00.0: [8086:1533] type 00 class 0x020000
[ 2.090095] pci 0000:04:00.0: reg 0x10: [mem 0xdeb00000-0xdeb7ffff]
[ 2.091096] pci 0000:04:00.0: reg 0x18: [io 0xc000-0xc01f]
[ 2.092084] pci 0000:04:00.0: reg 0x1c: [mem 0xdeb80000-0xdeb83fff]
[ 2.093208] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 2.094250] pci 0000:00:0c.0: PCI bridge to [bus 04]
[ 2.095074] pci 0000:00:0c.0: bridge window [io 0xc000-0xcfff]
[ 2.096073] pci 0000:00:0c.0: bridge window [mem 0xdeb00000-0xdebfffff]
[ 2.097181] pci 0000:05:00.0: [10de:25fb] type 00 class 0x030200
[ 2.098085] pci 0000:05:00.0: reg 0x10: [mem 0xdd000000-0xddffffff]
[ 2.099082] pci 0000:05:00.0: reg 0x14: [mem 0x7600000000-0x76ffffffff 64bit pref]
[ 2.100082] pci 0000:05:00.0: reg 0x1c: [mem 0x7700000000-0x7701ffffff 64bit pref]
[ 2.101078] pci 0000:05:00.0: reg 0x24: [io 0xb000-0xb07f]
[ 2.102078] pci 0000:05:00.0: reg 0x30: [mem 0xde000000-0xde07ffff pref]
[ 2.103143] pci 0000:05:00.0: PME# supported from D0 D3hot
[ 2.104147] pci 0000:05:00.0: 31.504 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x4 link at 0000:00:0e.0 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[ 2.105172] pci 0000:00:0e.0: PCI bridge to [bus 05]
[ 2.106074] pci 0000:00:0e.0: bridge window [io 0xb000-0xbfff]
[ 2.107074] pci 0000:00:0e.0: bridge window [mem 0xdd000000-0xde0fffff]
[ 2.108075] pci 0000:00:0e.0: bridge window [mem 0x7600000000-0x7701ffffff 64bit pref]
[ 2.109207] pci 0000:06:00.0: [8086:15c8] type 00 class 0x020000
[ 2.110089] pci 0000:06:00.0: reg 0x10: [mem 0x7702a00000-0x7702bfffff 64bit pref]
[ 2.111095] pci 0000:06:00.0: reg 0x20: [mem 0x7702c04000-0x7702c07fff 64bit pref]
[ 2.112079] pci 0000:06:00.0: reg 0x30: [mem 0xde680000-0xde6fffff pref]
[ 2.113141] pci 0000:06:00.0: PME# supported from D0 D3hot D3cold
[ 2.114101] pci 0000:06:00.0: reg 0x184: [mem 0xdea00000-0xdea03fff 64bit]
[ 2.115072] pci 0000:06:00.0: VF(n) BAR0 space: [mem 0xdea00000-0xdeafffff 64bit] (contains BAR0 for 64 VFs)
[ 2.116086] pci 0000:06:00.0: reg 0x190: [mem 0xde900000-0xde903fff 64bit]
[ 2.117072] pci 0000:06:00.0: VF(n) BAR3 space: [mem 0xde900000-0xde9fffff 64bit] (contains BAR3 for 64 VFs)
[ 2.118429] pci 0000:06:00.1: [8086:15c8] type 00 class 0x020000
[ 2.119090] pci 0000:06:00.1: reg 0x10: [mem 0x7702800000-0x77029fffff 64bit pref]
[ 2.120095] pci 0000:06:00.1: reg 0x20: [mem 0x7702c00000-0x7702c03fff 64bit pref]
[ 2.121079] pci 0000:06:00.1: reg 0x30: [mem 0xde600000-0xde67ffff pref]
[ 2.122141] pci 0000:06:00.1: PME# supported from D0 D3hot D3cold
[ 2.123096] pci 0000:06:00.1: reg 0x184: [mem 0xde800000-0xde803fff 64bit]
[ 2.124072] pci 0000:06:00.1: VF(n) BAR0 space: [mem 0xde800000-0xde8fffff 64bit] (contains BAR0 for 64 VFs)
[ 2.125086] pci 0000:06:00.1: reg 0x190: [mem 0xde700000-0xde703fff 64bit]
[ 2.126072] pci 0000:06:00.1: VF(n) BAR3 space: [mem 0xde700000-0xde7fffff 64bit] (contains BAR3 for 64 VFs)
[ 2.127415] pci 0000:00:16.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 2.128095] pci 0000:00:16.0: PCI bridge to [bus 06-07]
[ 2.129075] pci 0000:00:16.0: bridge window [mem 0xde600000-0xdeafffff]
[ 2.130074] pci 0000:00:16.0: bridge window [mem 0x7702800000-0x7702cfffff 64bit pref]
[ 2.131201] pci 0000:08:00.0: [8086:15c8] type 00 class 0x020000
[ 2.132089] pci 0000:08:00.0: reg 0x10: [mem 0x7702400000-0x77025fffff 64bit pref]
[ 2.133095] pci 0000:08:00.0: reg 0x20: [mem 0x7702604000-0x7702607fff 64bit pref]
[ 2.134079] pci 0000:08:00.0: reg 0x30: [mem 0xde180000-0xde1fffff pref]
[ 2.135141] pci 0000:08:00.0: PME# supported from D0 D3hot D3cold
[ 2.136101] pci 0000:08:00.0: reg 0x184: [mem 0xde500000-0xde503fff 64bit]
[ 2.137072] pci 0000:08:00.0: VF(n) BAR0 space: [mem 0xde500000-0xde5fffff 64bit] (contains BAR0 for 64 VFs)
[ 2.138086] pci 0000:08:00.0: reg 0x190: [mem 0xde400000-0xde403fff 64bit]
