Need Guidance for Building a Real-Time CCTV Surveillance Web Application Using Axelera Metis
  • June 11, 2026
  • 193 views
Hello everyone
I have an Axelera Metis PCIe card with the hardware setup completed, and I am planning to build a home CCTV surveillance web application. My goal is to process multiple RTSP/IP camera streams in real time using AI models such as RetinaFace for face detection, FaceNet for face recognition, and YOLOv8n ONNX for object detection. I would like to create a web dashboard where users can view live camera feeds, detect and recognize known faces, identify unknown visitors, monitor people and objects, and store detection logs and alerts. I am considering using FastAPI as the backend and a web frontend for live monitoring and management.
I would like guidance on the best way to integrate these AI models with the Metis card and expose the results through APIs. Are there any recommended examples, repositories, or best practices for running multiple AI pipelines simultaneously on Metis? I am also interested in learning how other developers handle RTSP streams, face embedding databases, event logging, and real-time web dashboards with Axelera hardware. Any suggestions, architecture recommendations, or community projects related to surveillance and face recognition would be very helpful.
Best answer by Spanner
Howdy ​@Nanthu! Loving this project - there’s simply no denying that for all the many and wonderful AI vision use cases, security and CCTV are the ones that are driving the way forward!
Maybe the best first step is to just get something up and running, and focus on the front end once that’s all confirmed and you’ve seen it in action: one model, one camera. YOLOv8n is already in the model zoo, and inference.py takes RTSP sources directly, so from your SDK directory try:
./inference.py yolov8n-coco-onnx rtsp://<your-camera-url>
First run will compile the model, so give it a few minutes. If that shows live detections from your camera, we know your card, install and RTSP feeds are all confirmed working, and everything else you’re planning then builds on top of that. It’s easy to jump ahead to the fun design work, but a solid foundation pays dividends here!
The model zoo reference and the application integration tutorial cover the input source formats and how to move from inference.py to your own Python application, including multiple streams and RTSP latency tuning.
For inspiration once that's running, there are a bunch of community projects in similar territory: a Home Assistant CCTV object detection build using Metis and RTSP cameras, and a deeper dive into a multi-model, multi-stream security system. There's also an earlier thread on streaming annotated video back to a web frontend that's close to your dashboard use case. And although right now you’re focusing on facial recognition, there’s some outstanding work on license plate recognition here, too.
And RetinaFace and FaceNet variants do exist in the model zoo, so the cascade face detection plus recognition piece will be a solid follow-up once your basics are rock solid and working. Can’y wait to see all this in action! Keep us posted on all your progress, won’t you!
  • June 12, 2026
