From whiteboard to shared knowledge: an offline meeting companion for process discovery
  • July 17, 2026
  • 84 views
I run digital transformation workshops for Italian SMEs, which means I spend a lot of time in meeting rooms covered in sticky notes. Process mapping sessions, mostly. And after years of trying every digital tool out there, I've accepted the truth: pen and paper wins. People think better on a whiteboard. They sketch flowcharts, build effort/impact matrices with sticky notes, draw arrows everywhere. It works.
What doesn't work is everything that comes after. Someone (usually me) photographs the wall, and then spends an evening squinting at pictures, retyping notes, trying to reconstruct a matrix that made perfect sense in the room. Regular OCR doesn't help much either, because it gives you the words but loses the structure. A matrix without rows and columns is just a word list. So in practice, half of that knowledge dies when the board gets erased.
So here's what I want to build: a small box that sits in the meeting room and captures the knowledge while it's being created.
A camera points at the whiteboard. The Metis pipeline (built with Wingman) watches the board and picks up new elements as they appear, classifying each one: sticky note, text block, diagram, table. Text goes to OCR on the host. Diagrams and matrices go through a small local vision-language model instead, which extracts the actual structure, so arrows become relationships and cells keep their position. A local LLM then connects everything to the process being mapped.
At the end of the session you get two things. First, a RAG you can query right on the device: "what pain points came up around invoicing?" and it answers citing the actual notes, showing the photo crops as evidence. Second, an export of the whole session as an Open Knowledge Format bundle, the markdown+YAML spec Google published in June. That part matters to me because the goal isn't just archiving a meeting. It's making the knowledge portable: any other local agent, in the client's office or in mine, can ingest that bundle and build on it. No conversion, no platform, no cloud.
And the no-cloud part is the whole point, really. Business processes are sensitive information. I've never met an SME owner who was thrilled about uploading their order-to-cash workflow to someone's cloud just to get it digitized. A box that walks into the room, does everything locally, and walks out with the data still inside it is what makes this actually usable with real clients. That's the reason it has to be edge.
Wingman would handle the entire vision side: board monitoring, change detection, element detection and classification, crops. I'll document every prompt and every iteration, since that pipeline is exactly the part that would normally cost me weeks.
Scope for the month: capture, classification, OCR and structure extraction, RAG, OKF export, demoed live in a real workshop setup. I'm keeping diagram understanding pragmatic at first (structure and labels, not perfection) and improving from there. If time allows, two stretch goals: generating a draft process flow diagram from the captured knowledge, and reusing the same pipeline as an "idea collector" station for events.
One last thing: I teach AI adoption to SMEs for a living, so if this works it won't stay a demo. It goes into real meeting rooms in September.
  • July 17, 2026
AI note taking apps are all the rage, yeah. We use them here for calls, and I don’t mind admitting they’re really good! Not just getting a transcription, but actual notes that you might take yourself.
So this is a great next level to that! Voice-based note taking apps are plentiful, but visual note taking is inspired!
I used to work at EA a long time ago, and they had these great rooms that were wallpapered in whiteboard material, so you could write ceiling to skirting board around three full walls! It was mega useful, until the day that you needed to record it all because it needed to get wiped. The truth is, those notes were lost, even if you might sometimes take a photo of them (you never actually used, or even looked at, the photo). This was before the days of AI, but I bet those whiteboard rooms still exist!
  • July 18, 2026
Ha, the EA rooms, I love that. And yeah, I'd bet they still exist. What you're describing is exactly the thing. That photo you snap to "save" the wall before someone wipes it? Nobody ever opens it again. It just sits in your camera roll making you feel a bit guilty. Taking the picture was never the problem. Doing something useful with it afterwards was.
And I think you've put your finger on why the visual side matters. When people actually get up and start scribbling, they're sharper. A keyboard is a filter, and not everyone writes at the speed they think, so a lot gets lost in that gap. A whiteboard doesn't do that. It's faster, messier in the good way, and the whole room joins in instead of one person typing while everyone watches. That's the part worth keeping, and it's the part every digital tool quietly gave up on.
So the voice note-takers and this are two halves of the same picture. One captures what got said, the other captures what got drawn. A meeting was never just a transcript, and half the real thinking ends up on the wall. I just want that half to stop disappearing the second the marker runs dry.
  • July 20, 2026
Really great points. When you’re writing it on a whiteboard (or the wall 🤣) you also don’t just write the words, like you do with a keyboard. You’re adding rough diagrams, arrows, connectors, you’re circling words and underlining them - none of which happens with a keyboard.
  • August 4, 2026
Since the pitch I've been building the other half of this, almost by accident. It's a company portal that takes the paper tools a business actually runs on and turns them into working digital ones. It has APIs, so an agent can convert what gets captured on site straight into structured records — and once the data's flowing, the KPIs and the automated lanes I've already got in there start suggesting new shapes for the processes themselves. The paperwork stops being an archive and starts being a signal.
Which is the part where Metis stops being nice-to-have.
On-site capture is the one moment the form still only exists on paper. If OCR and handwriting recognition happen right there, the operator finds out immediately that box 7 is illegible — not three days later at a desk, when fixing it means driving back. It's the only point in the chain where the mistake is free.
There's also the thing I spend my working life telling Italian SMEs about: shipping client records and signed forms to a cloud OCR API is precisely the GDPR problem. Doing it on-device means the portal gets clean structured data and the paper is never photographed outward. And practically speaking, capture happens in warehouses, plants, branch offices — places where the connectivity is honestly terrible. Local inference doesn't care. The portal syncs later.
Then there's the boring stuff that decides whether a thing ships: 4-8W means the capture device can be a case you carry, not a PC you plug in. At volume, a dedicated AIPU gives you steady pages-per-hour and a fixed cost per inference, instead of a metered bill that grows with every new site.
Same vision pipeline as ARGO, pointed the other way. There, Metis recognises who's watching. Here, it recognises what's on the sheet. Same hardware, same Wingman workflow, one idea proved twice — perception stays local, decisions go central.