[ 2.139072] pci 0000:08:00.0: VF(n) BAR3 space: [mem 0xde400000-0xde4fffff 64bit] (contains BAR3 for 64 VFs)
[ 2.140438] pci 0000:08:00.1: [8086:15c8] type 00 class 0x020000
[ 2.141089] pci 0000:08:00.1: reg 0x10: [mem 0x7702200000-0x77023fffff 64bit pref]
[ 2.142095] pci 0000:08:00.1: reg 0x20: [mem 0x7702600000-0x7702603fff 64bit pref]
[ 2.143079] pci 0000:08:00.1: reg 0x30: [mem 0xde100000-0xde17ffff pref]
[ 2.144141] pci 0000:08:00.1: PME# supported from D0 D3hot D3cold
[ 2.145096] pci 0000:08:00.1: reg 0x184: [mem 0xde300000-0xde303fff 64bit]
[ 2.146085] pci 0000:08:00.1: VF(n) BAR0 space: [mem 0xde300000-0xde3fffff 64bit] (contains BAR0 for 64 VFs)
[ 2.147087] pci 0000:08:00.1: reg 0x190: [mem 0xde200000-0xde203fff 64bit]
[ 2.148072] pci 0000:08:00.1: VF(n) BAR3 space: [mem 0xde200000-0xde2fffff 64bit] (contains BAR3 for 64 VFs)
[ 2.149403] pci 0000:00:17.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 2.150095] pci 0000:00:17.0: PCI bridge to [bus 08-09]
[ 2.151075] pci 0000:00:17.0: bridge window [mem 0xde100000-0xde5fffff]
[ 2.152074] pci 0000:00:17.0: bridge window [mem 0x7702200000-0x77026fffff 64bit pref]
[ 2.153412] ACPI: PCI: Interrupt link LNKA configured for IRQ 11
[ 2.154254] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[ 2.155253] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[ 2.156251] ACPI: PCI: Interrupt link LNKD configured for IRQ 7
[ 2.157252] ACPI: PCI: Interrupt link LNKE configured for IRQ 10
[ 2.158251] ACPI: PCI: Interrupt link LNKF configured for IRQ 14
[ 2.159252] ACPI: PCI: Interrupt link LNKG configured for IRQ 15
[ 2.160251] ACPI: PCI: Interrupt link LNKH configured for IRQ 15
[ 2.167073] ACPI: \_SB_.PCI0.SBRG.EC0_: Boot DSDT EC initialization complete
[ 2.168073] ACPI: \_SB_.PCI0.SBRG.EC0_: EC: Used to handle transactions and events
[ 2.182099] PCI: Using ACPI for IRQ routing
[ 2.191674] PCI: pci_cache_line_size set to 64 bytes
[ 2.446127] pci 0000:00:06.0: PCI bridge to [bus 01]
[ 2.451126] pci 0000:00:06.0: bridge window [mem 0xded00000-0xdedfffff]
[ 2.457952] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 2.462947] pci 0000:00:09.0: bridge window [mem 0xda000000-0xdc0fffff]
[ 2.469775] pci 0000:00:0b.0: PCI bridge to [bus 03]
[ 2.474773] pci 0000:00:0b.0: bridge window [io 0xd000-0xdfff]
[ 2.480902] pci 0000:00:0b.0: bridge window [mem 0xdec00000-0xdecfffff]
[ 2.487729] pci 0000:00:0c.0: PCI bridge to [bus 04]
[ 2.492723] pci 0000:00:0c.0: bridge window [io 0xc000-0xcfff]
[ 2.498851] pci 0000:00:0c.0: bridge window [mem 0xdeb00000-0xdebfffff]
[ 2.505678] pci 0000:00:0e.0: PCI bridge to [bus 05]
[ 2.510672] pci 0000:00:0e.0: bridge window [io 0xb000-0xbfff]
[ 2.516797] pci 0000:00:0e.0: bridge window [mem 0xdd000000-0xde0fffff]
[ 2.523619] pci 0000:00:0e.0: bridge window [mem 0x7600000000-0x7701ffffff 64bit pref]
[ 2.531752] pci 0000:00:16.0: PCI bridge to [bus 06-07]
[ 2.537006] pci 0000:00:16.0: bridge window [mem 0xde600000-0xdeafffff]
[ 2.543829] pci 0000:00:16.0: bridge window [mem 0x7702800000-0x7702cfffff 64bit pref]
[ 2.551961] pci 0000:00:17.0: PCI bridge to [bus 08-09]
[ 2.557216] pci 0000:00:17.0: bridge window [mem 0xde100000-0xde5fffff]
[ 2.564040] pci 0000:00:17.0: bridge window [mem 0x7702200000-0x77026fffff 64bit pref]
[ 2.572172] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 2.578391] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 2.584604] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 2.591512] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff window]
[ 2.598422] pci_bus 0000:00: resource 8 [mem 0x80000000-0xdfffffff window]
[ 2.605334] pci_bus 0000:00: resource 9 [mem 0x880000000-0x7fffffffff window]
[ 2.612505] pci_bus 0000:00: resource 10 [mem 0xfe010000-0xfe010fff window]
[ 2.619502] pci_bus 0000:00: resource 11 [mem 0xfa000000-0xfa0fffff window]
[ 2.626498] pci_bus 0000:00: resource 12 [mem 0xfb000000-0xfb7fffff window]
