Hi guys, new to the conversation here.
Just wondering whether there is a software compatibility matrix available somewhere?
I’ve been trying to get the METIS M2 chip running on my Jetson Orin NX. Thing is, I’m running a custom YOCTO build (based on Jetpack 6) and want to run the voyager-sdk in a Docker container, but I just can’t seem to get the drivers to properly match. So what driver versions match with which voyager-sdk versions?
The main error I’m getting is the one below:
root@hw00001aaa-24050002:/workspace# axdevice --pcie-scan
0007:01:00.0 : Axelera AI Metis AIPU (rev 02)
[libtriton_linux.c:799] Failed to open '/dev/metis-7:1:0': No such device
[AxeleraDevice.cpp:71] Device not found: metis-7:1:0
WARNING: Failed to open device 0(metis-7:1:0)
ERROR: Failed to open device metis-7:1:0
My guess is that it’s a driver version mismatch. These are my current axelera-device and -runtime versions.
root@hw00001aaa-24050002:/workspace# ls -d /opt/axelera/device-* /opt/axelera/runtime-* 2>/dev/null
/opt/axelera/device-1.4.1-1 /opt/axelera/runtime-1.4.1-1
I tried the following metis driver versions: 1.2.2 and 1.2.3
I’m probably missing something, somewhere in the documentation.
So if someone can help me set this up, so I can start playing around with the METIS hardware, that would be great! Thanks!
Cheers,
Sebbe
FYI: Some extra info, I’m able to detect the device through lspci and lsmod.
[METIS M2 DRIVER ERROR] Driver x runtime compatibility
Sign up
Log in, or create an Axelera AI account
Log In or Register HereLogin to the community
No account yet? Create an account
Log In or Register HereEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
