does Axelera has Yocto support?
  • November 14, 2025
  • 101 views
I wanna use axelera metis on alinx board and I wonder that is there any yocto support?
  • November 14, 2025
Hi ​@Eva! The Metis Compute Board actually has a pre-configured Yocto BSP, so it’s certainly an option.
I couldn’t say about an Alinx board, as that depends on whether there’s a BSP layer for that one (I don’t beleive Axelera’s done any work on that, and I’ve not heard about it being on any roadmaps). But in theory, building an Alinx/Axelera Yocto Linux image with the right drivers, bootloader, kernel config etc is perfectly feasible (if maybe a bit complex)!
You could also potentially look at running the Voyager SDK in Docker using an Ubuntu 22.04 container, if your Alinx already has a Yocto BSP that works?
  • November 14, 2025
if it is open source. maybe it can be done
  • November 14, 2025
This might be helpful too, if you decide to work on this:
Keep me posted on how it goes!