[ 2.633497] pci_bus 0000:00: resource 13 [mem 0xfa100000-0xfa1007ff window]
[ 2.640494] pci_bus 0000:01: resource 1 [mem 0xded00000-0xdedfffff]
[ 2.646793] pci_bus 0000:02: resource 1 [mem 0xda000000-0xdc0fffff]
[ 2.653093] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 2.658702] pci_bus 0000:03: resource 1 [mem 0xdec00000-0xdecfffff]
[ 2.665002] pci_bus 0000:04: resource 0 [io 0xc000-0xcfff]
[ 2.670605] pci_bus 0000:04: resource 1 [mem 0xdeb00000-0xdebfffff]
[ 2.676907] pci_bus 0000:05: resource 0 [io 0xb000-0xbfff]
[ 2.682513] pci_bus 0000:05: resource 1 [mem 0xdd000000-0xde0fffff]
[ 2.688811] pci_bus 0000:05: resource 2 [mem 0x7600000000-0x7701ffffff 64bit pref]
[ 2.696416] pci_bus 0000:06: resource 1 [mem 0xde600000-0xdeafffff]
[ 2.702716] pci_bus 0000:06: resource 2 [mem 0x7702800000-0x7702cfffff 64bit pref]
[ 2.710323] pci_bus 0000:08: resource 1 [mem 0xde100000-0xde5fffff]
[ 2.716622] pci_bus 0000:08: resource 2 [mem 0x7702200000-0x77026fffff 64bit pref]
[ 2.724863] PCI: CLS 64 bytes, default 64
[ 2.728974] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 2.880127] pcieport 0000:00:05.0: PME: Signaling with IRQ 25
[ 2.886095] pcieport 0000:00:05.0: AER: enabled with IRQ 25
[ 2.892031] pcieport 0000:00:06.0: PME: Signaling with IRQ 26
[ 2.897979] pcieport 0000:00:06.0: AER: enabled with IRQ 26
[ 2.903868] pcieport 0000:00:09.0: PME: Signaling with IRQ 27
[ 2.909786] pcieport 0000:00:09.0: AER: enabled with IRQ 27
[ 2.915512] pcieport 0000:00:09.0: DPC: enabled with IRQ 27
[ 2.921119] pcieport 0000:00:09.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 2.934323] pcieport 0000:00:0b.0: PME: Signaling with IRQ 28
[ 2.940249] pcieport 0000:00:0b.0: AER: enabled with IRQ 28
[ 2.945969] pcieport 0000:00:0b.0: DPC: enabled with IRQ 28
[ 2.951578] pcieport 0000:00:0b.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 2.964749] pcieport 0000:00:0c.0: PME: Signaling with IRQ 29
[ 2.970674] pcieport 0000:00:0c.0: AER: enabled with IRQ 29
[ 2.976412] pcieport 0000:00:0c.0: DPC: enabled with IRQ 29
[ 2.982023] pcieport 0000:00:0c.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 2.995212] pcieport 0000:00:0e.0: PME: Signaling with IRQ 30
[ 3.001147] pcieport 0000:00:0e.0: AER: enabled with IRQ 30
[ 3.006873] pcieport 0000:00:0e.0: DPC: enabled with IRQ 30
[ 3.012482] pcieport 0000:00:0e.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 3.025652] pcieport 0000:00:16.0: PME: Signaling with IRQ 31
[ 3.031584] pcieport 0000:00:16.0: AER: enabled with IRQ 31
[ 3.037455] pcieport 0000:00:17.0: PME: Signaling with IRQ 32
[ 3.043367] pcieport 0000:00:17.0: AER: enabled with IRQ 32
[ 3.476277] igb 0000:04:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 74:fe:48:93:00:32
[ 3.496300] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver
[ 12.657868] ixgbevf: Intel(R) 10 Gigabit PCI Express Virtual Function Network Driver
[ 12.688124] ehci-pci: EHCI PCI platform driver
[ 12.704109] ohci-pci: OHCI PCI platform driver
[ 12.896116] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 12.955684] sdhci-pci 0000:00:1c.0: SDHCI controller found [8086:19db] (rev 11)
[ 12.963710] mmc0: SDHCI controller on PCI [0000:00:1c.0] using ADMA 64-bit
[ 13.800954] pci_bus 0000:06: hash matches
[ 52.664252] metis: loading out-of-tree module taints kernel.
[ 52.671417] metis: module verification failed: signature and/or required key missing - tainting kernel
[ 52.682907] pci 0000:02:00.0: Found target device: AXLAIPU_OMEGA_DEVICE_ID
[ 52.690328] pci 0000:02:00.0: Found target device: 0000:02:00.0
[ 52.697664] pcieport 0000:00:09.0: Found bridge device: 0000:00:09.0
[ 52.705450] pcieport 0000:00:09.0: Bridge window: [mem 0xda000000-0xdc0fffff]
[ 52.713919] pcieport 0000:00:09.0: Decoded memory behind bridge: da000000-dc0fffff
[ 52.721532] pcieport 0000:00:09.0: Memory behind bridge is insufficient. Proceeding with reset.
