Export YOLOv8s Detections to JSON with Timestamps in Voyager SDK
  • June 20, 2025
  • 92 views
I’m using Axelera’s Voyager SDK to run a YOLOv8s object-detection pipeline on video files, and I need to capture every detection into a JSON array for downstream processing. For each detected object, I want to record:
  • frame_index: the zero-based frame number
  • timestamp: the frame’s PTS in seconds
  • bbox: [x1, y1, x2, y2] coordinates
  • class_id: numeric COCO class index
  • class_name: readable label (e.g. “person”)
  • score: detection confidence
What’s the cleanest way to hook into the Voyager inference loop, pull out the ObjectDetectionMeta (task name “detections”), convert its boxes, scores, class_ids, and labels into native Python types, attach the FrameResult.src_timestamp, and dump the results into a single JSON file? Example snippets or pointers to the relevant SDK APIs would be greatly appreciated.
  • June 23, 2025
This ought to do the trick:
#!/usr/bin/env python
import json
network="yolov8s-coco",
sources=["media/traffic2_1080p.mp4"],
frames=50,
out = []
for frame_no, result in enumerate(stream):
for detection in result.detections:
box = [int(x) for x in detection.box]
out.append(
'frame_no': frame_no,
'timestamp': result.src_timestamp,
'bbox': box,
'class_id': detection.label.value,
'label': detection.label.name,
'score': float(detection.score),
print(json.dumps(out, indent=2))
stream.stop()
This is covered here: https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.3/docs/tutorials/application.md#simple-application-integration-example
The reference documentation for meta objects is not as good as it should be yet, but rest assured we are working on it!  Here I used the frame results detections object to get a list of DetectedObject, which provides more pythonic access to the meta data.
https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.3/axelera/app/meta/object_detection.py#L31
and its base class has the label property which is an enum.Enum for Coco.
https://github.com/axelera-ai-hub/voyager-sdk/blob/release/v1.3/axelera/app/meta/base.py#L260
HTH
Sam