[ 52.721535] pcieport 0000:00:09.0: Removing bridge device: 0000:00:09.0
[ 52.722235] pci_bus 0000:02: busn_res: [bus 02] is released
[ 52.743564] pci 0000:00:09.0: [8086:19a4] type 01 class 0x060400
[ 52.750006] pci 0000:00:09.0: reg 0x10: [mem 0x777ff60000-0x777ff7ffff 64bit]
[ 52.758637] pci 0000:00:09.0: PME# supported from D0 D3hot D3cold
[ 52.766361] pcieport 0000:00:05.0: AER: Multiple Corrected error received: 0000:00:05.0
[ 52.766509] pci 0000:02:00.0: [1f9d:1100] type 00 class 0x120000
[ 52.775499] pcieport 0000:00:05.0: PCIe Bus Error: severity=Corrected, type=Transaction Layer, (Receiver ID)
[ 52.782928] pci 0000:02:00.0: reg 0x10: [mem 0xdc010000-0xdc010fff 64bit]
[ 52.794084] pcieport 0000:00:05.0: device [8086:19a2] error status/mask=00002000/0000c000
[ 52.794090] pcieport 0000:00:05.0: [13] NonFatalErr
[ 52.800913] pci 0000:02:00.0: reg 0x18: [mem 0xda000000-0xdbffffff]
[ 52.821734] pci 0000:02:00.0: reg 0x30: [mem 0xdc000000-0xdc00ffff pref]
[ 52.828533] pci 0000:02:00.0: supports D1
[ 52.833926] pci 0000:02:00.0: PME# supported from D0 D1 D3hot
[ 52.841230] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 52.847483] pci 0000:00:09.0: bridge window [mem 0xda000000-0xdc0fffff]
[ 52.855748] pci 0000:00:09.0: BAR 14: assigned [mem 0x80000000-0x82ffffff]
[ 52.863994] pci 0000:00:09.0: BAR 0: assigned [mem 0x880000000-0x88001ffff 64bit]
[ 52.872833] pci 0000:02:00.0: BAR 2: assigned [mem 0x80000000-0x81ffffff]
[ 52.879663] pci 0000:02:00.0: BAR 6: assigned [mem 0x82000000-0x8200ffff pref]
[ 52.886927] pci 0000:02:00.0: BAR 0: assigned [mem 0x82010000-0x82010fff 64bit]
[ 52.894283] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 52.900674] pci 0000:00:09.0: bridge window [mem 0x80000000-0x82ffffff]
[ 52.909243] pcieport 0000:00:09.0: PME: Signaling with IRQ 27
[ 52.916235] pcieport 0000:00:09.0: AER: enabled with IRQ 27
[ 52.923191] pcieport 0000:00:09.0: DPC: enabled with IRQ 27
[ 52.930043] pcieport 0000:00:09.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 52.944341] pci 0000:00:09.0: Bridge removal and PCIe rescan completed successfully
[ 53.023366] axl 0000:02:00.0: Register directory metis-0000:02:00.0
[ 59.455359] pci 0000:06:10.0: [8086:15c5] type 00 class 0x020000
[ 59.473527] pci 0000:06:10.2: [8086:15c5] type 00 class 0x020000
[ 59.493260] pci 0000:06:10.4: [8086:15c5] type 00 class 0x020000
[ 59.525573] pci 0000:06:10.6: [8086:15c5] type 00 class 0x020000
[ 59.538170] pci 0000:06:11.0: [8086:15c5] type 00 class 0x020000
[ 59.565147] pci 0000:06:11.2: [8086:15c5] type 00 class 0x020000
[ 59.589185] pci 0000:06:11.4: [8086:15c5] type 00 class 0x020000
[ 59.747746] pci 0000:06:11.6: [8086:15c5] type 00 class 0x020000
[ 59.780101] pci 0000:06:12.0: [8086:15c5] type 00 class 0x020000
[ 59.806289] pci 0000:06:12.2: [8086:15c5] type 00 class 0x020000
[ 59.823283] pci 0000:06:12.4: [8086:15c5] type 00 class 0x020000
[ 59.838542] pci 0000:06:12.6: [8086:15c5] type 00 class 0x020000
[ 59.861133] pci 0000:06:13.0: [8086:15c5] type 00 class 0x020000
[ 59.932221] pci 0000:06:13.2: [8086:15c5] type 00 class 0x020000
[ 59.988309] pci 0000:06:13.4: [8086:15c5] type 00 class 0x020000
[ 60.007142] pci 0000:06:13.6: [8086:15c5] type 00 class 0x020000
[ 60.130347] pci 0000:06:14.0: [8086:15c5] type 00 class 0x020000
[ 60.156964] pci 0000:06:14.2: [8086:15c5] type 00 class 0x020000
[ 60.205621] pci 0000:06:14.4: [8086:15c5] type 00 class 0x020000
[ 60.232642] pci 0000:06:14.6: [8086:15c5] type 00 class 0x020000
[ 60.253935] pci 0000:06:15.0: [8086:15c5] type 00 class 0x020000
[ 60.277732] pci 0000:06:15.2: [8086:15c5] type 00 class 0x020000
[ 60.311638] pci 0000:06:15.4: [8086:15c5] type 00 class 0x020000
[ 60.381283] pci 0000:06:15.6: [8086:15c5] type 00 class 0x020000
[ 60.414076] pci 0000:06:16.0: [8086:15c5] type 00 class 0x020000
[ 60.438207] pci 0000:06:16.2: [8086:15c5] type 00 class 0x020000
[ 60.541189] pci 0000:06:16.4: [8086:15c5] type 00 class 0x020000
[ 60.568682] pci 0000:06:16.6: [8086:15c5] type 00 class 0x020000
[ 60.586995] pci 0000:06:17.0: [8086:15c5] type 00 class 0x020000
[ 60.604188] pci 0000:06:17.2: [8086:15c5] type 00 class 0x020000
[ 60.632228] pci 0000:06:17.4: [8086:15c5] type 00 class 0x020000
[ 60.648611] pci 0000:06:17.6: [8086:15c5] type 00 class 0x020000
[ 60.678361] pci 0000:06:18.0: [8086:15c5] type 00 class 0x020000
[ 60.695351] pci 0000:06:18.2: [8086:15c5] type 00 class 0x020000
[ 60.717211] pci 0000:06:18.4: [8086:15c5] type 00 class 0x020000
[ 60.774665] pci 0000:06:18.6: [8086:15c5] type 00 class 0x020000
[ 60.799017] pci 0000:06:19.0: [8086:15c5] type 00 class 0x020000
[ 60.811827] pci 0000:06:19.2: [8086:15c5] type 00 class 0x020000
[ 60.827916] pci 0000:06:19.4: [8086:15c5] type 00 class 0x020000
[ 60.890542] pci 0000:06:19.6: [8086:15c5] type 00 class 0x020000
[ 60.944892] pci 0000:06:1a.0: [8086:15c5] type 00 class 0x020000
[ 60.966822] pci 0000:06:1a.2: [8086:15c5] type 00 class 0x020000
[ 60.985470] pci 0000:06:1a.4: [8086:15c5] type 00 class 0x020000
[ 61.042987] pci 0000:06:1a.6: [8086:15c5] type 00 class 0x020000
[ 61.074288] pci 0000:06:1b.0: [8086:15c5] type 00 class 0x020000
[ 61.088074] pci 0000:06:1b.2: [8086:15c5] type 00 class 0x020000
[ 61.103126] pci 0000:06:1b.4: [8086:15c5] type 00 class 0x020000
[ 61.117584] pci 0000:06:1b.6: [8086:15c5] type 00 class 0x020000
[ 61.137967] pci 0000:06:1c.0: [8086:15c5] type 00 class 0x020000
[ 61.166054] pci 0000:06:1c.2: [8086:15c5] type 00 class 0x020000
[ 61.190240] pci 0000:06:1c.4: [8086:15c5] type 00 class 0x020000
[ 61.209704] pci 0000:06:1c.6: [8086:15c5] type 00 class 0x020000
[ 61.222521] pci 0000:06:1d.0: [8086:15c5] type 00 class 0x020000
[ 61.235375] pci 0000:06:1d.2: [8086:15c5] type 00 class 0x020000
[ 61.251026] pci 0000:06:1d.4: [8086:15c5] type 00 class 0x020000
[ 61.263841] pci 0000:06:1d.6: [8086:15c5] type 00 class 0x020000
[ 61.295264] pci 0000:06:1e.0: [8086:15c5] type 00 class 0x020000
[ 61.325270] pci 0000:06:1e.2: [8086:15c5] type 00 class 0x020000
[ 61.340702] pci 0000:06:1e.4: [8086:15c5] type 00 class 0x020000
[ 61.355297] pci 0000:06:1e.6: [8086:15c5] type 00 class 0x020000
[ 61.370889] pci 0000:06:1f.0: [8086:15c5] type 00 class 0x020000
[ 61.395686] pci 0000:06:1f.2: [8086:15c5] type 00 class 0x020000
[ 61.408735] pci 0000:06:1f.4: [8086:15c5] type 00 class 0x020000
[ 63.839215] pci 0000:06:10.1: [8086:15c5] type 00 class 0x020000
[ 63.851918] pci 0000:06:10.3: [8086:15c5] type 00 class 0x020000
[ 63.869834] pci 0000:06:10.5: [8086:15c5] type 00 class 0x020000
[ 63.895957] pci 0000:06:10.7: [8086:15c5] type 00 class 0x020000
[ 63.912963] pci 0000:06:11.1: [8086:15c5] type 00 class 0x020000
[ 63.927939] pci 0000:06:11.3: [8086:15c5] type 00 class 0x020000
[ 63.952456] pci 0000:06:11.5: [8086:15c5] type 00 class 0x020000
[ 63.969079] pci 0000:06:11.7: [8086:15c5] type 00 class 0x020000
[ 63.984046] pci 0000:06:12.1: [8086:15c5] type 00 class 0x020000
[ 64.001821] pci 0000:06:12.3: [8086:15c5] type 00 class 0x020000
[ 64.018530] pci 0000:06:12.5: [8086:15c5] type 00 class 0x020000
[ 64.031460] pci 0000:06:12.7: [8086:15c5] type 00 class 0x020000
[ 64.046243] pci 0000:06:13.1: [8086:15c5] type 00 class 0x020000
[ 64.062845] pci 0000:06:13.3: [8086:15c5] type 00 class 0x020000
[ 64.078148] pci 0000:06:13.5: [8086:15c5] type 00 class 0x020000
[ 64.102977] pci 0000:06:13.7: [8086:15c5] type 00 class 0x020000
[ 64.140904] pci 0000:06:14.1: [8086:15c5] type 00 class 0x020000
[ 64.164798] pci 0000:06:14.3: [8086:15c5] type 00 class 0x020000
[ 64.185555] pci 0000:06:14.5: [8086:15c5] type 00 class 0x020000
[ 64.210386] pci 0000:06:14.7: [8086:15c5] type 00 class 0x020000
[ 64.229064] pci 0000:06:15.1: [8086:15c5] type 00 class 0x020000
[ 64.242084] pci 0000:06:15.3: [8086:15c5] type 00 class 0x020000
[ 64.264698] pci 0000:06:15.5: [8086:15c5] type 00 class 0x020000
[ 64.278943] pci 0000:06:15.7: [8086:15c5] type 00 class 0x020000
[ 64.306978] pci 0000:06:16.1: [8086:15c5] type 00 class 0x020000
[ 64.320908] pci 0000:06:16.3: [8086:15c5] type 00 class 0x020000
[ 64.395185] pci 0000:06:16.5: [8086:15c5] type 00 class 0x020000
[ 64.419331] pci 0000:06:16.7: [8086:15c5] type 00 class 0x020000
[ 64.432722] pci 0000:06:17.1: [8086:15c5] type 00 class 0x020000
[ 64.459347] pci 0000:06:17.3: [8086:15c5] type 00 class 0x020000
[ 64.472620] pci 0000:06:17.5: [8086:15c5] type 00 class 0x020000
[ 64.486110] pci 0000:06:17.7: [8086:15c5] type 00 class 0x020000
[ 64.517304] pci 0000:06:18.1: [8086:15c5] type 00 class 0x020000
[ 64.530679] pci 0000:06:18.3: [8086:15c5] type 00 class 0x020000
[ 64.545194] pci 0000:06:18.5: [8086:15c5] type 00 class 0x020000
[ 64.562818] pci 0000:06:18.7: [8086:15c5] type 00 class 0x020000
[ 64.575510] pci 0000:06:19.1: [8086:15c5] type 00 class 0x020000
[ 64.590074] pci 0000:06:19.3: [8086:15c5] type 00 class 0x020000
[ 64.623575] pci 0000:06:19.5: [8086:15c5] type 00 class 0x020000
[ 64.650429] pci 0000:06:19.7: [8086:15c5] type 00 class 0x020000
[ 64.676196] pci 0000:06:1a.1: [8086:15c5] type 00 class 0x020000
[ 64.688818] pci 0000:06:1a.3: [8086:15c5] type 00 class 0x020000
[ 64.733090] pci 0000:06:1a.5: [8086:15c5] type 00 class 0x020000
[ 64.757993] pci 0000:06:1a.7: [8086:15c5] type 00 class 0x020000
[ 64.775247] pci 0000:06:1b.1: [8086:15c5] type 00 class 0x020000
[ 64.797885] pci 0000:06:1b.3: [8086:15c5] type 00 class 0x020000
[ 64.810757] pci 0000:06:1b.5: [8086:15c5] type 00 class 0x020000
[ 64.823978] pci 0000:06:1b.7: [8086:15c5] type 00 class 0x020000
[ 64.841937] pci 0000:06:1c.1: [8086:15c5] type 00 class 0x020000
[ 64.861118] pci 0000:06:1c.3: [8086:15c5] type 00 class 0x020000
[ 64.877279] pci 0000:06:1c.5: [8086:15c5] type 00 class 0x020000
[ 64.898423] pci 0000:06:1c.7: [8086:15c5] type 00 class 0x020000
[ 64.926601] pci 0000:06:1d.1: [8086:15c5] type 00 class 0x020000
[ 64.959091] pci 0000:06:1d.3: [8086:15c5] type 00 class 0x020000
[ 64.972064] pci 0000:06:1d.5: [8086:15c5] type 00 class 0x020000
[ 64.996993] pci 0000:06:1d.7: [8086:15c5] type 00 class 0x020000
[ 65.010275] pci 0000:06:1e.1: [8086:15c5] type 00 class 0x020000
[ 65.024047] pci 0000:06:1e.3: [8086:15c5] type 00 class 0x020000
[ 65.048707] pci 0000:06:1e.5: [8086:15c5] type 00 class 0x020000
[ 65.070281] pci 0000:06:1e.7: [8086:15c5] type 00 class 0x020000
[ 65.085434] pci 0000:06:1f.1: [8086:15c5] type 00 class 0x020000
[ 65.104271] pci 0000:06:1f.3: [8086:15c5] type 00 class 0x020000
[ 65.125208] pci 0000:06:1f.5: [8086:15c5] type 00 class 0x020000
[ 205.764951] axl 0000:02:00.0: Unregistered metis-0:2:0 (0 0)
[ 205.764961] axl 0000:02:00.0: Release dma mem metis-0:2:0
[ 205.772630] pci_bus 0000:02: busn_res: [bus 02] is released
[ 207.845305] pci 0000:00:09.0: [8086:19a4] type 01 class 0x060400
[ 207.845331] pci 0000:00:09.0: reg 0x10: [mem 0x880000000-0x88001ffff 64bit]
[ 207.845416] pci 0000:00:09.0: PME# supported from D0 D3hot D3cold
[ 207.845748] pcieport 0000:00:05.0: AER: Multiple Corrected error received: 0000:00:05.0
[ 207.845801] pcieport 0000:00:05.0: PCIe Bus Error: severity=Corrected, type=Transaction Layer, (Receiver ID)
[ 207.845805] pcieport 0000:00:05.0: device [8086:19a2] error status/mask=00002000/0000c000
[ 207.845810] pcieport 0000:00:05.0: [13] NonFatalErr
[ 207.845939] pci 0000:02:00.0: [1f9d:1100] type 00 class 0x120000
[ 207.845961] pci 0000:02:00.0: reg 0x10: [mem 0x82010000-0x82010fff 64bit]
[ 207.845972] pci 0000:02:00.0: reg 0x18: [mem 0x80000000-0x81ffffff]
[ 207.846000] pci 0000:02:00.0: reg 0x30: [mem 0xdc000000-0xdc00ffff pref]
[ 207.846065] pci 0000:02:00.0: supports D1
[ 207.846068] pci 0000:02:00.0: PME# supported from D0 D1 D3hot
[ 207.847202] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 207.847220] pci 0000:00:09.0: bridge window [mem 0x80000000-0x82ffffff]
[ 207.847376] pci 0000:00:09.0: BAR 14: assigned [mem 0x80000000-0x82ffffff]
[ 207.847386] pci 0000:00:09.0: BAR 0: assigned [mem 0x880000000-0x88001ffff 64bit]
[ 207.847429] pci 0000:02:00.0: BAR 2: assigned [mem 0x80000000-0x81ffffff]
[ 207.847435] pci 0000:02:00.0: BAR 6: assigned [mem 0x82000000-0x8200ffff pref]
[ 207.847440] pci 0000:02:00.0: BAR 0: assigned [mem 0x82010000-0x82010fff 64bit]
[ 207.847451] pci 0000:00:09.0: PCI bridge to [bus 02]
[ 207.847457] pci 0000:00:09.0: bridge window [mem 0x80000000-0x82ffffff]
[ 207.847874] pcieport 0000:00:09.0: PME: Signaling with IRQ 27
[ 207.848087] pcieport 0000:00:09.0: AER: enabled with IRQ 27
[ 207.849114] pcieport 0000:00:09.0: DPC: enabled with IRQ 27
[ 207.849125] pcieport 0000:00:09.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 207.852847] pci 0000:02:00.0: Found target device: AXLAIPU_OMEGA_DEVICE_ID
[ 207.852857] pci 0000:02:00.0: Found target device: 0000:02:00.0
[ 207.852861] pcieport 0000:00:09.0: Found bridge device: 0000:00:09.0
[ 207.852868] pcieport 0000:00:09.0: Bridge window: [mem 0x80000000-0x82ffffff]
[ 207.852873] pcieport 0000:00:09.0: Decoded memory behind bridge: 80000000-82ffffff
[ 207.852877] pcieport 0000:00:09.0: Memory behind bridge is sufficient. Skipping reset.
[ 207.856669] axl 0000:02:00.0: Register directory metis-0000:02:00.0
  • March 31, 2026
https://wiki.debian.org/DkmsPackaging
Creating a DKMS Debian Package
Prepare Source: Organize your driver source in /usr/src/<module>-<version>/.
Create dkms.conf: Place a dkms.conf file in the source directory to define build parameters.
Add to DKMS: Run sudo dkms add -m <module> -v <version>.
Build Binary Package: Use sudo dkms mkdeb -m <module> -v <version> to generate the .deb file.
Debian Wiki
And I just have not long ago for gentoo n arch linux...  and posted links
PKGBUILDs on forum n ebuilds.... take conf from them and enjoy
https://github.com/Lonewolf-Information-systems/CM5-Exaviz/blob/main/Arch-Linux/metis-dkms/PKGBUILD
https://github.com/Lonewolf-Information-systems/CM5-Exaviz/tree/main/axelera.ai-overlay/sys-kernel
https://github.com/Lonewolf-Information-systems/CM5-Exaviz/blob/main/Arch-Linux/metis-dkms/dkms.conf
  • March 31, 2026
#!/bin/bash
# Simple script to generate a .deb from a DKMS source directory
PACKAGE_NAME="metis-dkms"
PACKAGE_VERSION="1.0.0"
ARCH="arm64,amd64"
MAINTAINER="Your Name <you@example.com>"
DESCRIPTION="Metis AI Accelerator DKMS driver"
# 1. Create directory structure
BUILD_DIR="deb_build_${PACKAGE_NAME}"
mkdir -p "$BUILD_DIR/DEBIAN"
mkdir -p "$BUILD_DIR/usr/src/${PACKAGE_NAME}-${PACKAGE_VERSION}"
# 2. Copy your local Arch source into the build directory
cp -r ./* "$BUILD_DIR/usr/src/${PACKAGE_NAME}-${PACKAGE_VERSION}/"
rm -rf "$BUILD_DIR/usr/src/${PACKAGE_NAME}-${PACKAGE_VERSION}/deb_build_"*
# 3. Create the Control file
cat <<EOF > "$BUILD_DIR/DEBIAN/control"
Package: $PACKAGE_NAME
Version: $PACKAGE_VERSION
Section: kernel
Priority: optional
Architecture: $ARCH
Maintainer: $MAINTAINER
Depends: dkms, libc6-dev
Description: $DESCRIPTION
 This package contains the Metis DKMS source for automated kernel module building.
EOF
# 4. Create Post-Install script to trigger DKMS
cat <<EOF > "$BUILD_DIR/DEBIAN/postinst"
#!/bin/bash
dkms add -m $PACKAGE_NAME -v $PACKAGE_VERSION
dkms build -m $PACKAGE_NAME -v $PACKAGE_VERSION
dkms install -m $PACKAGE_NAME -v $PACKAGE_VERSION
EOF
chmod 755 "$BUILD_DIR/DEBIAN/postinst"
# 5. Create Prerm script to cleanup
cat <<EOF > "$BUILD_DIR/DEBIAN/prerm"
#!/bin/bash
dkms remove -m $PACKAGE_NAME -v $PACKAGE_VERSION --all
EOF
chmod 755 "$BUILD_DIR/DEBIAN/prerm"
# 6. Build the .deb
dpkg-deb --build "$BUILD_DIR" "${PACKAGE_NAME}_${PACKAGE_VERSION}_${ARCH}.deb"
echo "Done: ${PACKAGE_NAME}_${PACKAGE_VERSION}_${ARCH}.deb created."
  • March 31, 2026
for TARGET_ARCH in arm64 amd64; do
  # Update control file with $TARGET_ARCH
  # dpkg-deb --build "$BUILD_DIR" "${PACKAGE_NAME}_${VERSION}_${TARGET_ARCH}.deb"
done
  • April 1, 2026
Thank you for the suggestion, but the metis kernel driver is already correctly installed and loaded. The issue is at the PCIe Data Link Layer level (DLActive-), not at the driver level
  • April 1, 2026
Hi guys! Hmm, yeah, I wonder if this isn’t a driver installation issue either. The driver is loaded and the card is enumerated with BARs assigned correctly, as you say. So maybe we’re looking at a communication level between the host and the Metis firmware that’s problematic?
One common cause of this on non-Ubuntu setups is IOMMU being enabled. What if you try adding intel_iommu=off to your kernel command line parameters and rebooting? From what I can find, in Debian 12 this is typically in /etc/default/grub under GRUB_CMDLINE_LINUX_DEFAULT, then run sudo update-grub and reboot. If you're using a custom bootloader, add it wherever your kernel cmdline is configured.
Let me know if that changes the axdevice output!
  • April 2, 2026
Thank you for your help. I can't simply disable intel_iommu globally because it is used for other services in our environment. Instead, I tried to disable it per device, but it seems that /sys/kernel/iommu_groups/ is empty, no devices are assigned to any IOMMU group and DMA translation is not active for any PCIe device, including the Axelera card.
  • April 3, 2026
Ah okay, thanks for confirming that. Good work on researching the IOMMU groups - since those are empty and DMA translation isn't active, we can probably rule that out now. I was barking up the wrong tree there I guess 😄
So, the driver loads and BARs are assigned correctly but the board controller returns an invalid board type… That might suggest the Metis firmware isn't initialising properly after enumeration? I found a note about how the host cutting 3.3V standby power to the slot before the firmware has finished booting can demonstrate similar symptoms.
We could you try disabling d3cold_allowed on the PCIe bridge device for the Metis card and then doing a rescan?
echo 0 | sudo tee /sys/bus/pci/devices/0000:00:09.0/d3cold_allowed
echo 1 | sudo tee /sys/bus/pci/devices/0000:02:00.0/remove
echo 1 | sudo tee /sys/bus/pci/rescan
Also, have you tried axdevice --refresh? That does a full remove/rescan/firmware-reload cycle which sometimes resolves the timeout on the first attempt. Let me know if any of this gets us closer!
  • April 3, 2026
Hi, thanks for the suggestion! Unfortunately the d3cold_allowed fix didn't change anything — DLActive- is still there after the rescan. I also already tried axdevice --refresh earlier, but it returned the same error:
Here's what I get with axdevice --verbose:
The link is physically up at Gen3 x4, the driver binds, BARs are assigned — but the firmware never seems to finish initializing. Could board_type=8 mean anything specific on your end? At this point I'm wondering if the onboard firmware might be corrupted
  • April 14, 2026
Hi, i’m still stuck with this issue. any new suggestion ?
  • April 14, 2026
@belkacem did you install the dkms modules?
Also what happens if you run `lsmod | grep Metis`?
  • April 14, 2026
Hi ​@belkacem! Hmm, there are a couple of unknowns for us, like Debian 12 with a custom kernel and StarTech PCIe-to-M.2 adapter (to my knowledge, neither’s been tested internally - certainly not the custom kernel, of course 😄), which makes it tricky to fathom where the exact issue is.
One thing we haven't tried yet is adding pcie_aspm=off to your kernel command line parameters? I think it shows ASPM as being disabled somewhere (I saw it above previously) but still - might be worth a shot in case something in the kernel power management is overriding the firmware?
